Module MultiCompany
Module name | |
Editor / Editeur | Regis Houssin - http://www.dolistore.com/ |
Prerequisites / Prérequis |
Dolibarr min version: 3.0.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2016-03-25 |
Note / Nota |
With this module, Dolibarr is able to manage several instances with only one installation (one unzipping and one database)
