Versions
- Dolibarr must work on:
- All OS (Windows, Linux, MACOS...)
- PHP 7.1.0+ (Must work with no need of complementary PHP module, except module to PHP module to access database).
- Mysql 5.1+
Copyright Norms
- All PHP files must start with a header that looks like
<?php
* Licence information
PHP Norms
PHP
- Dolibarr is written with PHP and supports all PHP version higher than 7.1.0+. All files must end with extension .php
- Usage of PHP superglobals variables must use dedicated operators $_COOKIES, $_SERVER, $_ENV but use Dolibarr function GETPOST() to get content of $_GET or $_POST..
Other operators ($HTTP_SERVER_GET, ...) are now deprecated inside PHP, so they must no more be used. Like that code will work also if option register_long_arrays is set to off. Moreover, the code must work when PHP option register_globals is off (recommended by PHP). It must work the same way when the option register_globals is on (by default on a lot of installations).
- Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"]. Also, Dolibarr framework sanitizes content of $_SERVER["PHP_SELF"] variable (into main.inc.php file, so before any business code).
- When several variables must be initialized with same value, you must use several instructions (separated with ;)
$var1=1;$var2=1;$var3=1;
instead of
$var1=$var2=$var3=1;
that is slower.
- String must be rounded by simple or double quote and a variable within the string must be out side of the quote.
print 'My text show my '.$variable.' !';
- Comments must use the C syntax, ie a double slash for a comment on one line and a slash-star to open a bloc for several lines
/* Bloc of comment
* End of bloc
for ($i = 1 , $i < 2 ; $i++)
// comment on one line
print $i;
- Functions must return a value equal or higher than 0 if successful and strictly lower than 0 if error.
- No dead code (code never used) into Dolibarr core code (code used by external modules only must be included within the external modules).
- Use "include_once" for anything with functions or class definitions in it (like *.class.php and *.lib.php files), use "include" for template-style php with files containing common part of HTML and PHP code (like *.inc.php and *.tpl.php files).
- Coding style to use is the PSR-2 (https://github.com/php-fig/fig-standards/blob/master/accepted/PSR-2-coding-style-guide.md). Only rules "MUST" are currently required. So note however the exceptions:
- Length of line: PSR-2 mention we can go up to 120 characters on same line, this is a soft limit. It is better to have long lines instead of long page with code content that is just data declaration and does not contain any logic. However, we introduced a hard limit of 1000 characters (having line larger that this will return errors on Continuous Integration tests).
- Tabs are allowed: The other exception is that we don't replace the tabs with spaces. Using tabs is more convenient for most editors/developers. Also using spaces breaks some auto-format features (like Eclipse autoformat feature on some Eclipse version).
- Note 1: The following rule are very important to follow:
- Files must be saved with Unix format (LF) and not Windows (CR/LF). Unix format is compatible on all OS such as Unix like, Windows, Mac, but the Windows text file format may not work on some PHP under Unix.
- Smart tags PHP are not used. PHP code section must start with <?php
- Note 2: You can use the file dev/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
- Note 3: You may note that current code is not yet compliant with the PSR-2. The reason is that we must "now" follow the "MUST" rules of PSR-2, but it wasn't in the past. So feel free to change coding style to match new rules if you find such cases.
Some properties of classes are found in different classes. To avoid having different names, we will use the following names:
- date_creation: date of creation
- user_creation: object User creating object
- fk_user_creation: id of user creating object
- date_modification: date of last modification
- user_modification: object User performing the modification
- fk_user_modification: id of user doing modification
- date_validation: date validation
- user_validation: object User
- fk_user_validation: id of user making validation
SQL rules
Table and fields structures
- Structure of tables.
- rowid integer for id - tms timestamp that will contain date of last modification (the database manages this field automatically, no need to manage it by the code, just create the field) - import_key that will contains the import code YYYYMMDDHHMMSS if you make mass import.
