Module Timesheet
Revision as of 15:02, 28 September 2016 by Delcroip (talk | contribs)
<keywords content="timesheet, Dolibarr, interface, project, task, report, approval" />
Module name timesheet
Editor / Editeur delcroip
Prerequisites / Prérequis projects
Last update date / Date mise à jour fiche / Fecha última actualización 2016-09-28
Note / Nota Latest Module version: 1.5.1
- Timesheet interface for all the user task per week - Generate report on user and on project per month - whitelist to show only some project/task (if no whitelist define all task are showed) - Approval of the timesheets per the N+1
Change log from 1.5 - Support dolibarr 4.0.1 - Hidden option to join file to timesheets via the setting TIMESHEET_ADD_DOCS
Change log from 1.4.3: - Timesheet approval by N+1, - Reminder (email) for to be approved timesheet possible through dolibarr planned tasks - admin wiew for the Approval (change a approval status outside the normal approval flow) - Home box with the pending timesheet to be approved - Blocking some weekdays (e.g week ends) - Holiday showed in the timesheet - Holiday time can be included in the timesheet totals - Typo correction for French. - Posibility to add a note - Compatible with dolibarr 3.9.2
Change log from 1.4.1:
- Correction of the Spanish language (thanks to vinclar) - Possible to deactivate the dolibarr Ajax for the dropdown list for the setup page (in case of issue to add whitelist) - Keep the whitlistmode after submit / go to date / next / previsous week
Change log from 1.4: - Bugfix for the tasktime date in the project page - Link to have the different whitelist behaviour (black list, and none) - Spanish language (google trad) - Typo correction for French - Support the print mode for timesheet & the report - Show the project open to everyone on the new whitelist page
Change log from 1.3.7: - layout improvement: timesheet, setup page, reports - whitelist to show only some project/task - taslk column customisation - new task column: company, parent task - new report option: report all, export friendly layout - user report available for the N-2, N-3
Change log from 1.3.6: - compatible avec dolibarr 3.7 - Change log from 1.3.3: - Works with PHP<=5.3 - Possibility to remove the 0:00 - Color code for already filled tasktime / new tasktime and error - Bux fixes in the report - Better date dialog - N+1 is able to check the user report of his N's
