Module ECommerce NG (Magento) FR
<keywords content="Magento, Dolibarr, synchro, synchronisation, interface" />
Module name | Magento |
Editor / Editeur | Teclib - www.teclib.com |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2016-03-31 |
Note / Nota |
Intègre une synchronisation Magento - Dolibarr. Il s'agit d'un module qui s'installe sur Dolibarr. L'accès à Magento est fait par Dolibarr en utilisant les Web services par défaut de Magento.
Depuis l'application
Manuellement
unzip fichiermodule.zip
Configuration côté Magento
Il n'y a rien de particulier à faire.
Configuration côté Dolibarr
Synchronisation de Magento vers Dolibarr
Synchronizing can done manually from page Synchronizing Site Magento:
- Categories created/modified into Magento => Created into Dolibarr as sub-categories of the parent category used for Mangeto categories (defined into module setup) (Table llx_ecommerce_category is mainained to keep link of dolibarr id and remote magento id)
- Products created/modified into Magento => Created into Dolibarr with categories (Table llx_ecommerce_product is mainained to keep link of dolibarr id and remote magento id)
- Thirdparties and contact/addresses created/modified into Magento => Created into Dolibarr (Table llx_ecommerce_societe and llx_ecommerce_socpeople is mainained to keep link of dolibarr id and remote magento id)
- Orders created/modified into Magento => Created into Dolibarr (Table llx_ecommerce_commande is mainained to keep link of dolibarr id and remote magento id)
- Creating a shipment in Magento is changing status of Order from "pending" to "processing". Because it is changing status or order, it is synchronized
- Invoices created/modified into Magento => TODO
TODO Add job/script to automate this.
Synchronisation de Dolibarr vers Magento
Synchronizing is done in real time:
