Table llx menu
Revision as of 15:42, 31 August 2016 by Eldy (talk | contribs)
Content/Contenu/Contenido
  Contains the menus. See also page Menus_system
  Contient les menus. Voir aussi la page Système_de_menus
  Contiene los menús.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
menu_handler varchar(16) NO UNI Menu handler name
entity int(11) NO 1 See page Field Multi company id. (llx_entity->rowid)
module varchar(64) YES NULL module name if record is added by a module
type varchar(4) NO MUL type of menu (top or left)
mainmenu varchar(100) NO Name family/module (home, companies, etc.)
fk_menu int(11) NO UNI 0 or Id of parent menu line
position int(11) NO sort order of entry
url varchar(255) NO UNI relative (or absolute) url to go
target varchar(100) YES NULL target of url link
titre varchar(255) NO key for menu translation
langs varchar(100) YES NULL lang file to load for translation
level smallint YES NULL only used by auguria menu. Do not use
leftmenu varchar(1) YES 1 Not used (deprecated)
perms varchar(255) YES NULL condition to show enabled or disabled (grayed menu) if field enabled is 1
enabled varchar(255) YES 1 condition to show or hide (completely hidden)
usertype int(11) NO 0 0 if menu for all users, 1 for external only, 2 for internal only
tms timestamp NO Current date Date of last modification. See page Field Tms.
Keys
Key Type Fields
PRIMARY PRIMARY rowid
idx_menu_uk_menu UNIQUE menu_handler,fk_menu,url,entity
idx_menu_menuhandler_type MULTIPLE menu_handler,type
