Module Stocks En
Stock | |
Numéro/ID du module | 52 |
Doc développeur du module | Module Stock (developer) |
Stock management module can save status for stocks of products into warehouses, edit amounts of products you have and correct them.
The setup page allows you to choose, among four options, when the stock is automatically incremented or decreased (depending on events in orders or invoices cycle of life).
Definition
- Physical stock is the stock that is stored in Dolibarr (amount of products into warehouses database)
- Virtual stock is the physical stock - the number of products ordered by customers (order with status validated) + the number of ordered done to suppliers (order with status "sent to the supplier").
Create a warehouse
The creation of a warehouse is the mandatory first step for stock management. You can create a warehouse on the Products/Services tab, clicking Stocks on the left menu and then New warehouse stock. The only required information is a reference code and a warehouse name, the other fields are optional. You must then set whether the warehouse is running or not (opened / closed). A closed warehouse cannot be used by the other Dolibarr functions. This is a good way to prepare a warehouse (by filling it up) before you turn it on, or to temporarily block during an inventory.
Allocate product stocks
Long but necessary step, it is then, for each product, to define the stock amount, in each warehouse.
- This has to be done from the stock tab on the page of the product, which can be found on the products section of the left menu.
- You can also do this from the stock tab on the page of the warehouse.
Automatic stock updates
Depending on the option chosen in the module's configuration, the available stock amount is updated either at the time of the order, at the time of shipment, at the time of invoice, etc.. A movement of stock is then registered according to the chosen increase/decrease stock option.
Manual stock updates
If you wish to make adjustments to the existing stock amounts (because of internal production, theft, loss, aging, ...), you can do it directly via the stock tab on the page of the product. Use the label field to specify the reason for the change, or to add miscellaneous information.
Warehouse status
It is possible to obtain a detailed list of products and movements in a warehouse via a click on the name of the store from the list of warehouses.
Removal strategory
When using stock decrease on shipments, a removal strategy is a removal rule to decide which lot/serial or from which warehouse you take a product when you are doing a shipment.
- FIFO: First in, first out
- LIFO: Last in, last out
- FEFO: First expiry, first out
Currently, Dolibarr does not suggest any warehouse, nor product lot in priority when you want to ship a product. You choose, from the interface which product/lot quantity, from wich warehouse you use. So the removal strategy is a manual choice of user. You can decide to choose according to FIFO, LIFO, or FEFO rule, but you must choose yourself and can change at each shipment.
In a future, a removal strategy may be implement so application will use default value to suggest you lot/serial/warehouse/qty to match a fixed removal strategy rule.
Stock valuation
With Dolibarr, you can get a valuation of stock in two ways:
- Standard valuation: Current price of product * qty in stock
- Avergae Weight Price (AWP): AWP of product * qty in stock
Examples of use cases
UCMS01: | |
Situation | |
Actions |
