Module Woocommerce EN
Revision as of 14:47, 23 December 2016 by P.scoffoni (talk | contribs) (Work in progress)
Module name Woocommerce
Last update date / Date mise à jour fiche / Fecha última actualización 2016-12-23
Integrates a Woocommerce - Dolibarr synchronyzation. It is a module to be installed in Dolibarr. Access to Woocommerce is done by dolibarr using default Woocommerce's WebServices. Actually this module is under developpement and use the same core as Module Magento Template:Module Magento EN
Woocommerce
To be defined
Dolibarr module
From the application
Manually
unzip modulefile.zip
Setup on Woocomerce side
To be defined
Setup on Dolibarr side
To be defined
Synchronize from Woocommerce to Dolibarr
Action into Woocomerce Effect into Dolibarr When Note
Categories created/modified into Woocomerce Created into Dolibarr as sub-categories of the parent category used for Mangeto categories (defined into module setup) Manual click on "Magento to Dolibarr sync" button
NA
Table llx_ecommerce_category is updated to store a link between dolibarr category id and remote magento id. Due to a lack of search on last modified time on Magento API, this sync may be slow if you have a high number of categories
Products or Stock created/modified into Magento Created into Dolibarr and linked to its categories.
If module stock is enabled and Stock synchronisation direction was set to "ecommerce2dolibarr", stock is also initialised/updated into warehouse defined into eCommerce dolibarr module setup
TODO
Table llx_ecommerce_product is updated to store a link between dolibarr product id and remote magento id
Thirdparties and contact/addresses created/modified into Magento Created into Dolibarr Manual click on "Magento to Dolibarr sync" button
TODO
Table llx_ecommerce_societe and llx_ecommerce_socpeople is updated to store a link between dolibarr thirdparty id and remote magento id. To know if a thirdparty already exists, Magento check on the ref. To know if a contact already exists, Magento check on all fields firstname, lastname, address, zip, town (and thirdparty).
Orders created/modified into Magento Created into Dolibarr Manual click on "Magento to Dolibarr sync" button
TODO
Table llx_ecommerce_commande is updated to store link of dolibarr order id and remote magento id
Shipment created/modified in Magento Creating a shipment in Magento is changing Magento status of the Order from "pending" to "processing". Because it is changing status of order, see case "Order created/modified into Magento". Manual click on "Magento to Dolibarr sync" button
NA
Note: The shipment is not downloaded into Dolibarr, only status of Dolibarr Order will be changed like is the Magento order.
Note: You may choose to manage shipment on Dolibarr or Magento (we recommand to create/update shipments on Dolibarr and not into Magento).
Invoices created/modified into Magento Created into Dolibarr (with correct status but without payments) Manual click on "Magento to Dolibarr sync" button
NA
Table llx_ecommerce_facture is updated to store a link between dolibarr invoice id and remote magento id.
Note: Payment must still be recorded manually on Dolibarr.
TODO In a future version, the "Magento to Dolibarr sync" button could be replaced with a scheduled job/script to launch it automaticaly every hour for example.
Synchronize from Dolibarr to Magento
Action into Dolibarr Effect into Magento When Note
Categories created into Dolibarr No update is currently done on Magento. In a future version, creation will be done into Magento if category is inside the parent category for Magento, defined into module setup No creation/update is currently done on Magento. In a future version, sync will be in real time
NA
Categories modified into Dolibarr No update is currently done on Magento. In a future version, update will be done into Magento if category is linked to Magento (category was created by a "Magento to Dolibarr sync") No creation/update is currently done on Magento. In a future version, sync will be in real time
NA
Products created into Dolibarr None. In a future, creation will be done into Magento if product has a category inside tree of Magento categories No creation is currently done on Magento. In a future version, sync will be in real time
TODO
Products or Stock modified into Dolibarr Update into Magento is done if product is linked to Magento (product was created by a "Magento to Dolibarr sync")
If module stock is enabled and Stock synchronisation direction was set to "dolibarr2ecommerce", then stock is also overwritten on Magento
Real time
TODO
Thirdparties created None. In a future version, creation will be done into Magento if thirdparty has the category of Magento thirdparties (defined into setup) No creation is currently done on Magento. In a future version, sync will be in real time
NA
Thirdparties modified into Dolibarr Update into Magento is done if thirdparty is linked to Magento (thirdparty was created by a "Magento to Dolibarr sync") Real time
NA
Contact/addresses created into Dolibarr None. In a future version, creation will be done into Magento if thirdparty has the category of Magento thirdparties (defined into setup) No creation is currently done on Magento. In a future version, sync will be in real time
NA
Contact/addresses modified into Dolibarr Update into Magento is done if contact/address is linked to Magento (contact/address was created by a "Magento to Dolibarr sync") Real time
NA
Orders created (validated) into Dolibarr None Orders created directly into backoffice does not need to appear into ecommerce. See next line for Orders modified.
Orders modified into Dolibarr Order will be updated into Magento if order is linked to Magento (order was created by a "Magento to Dolibarr sync") No update is currently done on Magento. In a future version, sync will be in real time
TODO
Shipments created (validated) into Dolibarr Shipment will be created/modified into Magento if source order of shipment was created by a "Magento to Dolibarr sync" Real time
NA
Shipments modified (closed) into Dolibarr This step does not exists on Mangento, so nothing is done NA
Invoice created (validated) into Dolibarr None. In a future, invoice will be created/modified into Magento if source order was coming from Magento No creation/update is currently done on Magento. In a future version, sync will be in real time
TODO
Invoice modified into Dolibarr (for exemple when status change to paid because of a payment entered) None. In a future, invoice will be created/modified into Magento if source order was coming from Magento No creation/update is currently done on Magento. In a future version, sync will be in real time
NA
Stock of a product modified into Dolibarr (whatever is reason: shipment processed, order or invoice validated, depending on your Dolibarr setup of the stock change rule, manuel change of stock or inventory) Stock is updated on Magento if product exists also in Magento Real time
TODO
TroubleShooting
Due to a problem in Magento, if you have a large number of product categories, you may experience low performance when counting data to synchronize and making a synchronize. This is how you can fix this:
On magento side, edit the file app/code/core/Mage/Catalog/Model/Category/Api.php to add the line visible into comment
<source lang="php">
    * Convert node to array
    * @return array
       // Only basic category data
       $result = array();
       $result['parent_id']   = $node->getParentId();
       $result['name']        = $node->getName();
       $result['is_active']   = $node->getIsActive();
       $result['position']    = $node->getPosition();
       $result['level']       = $node->getLevel();
/* LDR Add here this new line to add the missing property returned by web service */ $result['updated_at'] = $node->getUpdatedAt();
       $result['children']    = array();
       return $result;
</lang>
