Module SelectBank
Revision as of 01:45, 8 November 2015 by Eldy (talk | contribs) (→‎Installation)
Module name Select Bank
Last update date / Date mise à jour fiche / Fecha última actualización 2015-11-8
Feature
Can select, when generating PDF, the bank account to suggest.
Prérequis
Dolibarr 3.5.0
Template:ActivationModule
Create bank accounts (module Bank must have been activated). The list of bank accounts appears on invoices into section to generate PDF for invoices.
Template:TemplateModNLTechno
