Module Ext direct
Revision as of 20:04, 20 October 2015 by Fappels (talk | contribs) (create)
Module name dolibarrextdirect
Editor / Editeur Z-Application
Dolibarr min version: 3.2.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2015-10-20
Connect to external Extjs/Sencha Touch javascript applications which use Sencha Ext.direct
