Module SelectBank
Module name Select Bank
Last update date / Date mise à jour fiche / Fecha última actualización 2015-11-8
Feature
Can select, when generating PDF, the bank account to suggest.
Prérequis
Dolibarr 3.5.0
Create bank accounts (module Bank must have been activated). The list of bank accounts appears on invoices into section to generate PDF for invoices.
Template:TemplateModNLTechno
