Module Ultimateline EN
Module name | UltimateLine |
Editor / Editeur | Atoo.Net - http://www.atoo-net.com |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2016-01-24 |
Note / Nota |
Allows automatic addition of final lines to proposals, orders or invoices when adding or editing a line. It can handle multiple lines to be added, depending on products or services identified together or independently. It is particularly suitable for automated calculation and adding invoice lines such as carbon taxes, green tax, special discounts ...
Prerequisites
Dolibarr 3.5.x, 3.6.x, 3.7.x, 3.8.x
- Download the archive file of module (.zip file) from web site DoliStore.com
- Uncompress the zip file, for example with command : unzip modulefile.zip
The correct location of the module must be of the type : htdocs/custom/ultimateline
Module is then available and can be activated.
Settings
Define a service as a final line
Configuration page dedicated to module:
In the configuration page dedicated to module:
- Select a service to use as a final line service by choosing from the drop down list of the services previously created.
- Choose the type of action associated (rate applied on the price in% or fixed amount added to the price.
- Fill in the field "Value to apply" by a numerical value ... then click the Assign button..
- Now select your final line service that appears in the drop down list of the next block. Click the "Display" button
- You can now select from the list of combinable products, for which this rule will apply.
- Pass selected products from one column to another using the little arrows, and click apply..
- To see online training on Youtube:[[1]]
Utilization
- Warning! : If in the preparation of a document you delete a product line whose amount is already recognized in the final line ... it will also delete the final line for it to recalculate. This will naturally if you add a new product line, or you will have to edit and re-register the already filled product lines.
Ultimatepdf est un module suivi sur le Git de Framasoft : https://git.framasoft.org/grandoc/ultimateline
