Module ECommerce NG (Magento) FR
<keywords content="Magento, Dolibarr, synchro, synchronisation, interface" />
Module name Magento
Last update date / Date mise à jour fiche / Fecha última actualización 2016-04-1
Intègre une synchronisation Magento - Dolibarr. Il s'agit d'un module qui s'installe sur Dolibarr. L'accès à Magento est fait par Dolibarr en utilisant les Web services par défaut de Magento.
Depuis l'application
Manuellement
unzip fichiermodule.zip
Configuration côté Magento
  • Créer un compte Webservice SOAP/XML RPC depuis l'interface admin System - Webservices - SOAP/XML RPC, par exemple le compte soapuser.
  • Mettre un mot de passe dans le champ API key.
Configuration côté Dolibarr
File:Config Magento.png
Synchronisation de Magento vers Dolibarr
  • Categories created/modified into Magento => Created into Dolibarr as sub-categories of the parent category used for Mangeto categories (defined into module setup) (Table llx_ecommerce_category is mainained to keep link of dolibarr id and remote magento id)
  • Products created/modified into Magento => Created into Dolibarr with categories (Table llx_ecommerce_product is mainained to keep link of dolibarr id and remote magento id)
  • Thirdparties and contact/addresses created/modified into Magento => Created into Dolibarr (Table llx_ecommerce_societe and llx_ecommerce_socpeople is mainained to keep link of dolibarr id and remote magento id)
  • Orders created/modified into Magento => Created into Dolibarr (Table llx_ecommerce_commande is mainained to keep link of dolibarr id and remote magento id)
  • Creating a shipment in Magento is changing status of Order from "pending" to "processing". Because it is changing status or order, it is synchronized
  • Invoices created/modified into Magento => TODO
TODO Add job/script to automate this.
Synchronisation de Dolibarr vers Magento
Synchronizing is done in real time:
  • Categories created/modified into Dolibarr => Created into Magento if category is inside the parent category defined into setup.
  • Products created/modified into Dolibarr => Created into Magento if product has a category inside parent category of Magento product (defined into setup too).
  • Thirdparties and contact/addresses into Dolibarr are not synchronized to Magento.
  • Orders created into Dolibarr => They are not pushed to Magento. Orders updates are done on Magento only if order was created by a Magento to Dolibarr synchronization.
  • Shipments created into Dolibarr => They are not pushed to Magento except if source order was coming from Magento.
  • Invoice created into Dolibarr => They are not pushed to Magento except if source order was coming from Magento.
  • Stocks
