Events-Todo-Journal
Software used to manage tasks/plannings/agenda (like Outlook, Lightning, Webcalendar, etc) can manage 3 different notions (normalized in norm RFC2445) that are:
- Event (event in the norm)
- Task (to-do in the norm)
- Journal (journal in the norm)
This 3 definitions are nearly similar but they are different terms and are used for different goals. This page describe the differences between each of them.
See norm at www.ietf.org/rfc/rfc2445.txt
Event and rendez-vous (event)
An event (event in the norm), is something to define an action (a instant action or an action with a long duration that is in past or future).
Events has the folowwing properties:
- A label (In the norm ical: summary)
- A description (In the ical norm: description)
- A start date (In the ical norm: dtstart)
- An end date (In the ical norm: dtend) or a duration (In the ical norm: duration) but it's one or other not both.
- A location, like a meeting-room for example (In the ical norm: location)
- A priority (In the ical norm: priority)
- Transparency (In the ical norm: transp) that says if actors of event are available for this task.
- A status (try, confirmed or canceled), rarely used.
- Other less important informations.
Example of use case: This is same thing that what you can find into an Outlook calendar (tab Calendar), Evolution, Thunderbird/Lightning or into Google calendar. We use the "events" to save rendez-vous for exemple, but you can also use them to save a work to do into a date range if you want.
Into Dolibarr: This concept is managed by Module Agenda. Dolibarr has added a percentage. There is also an option to add a type into Dolibarr.
The tasks (to-do)
A task has the following properties:
- A label (In the ical norm: summary)
- An end date (In the ical norm: due) or a duration (In the ical norm: duration) but one or other not both.
- A percentage of accomplishment (In the ical norm: percent-complete).
- A priority (In the ical norm: priority).
- A status (running, confirmed or canceled)
- Other informations less important.
Example of use case: This is same thing that you can found into Outlook Tasks feature (tab Tasks), Evolution or Thunderbird/Lightning. We use then in most cases to manage projects.
Into Dolibarr: This concept is managed by Module Projects.
The journals (journal)
A journal entry is an information. It has following properties:
- A label
- A description
- An information date
- A location
- A status (draft, confirmed, deleted).
- Other information less important.
Example of use case: Manage a personal diary.
Into Dolibarr: This concept does not exists in any standard module provided with Dolibarr.