Eventualy
- datec timestamp that is the creation date - fk_user_author integer that is the id of user making creation - fk_user_mod integer that is the id of user making change - fk_soc integer that is the ID of the Thirdparty
Note field:
- note_private text for private comment of the object - note_pubic text for public comment of the object
or
- Type of fields:
Well, to be compatible with any accuracy required by any country on amounts, and with any database syntax, we will use the following type into database:
- integer for an any of foreign key - double(24,8) for any amount - double(6,3) for any vat rate - real for a quantity - varchar for a string (also if length is 1, the type char is more and more deprecated) - timestamp for a field date+time that is automatically updated - datetime for a field date+time - date for a field date
- All tables has a prefix to avoid name conflicts with other projects. In current version this prefix is fixed ans can't be modified. Its value is llx_. In a future version this value should be modified during installation process.
Primary keys
Foreign keys
Alternative keys
Index performance
DDL file format
- The first file defines the table and its fields. The file name contains the table name, e.g. like this: llx_mytable.sql
- The second file defines all foreign keys, performance indexes or other constraints and the file name will be like: llx_mytable.key.sql
create table llx_mytable
field_one integer,
field_two integer NOT NULL,
fk_field integer,
field_date datetime,
fk_user_mod integer NOT NULL, -- Last updater, foreign key of llx_user
import_key varchar(14) -- Use by import process
)type=innodb;
SQL Coding rules
- Alias usage/Fields naming
- Using SELECT * is forbidden ! When using SELECT you must define complete list of fields to get. This avoids confusion. Example:
- Into SQL requests, you must quote fields except the fields that contain amounts which must be stored as double or real type. Quotes on numbers may result in saving as a different value. For example 412.62 in an insert will be saved as value 412.61999512 into database (due to implicit conversion string to numeric) if the target field has type double(24,8). Only PHP see value 412.61999512. Other tools will see 412.62 giving a sense that there is no problem. But it's PHP that has the good vision. There is really a wrong value into database. By removing quotes on numbers, no problem occurs.
Example:
Good: INSERT INTO table_1 (field_txt, field_num) VALUES ('txt', 412.62)
Bad: INSERT INTO table_1 (field_txt, field_num) VALUES ('txt', '412.62')
Note, problem of float numbers is same problem on all langauges and not only when inserting data into database. It occurs also with any language when you work on "real" numbers, so numbers must be, as soon as they are affected, cleaned with function price2num with second parameter defined to : 'MU' (for unit prices), 'MT' (for total prices) or 'MS' (otherwise) depending on usage of number. (see function documentation)
- Functions NOW, SYSDATE or DATEDIFF are forbidden inside SQL requests. If you must use the current date into a field, value must come from the PHP and not from the database engine. This is for better portability of code and correct management of TimeZone.
For example, don't do:
but do:
but do:
Mysql specificities
- Tables must be declared with format InnoDB.
- Dolibarr must work even if Mysql option strict is active.
To activate it (recommended when developing on Dolibarr), add the following line into the config file of your Mysql server (my.cnf or my.ini)
PostgreSQL specificities
MySQL Syntax:
PgSQL Syntax:
There is no native SQL request "update from" in dolibarr core. But in your module you should do :
} else {
HTML norms
Syntax rules
- HTML used must be HTML compliant and not XHTML. All attributes of HTML tags must be in lower case and quoted with ".
- Links href must be absolute and use the function dol_buildpath() to get absolute path from a relative path and img tag must be build using function img_picto().
For example:
- HTML tables must have columns with no forced width, except for columns that contains data we know the length. For example, a column with a picto only can be forced to with="20px".
- Javascript/ajax code and call to javascript files into php pages must be avoided. However, if you need to include javascript code, you must add a condition on "$conf->use_javascript_ajax"
... // php code generating javascript here
- Popup windows must not be used, except for tooltips (and must have a condition as explained before).
- External scripts must be written in Perl if they can't be written in PHP. Usage of another language is not forbidden but must be argued before in the development mailing-list.
