Agenda | |
Numero/ID of module | 2400 |
Developer doc. of module | Module Agenda (developer) |
The Agenda Module is a core Dolibarr module. It is optional and part of the Projects/Collaborative work group in module list.
The Agenda module is used to add a calendar into Dolibarr and manage things like events and rendez-vous.
To know how to setup the module to export Dolibarr agenda events it into the Google agenda, see FAQ Agenda EN.
Definitions
Before to read next chapters, it is important to know the meanings of each terms « Events / Tasks / Journals ». This 3 words often misunderstood are used for different meanings, so it is important to be familiar with them as this words are now used by nearly all ERP. For this, a definition is provided into page Events-Todo-Journal.
The events (event)
In Dolibarr, we also call this events the actions. There is some automatic actions (created automatically by Dolibarr) and manual actions (created explicitly by users). This is the role of Agenda module to manage this kind of events.
Automatic events
We can setup in the Agenda module, which event we want to create automatically into the calendar. Events chosen (invoice creation, order validation...) are then created automatically into the calendar. So such events are business actions that has just been done. They are created with status realized (percentage of accomplishment = 100%). Duration of such events are in general 0 seconds (end date = start date)
Manual events and rendez-vous
You can also create yourself events from Agenda menus. So you create, modify, delete an event (named action into Dolibarr). Such events will have a start date, an end date, an accomplishment percentage, all chosen by user. This properties can also be modified later.
Life cycle / Business rules
Example of use case
UCAG01: | |
Situation | |
Actions |
