Module ECommerce NG (Magento)
<keywords content="Magento, Dolibarr, synchro, synch, interface" />
Module name Magento
Last update date / Date mise à jour fiche / Fecha última actualización 2016-04-8
Intègre une synchronisation Magento - Dolibarr. Il s'agit d'un module qui s'installe sur Dolibarr. L'accès à Magento est fait par Dolibarr en utilisant les Web services par défaut de Magento.
From the application
Manually
unzip modulefile.zip
Setup on Magento side
  • Créer un compte Webservice SOAP/XML RPC depuis l'interface admin System - Webservices - SOAP/XML RPC, par exemple le compte soapuser.
  • Mettre un mot de passe dans le champ API key.
Setup on Dolibarr side
File:Config Magento.png
Synchronize from Magento to Dolibarr
Action into Magento Effect into Dolibarr When Note
Categories created/modified into Magento Created into Dolibarr as sub-categories of the parent category used for Mangeto categories (defined into module setup) Manual click on "Magento to Dolibarr sync" button Table llx_ecommerce_category is updated to store link of dolibarr id and remote magento id
Products created/modified into Magento Created into Dolibarr with categories Manual click on "Magento to Dolibarr sync" button Table llx_ecommerce_product is updated to store link of dolibarr id and remote magento id
Thirdparties and contact/addresses created/modified into Magento Created into Dolibarr Manual click on "Magento to Dolibarr sync" button Table llx_ecommerce_societe and llx_ecommerce_socpeople is updated to store link of dolibarr id and remote magento id
Orders created/modified into Magento Created into Dolibarr Manual click on "Magento to Dolibarr sync" button Table llx_ecommerce_commande is updated to store link of dolibarr id and remote magento id
Shipment created/modified in Magento Creating a shipment in Magento is changing status of the Order from "pending" to "processing". Because it is changing status of order, see case "Order created/modified into Magento". The shipment is not downloaded into Dolibarr, only status of Order is changed It is recommended to manage shipments on ERP side.
Invoices created/modified into Magento Created into Dolibarr Manual click on "Magento to Dolibarr sync" button Table llx_ecommerce_facture is updated to store link of dolibarr id and remote magento id TODO
TODO In a future version, the "Magento to Dolibarr sync" button could be replaced with a scheduled job/script to launch it automaticaly every hour for example.
Synchronize from Dolibarr to Magento
Action into Dolibarr Effect into Magento When Note
Categories created/modified into Dolibarr No update is currently done on Magento. In a future version, creation/update into Magento if category is inside the parent category for Magento, defined into module setup Real time
Products created/modified into Dolibarr No update is currently done on Magento. In a future version, creation/update into Magento will be done if product has a category inside parent category of Magento product (defined into setup too) No update is currently done on Magento. In a future version, sync will be in real time
Thirdparties created/modified into Dolibarr No update is currently done on Magento. In a future version, creation/update into Magento will be done if thirdparty has the category of Magento thirdparties (defined into setup) No update is currently done on Magento. In a future version, sync will be in real time
Contact/addresses created/modified into Dolibarr None No update done on Magento
Orders created into Dolibarr None Orders created directly into backoffice does not need to appear into ecommerce. See next line for Orders update.
Orders modified into Dolibarr Order will be updated into Magento if order was created by a "Magento to Dolibarr sync" Real time TODO
Shipments created/modified into Dolibarr Shipment will be created/modified into Magento if source order of shipment was created by a "Magento to Dolibarr sync" Real time TODO
Invoice created/modified into Dolibarr None. In a future, invoice will be created/modified into Magento if source order was coming from Magento Real time TODO
Stock of a product modified into Dolibarr (because of a shipment processed or because of an order or invoice validation, depending on your Dolibarr setup of the stock change rule, or because of a manuel change of stock or an inventory) Stock is updated on Magento if product exists also in Magento Real time TODO
