Module Expense Reports
Expense Reports
Numero/ID of module 75
Developer doc. of module Module Expense Reports (developer)
With this module, employees can report (create, edit, delete) expense reports. Their supervisor can validate it and a book keeper can set them as paid. Documents (scan of expense reports) can also be attached to each demand.
Life cycle / Business rules
An expense report follow the following life cycle:
    /                       /---------------------->---------> E-Canceled
A-Draft --> B-Validated/Waiting approval --> C-Approved -----> D1-Enter payment ----> D2-Payed
   |                        ---------------> D-Denied <--|
  • A) Draft status means the expense report does not exists yet. Edition is not yet finished.
  • B) Status validated means also "waiting for approval". When you validate an expense report, an email is sent to the supervisor.
  • C) A supervisor with permission "Approve expense reports" can approve the expense report.
  • D) A user with permission "Set Payed" can classify the expense report to *Payed*.
Create an expense report
Creation of an invoice need to go on card of a third party, on tab "Customer" (this require your third party has customer nature).
If Module Workflow and Module Commercial Proposals enabled, you can also have a draft customer orders automatically created once a proposal is closed (You must set this into setup of Module Workflow.
Validate an expense report
To validate an expense report, go on its card (you can find order from menu HR - Expense report - List).
Then click on button *Validate and submit for approval*. An email will be sent to supervisor of user (or another user if expense report creator ask a validation by another approver).
Modify an expense report
To modify an expense report, go on its card (you can find order from menu HR - Expense report - List).
You can edit it if expense report has draft status. If not click on action button Back to draft.
Pay an expense report
Only users with permission "Pay expense reports" can approve set an expense report to status "Payed".
To set an expense report to "Payed", go on its card (you can find order from menu HR - Expense report - List).
Then click on *Set as payed*
Delete an expense report
To delete an expense report, go on its card (you can find order from menu HR - Expense report - List .
Then click on action button Delete.
Warning, a deleted expense report is definitively removed with no way to restore it.
Examples of use cases
UCCU01:
Situation
Actions
