Module ECommerce NG (Magento)
<keywords content="Magento, Dolibarr, synchro, synch, interface" />
| Module name | Magento |
| Editor / Editeur | Teclib - www.teclib.com |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2016-05-27 |
| Note / Nota |
Integrates a Magento - Dolibarr synchronyzation. It is a module to be installed in Dolibarr. Access to Magento is done by dolibarr using default Magento's WebServices.
Magento
We suppose you have a Magento already available. If not, this is quick steps to install it:
- Go on www.magento.com to download last version.
- Unzip package on a magento root directory
- Create an empty database on your mysql/mariadb server
- Create a virtual host on your apache server to point to this magento directory and call this url. Use external url for your localhost. A wizard will start to initialize Magento. Note: If you need to work locally only, with an internal URL, you must known than with magento < 2, the name of the virtual host can't be "localhost". But you can edit your /etc/hosts file to add an entry like magento.local on ip 127.0.0.1 and use this (this suppose you want to work locally only).
Note: To reset password of an admin user: UPDATE admin_user SET password = MD5('NEWPASSWORD') WHERE username = 'adminlogin';
Dolibarr module
From the application
Manually
unzip modulefile.zip
Setup on Magento side
- Create first a Webservice SOAP/XML RPC role from admin interface System - Webservices - SOAP/XML RPC Roles, for example role soaprole. Grant this role Access to *All resources*.
- Create a Webservice SOAP/XML RPC account from admin interface System - Webservices - SOAP/XML RPC User, for example account soapuser. Remember the password you used into field API key during user creation. Set this user to the role you created at previous step. Note: A user with no role set is useless and Dolibarr won't be able to login with it.
- The parameter System - Configuration - Services - Maento Core API - WS/I Compliant can be set to true or false.
Setup on Dolibarr side
- Saisir l'URL des services SOAP Magento.
- Renseigner le login et l'API key créé à l'étape précédente dans Magento (soapuser).
- Choisir la catégorie à utiliser pour marquer les tiers issus de Magento ou ceux à pousser sur Magento. Le tiers assigné à cette catégorie seront poussés en temps réel sur Magento.
- Choisir la catégorie mère dans laquelle sera créée les catégories produits issues de Magento. Les produits créés ou modifiés qui sont assignés à une catégorie ou sous-catégorie de cette dernière seront poussés sur Magento en temps réel.
Synchronize from Magento to Dolibarr
| Action into Magento | Effect into Dolibarr | When | Note |
| Categories created/modified into Magento | Created into Dolibarr as sub-categories of the parent category used for Mangeto categories (defined into module setup) | Manual click on "Magento to Dolibarr sync" button | Table llx_ecommerce_category is updated to store link of dolibarr id and remote magento id |
| Products created/modified into Magento | Created into Dolibarr with categories | Manual click on "Magento to Dolibarr sync" button | Table llx_ecommerce_product is updated to store link of dolibarr id and remote magento id |
| Thirdparties and contact/addresses created/modified into Magento | Created into Dolibarr | Manual click on "Magento to Dolibarr sync" button | Table llx_ecommerce_societe and llx_ecommerce_socpeople is updated to store link of dolibarr id and remote magento id |
| Orders created/modified into Magento | Created into Dolibarr | Manual click on "Magento to Dolibarr sync" button | Table llx_ecommerce_commande is updated to store link of dolibarr id and remote magento id |
| Shipment created/modified in Magento | Creating a shipment in Magento is changing Magento status of the Order from "pending" to "processing". Because it is changing status of order, see case "Order created/modified into Magento". The shipment is not downloaded into Dolibarr, only status of Dolibarr Order will be changed like is the Magento order | You must choose if you manage shipment on Dolibarr or Magento. | |
| Invoices created/modified into Magento | Created into Dolibarr | Manual click on "Magento to Dolibarr sync" button | Table llx_ecommerce_facture is updated to store link of dolibarr id and remote magento id TODO Priority 1 |
TODO In a future version, the "Magento to Dolibarr sync" button could be replaced with a scheduled job/script to launch it automaticaly every hour for example.
Synchronize from Dolibarr to Magento
| Action into Dolibarr | Effect into Magento | When | Note |
| Categories created into Dolibarr | No update is currently done on Magento. In a future version, creation will be done into Magento if category is inside the parent category for Magento, defined into module setup | No creation/update is currently done on Magento. In a future version, sync will be in real time | TODO |
| Categories modified into Dolibarr | No update is currently done on Magento. In a future version, update will be done into Magento if category is linked to Magento (category was created by a "Magento to Dolibarr sync") | No creation/update is currently done on Magento. In a future version, sync will be in real time | TODO |
| Products created into Dolibarr | None. In a future, creation will be done into Magento if product has a category inside tree of Magento categories | No creation is currently done on Magento. In a future version, sync will be in real time | TODO |
| Products modified into Dolibarr | Update into Magento is done if product is linked to Magento (product was created by a "Magento to Dolibarr sync") | Real time | |
| Thirdparties created | None. In a future version, creation will be done into Magento if thirdparty has the category of Magento thirdparties (defined into setup) | No creation is currently done on Magento. In a future version, sync will be in real time | TODO |
| Thirdparties modified into Dolibarr | Update into Magento is done if thirdparty is linked to Magento (thirdparty was created by a "Magento to Dolibarr sync") | Real time | |
| Contact/addresses created into Dolibarr | None. In a future version, creation will be done into Magento if thirdparty has the category of Magento thirdparties (defined into setup) | No creation is currently done on Magento. In a future version, sync will be in real time | TODO |
| Contact/addresses modified into Dolibarr | Update into Magento is done if contact/address is linked to Magento (contact/address was created by a "Magento to Dolibarr sync") | Real time | |
| Orders created into Dolibarr | None | Orders created directly into backoffice does not need to appear into ecommerce. See next line for Orders update. | |
| Orders modified into Dolibarr | Order will be updated into Magento if order is linked to Magento (order was created by a "Magento to Dolibarr sync") | No update is currently done on Magento. In a future version, sync will be in real time | TODO |
| Shipments created/modified into Dolibarr | Shipment will be created/modified into Magento if source order of shipment was created by a "Magento to Dolibarr sync" | Real time | TODO Priority 1 |
| Invoice created/modified into Dolibarr | None. In a future, invoice will be created/modified into Magento if source order was coming from Magento | No creation/update is currently done on Magento. In a future version, sync will be in real time | TODO |
| Stock of a product modified into Dolibarr (whatever is reason: shipment processed, order or invoice validated, depending on your Dolibarr setup of the stock change rule, manuel change of stock or inventory) | Stock is updated on Magento if product exists also in Magento | No creation is currently done on Magento. In a future version, sync will be in real time | TODO Priority 1 |