External templating framework ?
There is ton of frameworks to provide a templating language of an HTML page. The best and faster is just called "PHP", and because Dolibarr already depends on PHP, there is no need for depend on a third languages.
All templating frameworks are just preprocessor, BEFORE PHP. It can't be faster than PHP alone. When we say "speed, when using cache of templating framework, is increase", it is in fact the overtime spent by the framework that is reduced by cache, not the speed of processing PHP file. We should says "any templating framework has an overload over PHP, the cache of framework, just reduce the slowing effect of using it", but not "the speed is increased, it is always increased".
Above all, having a templating system is completely possible by doing a ".tpl.php" file that dos not contains any logic code, but only HTML and echo. We get same result (but faster and easier to develop because it does not need to do all the setXXX) before calling each template. All variables (known by code that include the template) are automaticaly known into a PHP template page. No risk to forget a set, and a lot of line of codes reduced, a lot of time saved.
Also, keeping a 100% isolation between code and HTML output is interesting in only 1 situation: When teams building design is complety different than team building logic code, AND if you build not too sophisticated pages, AND with no need of too many Ajax features (this need to know how code works). And this situation is surely not the Dolibarr future (team will often be same, Ajax will be more and more present, event if I hope not too much, and screens are more and more dependent of dynamic or contextual events, difficult to have with a template without transforming the template into a page with high level of code).
There is a ton of other reasons to not use an external templating system and all arguments to use them are the best argument to use PHP as our templating system.
Skeleton code
- 1 that serves as an example of the module description: myModule.class.php
- 1 that serves as an example of code for creating a new class: skeleton_class.class.php
- 1 that serves as an example of code for creating a new page: skeleton_page.php
- 1 that serves as an example of code for creating a script for executing command lines: skeleton_script.php
Dates and Timezones
- A date into memory must always be stored with Timestamp GMT format.
- A date stored into database, is the GMT Timestamp of date submitted into the request usng the PHP server timezone. This does not apply to date update automatically by database (fields tms into database).
For exemple le 1st january 1970, 3 hour at Paris (TZ=+1) = 2 hour at Greenwitch (TZ=0) will be stored into memory with value 7200 and will be submitted into a SQL request to database with the string '19700101030000' (PHP convert into its TZ hour and databse will unconvert it using its timezone too that is same than PHP).
- Dates that are updated automatically (field tms into database) contains a GMT Timestamp GMT of date when change is done. The select will also use the db->jdate (that use PHP server TZ) to convert read data into a GMT Timestamp into memory. So if timezone of database differs from timezone of PHP server (one of them is not correctly set), you may experience differences between creation date and update date.
- Manipulation date with PHP must be done using the Dolibarr date functions: dol_now(), dol_mktime(), dol_stringtotime(), dol_getdate(), dol_time_plus_duree(). You may also find other functions available into file date.lib.php.
UTF8/ISO encoding
- In database, data is stored in UTF8 or ISO. It depends on the database's pagecode therefore these options are set at creation time. In any case, Dolibarr's database driver (in lib/database) deals with it to convert from/to UTF8 at insertion and readout.
- Memory data is stored in UTF8 (PHP object instances).
- Screen displayed web pages are UTF8 (for versions prior to 2.5.1, the deprecated $character_set parameter from conf.php file defines output format).
print 239.2 - 229.3 - 9.9;
Creation of tables
Do not create tables, on the fly, during execution by a standard user, we mean, during current usage of software. If you create a module that uses its own table, not available in the default Dolibarr code, then take a look at tutorial Module Development. It explains how to provide new tables with your module, so that, the tables will be created during module activation and not during module usage.
Logs
Working directory
dol_mkdir($mymoduledir);
Patterns of code organization
- The Transaction Script (The source code is linear for each user action).
- The Domain Model
- The Table Module
- The Table And Row Data Gateway
- The Active Record
- The Data Mapper
