Documentación traductores
Language.png Traducir Dolibarr a otro idioma
Dolibarr se desarrolla por defecto en inglés
Existen 3 métodos para realizar la traducción de Dolibarr:
  1. Automático mediante autotranslator.php
  2. Manualmente mediante la modificación de los archivos de idiomas
  3. Manualmente usando Transifex.com (oficial y recomendado).
Los describimos por orden de preferencia:
Traducción via transifex (recomendada)
Transifex is a web application that provides an online platform for translation projects. It includes teams and discussion tools, translation memory, glossary, proofreading and a lot of other features. It is quite easy to use and all translations can be uploaded or downloaded through the web interface or using their TX client in a terminal. Transifex is an open source project and the "community edition" can be freely downloaded and installed, but we will use the online hosted service.
Create transifex account and choose language
If you want to help translating Dolibarr in your own language, please refer to http://transifex.com/projects/p/dolibarr/ and see if language is already supported. If it exists (many teams are already working for the project), you can ask to join the team and start to translate right away; if there is not a team for your language, you should request a new translation team on Transifex. It can be done directly using transifex.com interface on the website.
Using the web interface (for translators)
If language is already available onto page http://transifex.com/projects/p/dolibarr/, just create an account and follow instruction of transifex web site to translate files.
Note, that this web interface must not be used to translate en_US language that is source. Any change on source language must be done by submiting code change using GitHub Pull Requests.
Using TX command line client (for Dolibarr Category:Yoda team)
This describe how to use Transifex from command line. However, this is reserved to Dolibarr admin users to synchronize Transifex with Dolibarr main sources.
Official documentation
TX Client configuration
First install TX Client. With Debian/Ubuntu/Mint:
apt-get install python-pip
pip install transifex-client
Then you have to initialize your TX environment. This is done by running tx init into dolibarr project root directory.
cd git/dolibarr
tx init
Accept to overwrite config file. Keep default value for Transifex instance, then enter your Transifex login and password.
After this, a .transifexrc has been created into your HOME dir and a generic config file has been created as .tx/config in project's root. So your directory's contents will look like that:
|-- build
|-- build.xml
|-- ChangeLog
|-- COPYING
|-- COPYRIGHT
|-- dev
|-- doc
|-- .gitignore
|-- htdocs
|-- INSTALL
|-- pom.xml
|-- quickbuild.xml
|-- README
|-- README-FR
|-- README.md
|-- robots.txt
|-- scripts
|-- test
`-- .tx
The current config file can be downloaded from https://github.com/Dolibarr/dolibarr/tree/develop/.tx , put it into .tx directory, overwriting the one created by tx init
This project configuration file is used to store the project’s details and the file-to-resource mappings.
That is a sample of what the config file contains:
[main]
host = https://www.transifex.com
lang_map = uz: uz_UZ
[dolibarr.admin]
file_filter = htdocs/langs/<lang>/admin.lang
source_file = htdocs/langs/en_US/admin.lang
source_lang = en_US
type = MOZILLAPROPERTIES
Here is an explanation of the sections and options used in the config file:
[main] section
In this section we have project-wide options, such as the default transifex host for all projects. These can be overriden by each resource, in case it is needed.
[dolibarr.resource]
source_lang: this is the source language of the resource.
source_file: this points to the source file directly.
file_filter: here we hold the expression used to identify translation files under the specific project. not mandatory
trans.<lang>: this is used for translation files that don’t follow a common naming schema and the file expression cannot be used to track them. not mandatory
host: in case the project doesn’t use the default Transifex server as specified in the [main] section, it can override it using this option. not mandatory
TX Client use
Some useful information on tx commands.
tx status
Show status of translations
tx push
Used to push changes from your computer to Transifex server
Additional options for the tx push command are:
-h - Shows the help screen for the command
-l <lang> - Specify which translations you want to push (defaults to all)
-r <resource> - Specify the resource for which you want to push the translations (defaults to all)
-f - Push source files without checking modification times
--skip - Don't stop on errors. Useful when pushing many files concurrently.
-s - Push the source file to the server
-t - Push the translation files to the server
--no-interactive - Don't require user input when forcing a push
tx pull
Used to pull changes from Transifex server to your computer
Additional options for the tx pull command are:
-l <lang> - Specify which translations you want to pull (defaults to all)
-r <resource> - Specify the resource for which you want to pull the translations (defaults to all)
-a - Fetch all translation files from server (even new ones)
-s - Force the fetching of the source file (default: False)
-f - Force download of translations files
--disable-overwrite - By default Transifex will fetch new translations files and replace existing ones. Use this flag if you want to disable this feature.
--minimum_perc=VALUE - Specify the minimum acceptable percentage of a translation in order to download it.
Examples
To pull translation files, you can use:
tx -d pull -l it_IT  # Get italian language only
tx -d pull -a   # Get all languages
To push source files, just type:
tx -d push -t -l it_IT [-r dolibarr.file]   # To push only a specific translation file
tx -d push -s  # To push source file
Other questions on transifex process
This is short questions and answer yuo may also ask about transifex translation process:
1) Is the sync on a regular time interval ?
No. It is done where there is enough translation submited. It is also done on a beta branch just before creating the final release package.
2) Are all the translations synced to git, or only the reviewed translations. Do I need to review before sync is done ?
When a Sync is done, transifex files overwrites files into git, but only if there is at least on record modified for the file. You don't have to make review before sync is done. Making review is above all to know which lines were manually reviewed and wich one were intially translated using a robot.
3) In which Dolibarr releases will translations be available ? Are transifex translations also synced to maintenance releases ?
Sync is always done on develop and/or beta. So transifex changes appear in all version whose branch is created after the transifex change (a sync is always done before creating a new branch). Once a branch is created, then new changes into transifex will be available only for next branch. Reason of this is that transifex is not able to manage branch/versions (not yet).
Traducción totalmente manual (no recomendada)
Para traducir Dolibarr a otro idioma, vaya a la carpeta langs y cree una carpeta llamada con el código de idioma a traducir (Siguiendo el mismo formato de las ya existentes, por ejemplo en_US, fr_FR, es_ES, de_DE, etc...). Deberá copiar los archivos de una carpeta lang ya traducida (por ejemplo en_US/main.lang ó fr_FR/bills.lang), y pegarlas en la carpeta del nuevo idioma que acabamos de crear y empezaremos a traducir el contenido de estos archivos.
Estos ficheros están constituidos de la siguiente manera:
Code1=Frase a traducir 1
Code2=Frase a traducir  2
Coden=Frase a traducir  n
Solamente las frases a la derecha del = se deben traducir, el código debe permanecer sin cambios. Es posible traducir los archivos uno por uno, sin tener que traducirlos todos a la vez. Si un archivo no se ha traducido en el nuevo idioma, Dolibarr utilizará el Inglés.
Para tener una variable de cadena para el idioma en el código PHP, todo lo que necesita hacer es cargar el archivo de idioma y utilizar el método para recuperar la variable traducida. Esto se puede hacer de la siguiente manera:
$langs->load("nombredelarchivo"); // o $langs->load("nombredelarchivo@mimodulo") si miarchivo.lang se encuentra en el directorio htdocs/mimodulo/langs/xx_XX
print $langs->trans("CodeX")
Y una entrada del tipo
CodeX=Phrase X
debe de ser añadida a los ficheros .lang
Traducción automática mediante la utilidad autotranslator.php (no recomendada)
  • SO del traductor: Cualquiera
  • Utilidad: autotranslator.php viene con Dolibarr, se encuentra en la carpeta dev/translation.
Para traducir o actualizar todos los archivos en un nuevo idioma, símplemente ejecute el script:
php autotranslator.php lang_code_source lang_code_target GOOGLEAPIKEY
Por ejemplo:
php autotranslator.php en_US pt_PT GOOGLEAPIKEY
para realizar la traducción al portugés (pt_PT) utilizando el inglés (en_US) como origen.
Todos los ficheros no existentes serán creados, y los existentes se actualizarán con las cadenas inexistentes. Las cadenas ya traducidas anteriormente se conservarán tal cual. La utilidad utiliza el servicio de traducción de Google para encontrar el valor traducido de una cadena. Su PHP debe de tener permisios de escritura en la carpeta htdocs/langs y disponer de las funciones de la extensión curl disponibles.
Language.png Difusión o inegras su idioma
Lo mejor que puede hacer, después de realizar una traducción, es incluirla incluye en la versión oficial de Dolibarr.
Si usted ha completado archivos .lang existentes en Dolibarr de forma incompleta o si ha creado nuevos archivos .lang para un nuevo idioma, puede :
  • Incluir sus cambios o archivos en la versión oficial de Dolibarr. Es posible, si sabe usar un sistema GIT. Para ello cree una cuenta en https://github.com/Dolibarr/dolibarr, haga un fork del proyecto Dolibarr, haga sus cambios y mande un Pull Request.
  • o envíe sus archivos por e-mail en un adjunto a la lista inglesa: dolibarr-dev@nongnu.org (Inscripción en https://savannah.nongnu.org/mail/?group=dolibarr). Un desarrollador lo integrará por usted.
Nota: Hay un idoma principale, que siempre están completos:
  • El inglés (ficheros .lang de la carpeta lang/en_US)
Puede utilizar indistintamente tanto uno como el otro (el que prefiera) como referencia ya que los dos están actualizados. Todos los demás archivos de idioma son susceptibles de estar incompletos.
Language.png Traducción del wiki
El wiki se mantiene en 3 idiomas: Inglés, Francés y Español. Si desea mejorar la documentación en uno de estos idiomas, simplemente debe de crear una cuenta en este wiki. Entonces, podrá modificar una traducción incorrecta o traducir una página a la espera de traducción. La lista de estas páginas se encuentra disponible en la página Category:Page_waiting_for_translation.
