Roadmap and Release 3.8.0
Version: 3.8.0 and 3.8.1 (List of other versions on page Category:RoadMap)
Release date: September 2015
Should contains all tasks with priority 9 logged when previous version were released in task tracker https://github.com/Dolibarr/dolibarr/issues
- Enhancement of module project. Add a way to manage opportunities with calculation of estimated amount you can sell based on status of opportunity (that are a probability to win the lead).
- A new expense report module: you can set aa different project for each line of your expense report, can attach files, manage private and public notes like with other modules
- Enhancement of project module. A new way to enter time spent for timesheet management. Can see profit of a project in one page including invoices, expense reports, calculation of value of time spent defined into timesheet
Detailed Changelog:
***** ChangeLog for 3.8.1 compared to 3.8.0 ***** FIX: #3521 postgresql migration error FIX: #3524 FIX: #3529 FIX: #3530 FIX: #3533 FIX: #3533 Load categories language FIX: #3534 FIX: #3572 Impossible to attach project in order FIX: #3599 Not saving legal form FIX: #3606 FIX: #3607 Better categories setting and unsetting FIX: #3628 FIX: #3630 - Wrong balance report when module salaries and donation disabled FIX: Add a test to save life when ref of object (invoice ref, order ref, ...) was empty. The was no way to go back to a clean situation, even after vaidating again the object. FIX: Admin fiche inter page do not take good action FIX: Always use type send in parameters in showCategories method FIX: avoid SQL error in getValueFrom common object when all params are not send FIX: avoid SQL error when no sortfield send to method FIX: bad link into project box FIX: Bad title line in project view when using jmobile FIX: Bad translation key for project "Overview" FIX: Can create Proposal on close thridparty #3526 FIX: Can't change state on a contact FIX: Can't change the admin with default setup FIX: Can't delete thirdparty if there is some discounts FIX: Can't reopen a canceled invoice. FIX: Creation of tables or keys must not be done with a random order. FIX: debian install when module mysqli is not installed. FIX: Description of tags was mandatory in edit mode but not in create mode. Should not be mandatory. FIX: display error on extrafields on ficheinter FIX: Email selector contact must not include inactive contact FIX: error in SQL due to a previous fix FIX: Error retrieving customer prices FIX: Event from ical stream should not be movable into calendar view FIX: facturestat bad sql when customer view is limited FIX: Filter on status of thirdparty list and bad encoding of url FIX: icon into export profile may be not correctly output FIX: Init into bad var FIX: Link of project must be cickable if user has permission to read all projects FIX: Missing information into the alt of project picto FIX: List of project for user that are restrited as sale repreentative to some thirdparties. FIX: Mass Mailing activity don't display all status FIX: Missing contracts into list in page of Refering objects of a thirdparty. FIX: Missing menu entry for list of thirdparties when using auguria menu manager FIX: Missing validate button if permission are not valid. FIX: New adherent from, always redirect on entity FIX: not closing CSS. FIX: not responsive part for project page FIX: Only are showing one object linked FIX: order ref must not be translated FIX: Payment form for paypal and paybox was not centered. FIX: Pb into pagination scroll widget FIX: Style of previous-next card when using dolidroid FIX: Regression on bad use of fk_account showing the bad bank account on PDF. FIX: Removed warnings FIX: remove twice same test FIX: select of project using ajax autocomplete option FIX: sortder field was missing so manually added values were moved to begin. FIX: Syntax error in Debian Apache configuration FIX: The admin flag is mising. FIX: The filter on thirdparty prices should be visible if there is at least one thirdparty price. FIX: Thirdparty is missing on card FIX: update2.php test res befre assign it FIX: When delete actioncomm also delete actioncomm_resources FIX: when editing time spent, date of line suggested was a rubbish value FIX: When filter with empty status, by default get canceled status (-1) FIX: When update a member login for a member linked to a user, the login of user was not sync (not updated). FIX: Wizard for restore does not show import command ***** ChangeLog for 3.8 compared to 3.7.* ***** For users: FIX: #2519 FIX: #2758 Product::update sets product note to "null" when $prod->note is null FIX: #2832: Fixed a problem with special characters in expense report PDF model FIX: #2856 : Wrong table design FIX: #2901 FIX: #2957 : missing $langs object for trigger FIX: #2983 Load gravatar avatar images securely over HTTPS FIX: #2987: removed dead function moneyMeter() FIX: #3009: Better filtering to prevent SQL injection FIX: #3009: Better filtering to prevent SQL injection FIX: #3091 TotalHT amount in supplier order is bold unlike the rest of Dolibarr FIX: #3138 - Too much visible thing when access is denied on public pages FIX: #3173 Overlapping of shipment ref FIX: Adding 5 more choice link into survey module was not working with chrome FIX: bad calculation for stock value FIX: Bad link to login page into email for password renewal. FIX: Bad logo for status "Do not contact" of thirdparty. FIX: Bad variable usage FIX: Better management error into the color conversion functions FIX: [bug #1883] missing field in SQL installation FIX: Bug on order and supplier invoice numeration mask when use supplier code FIX: Bug on order and supplier invoice numeration mask when use supplier code FIX: button create payment hide if tax amount is less than 1 FIX: can receive new batch product on supplier order FIX: can show print page after product save FIX: Close #2835 Customer prices of a product shows incorrect history order FIX: Close #2837 Product list table column header does not match column body FIX: Close bug #2855 Wrong translation key in localtax report page FIX: Close bug #2861 Undefined variable $res when migrating from 3.6.2 to 3.7.0 FIX: Close bug #2891 Category hooks do not work FIX: Close bug #2900 Courtesy title is not stored in create thirdparty form FIX: Close bug #2976: "Report" tab is the current tab but it is not marked as selected by the UI FIX: Correct migration script FIX: create contact with extrafiel is null when it is require FIX: Description of contract line was not visible. FIX: Correct path of loan class FIX: Correct problem field with note - Add note_private & use wysiwyg editor FIX: Edit in place of "Outstanding Limit" FIX: Module Expense Report - Correct init FIX: Update licence to GPLv3 FIX: End log must use same level then start log. FIX: event for restricted user was restricted if company null FIX: event not linked to contact on creation FIX: Export of tags for contact and member FIX: extrafields required on thirdparty FIX: Force ref FIX: Function expects an int, not a boolean FIX: Function was expecting a boolean not a string FIX: hide category if it's not enable FIX: If supplier invoice block linked element is display after other block total HT amount is not reset to 0 and sum other block (like customer orders values) FIX: jdate returning -62169955200 on x64 machine FIX: Let ability to use IDPROF verifications even if new entry is "private" FIX: migration error FIX: moved built-in bug report system to GitHub Issues FIX: Moved code to where the variable is defined FIX: No check warehouse is provided if module stock is not enabled. FIX: Payed invoices are showed as canceled FIX: Bad date filter on customer order FIX: Ref/label of product on contract line was not visible, nor into page, nor into PDF. FIX: Removed concatenation on undeclared variable FIX: Remove deprecated property 'libelle' on product object FIX: Replaced some deprecated call FIX: Replaced some deprecated property FIX: Save of filters into export profiles failed. FIX: "script" balise with wrong syntax FIX: send mail, copy sendto don't read the list of contact FIX: top links menu have target attribute with wrong value FIX: total amount in tpl linked object are not reset FIX; Unknown field 'sc.fk_soc' in field list FIX: update usergroup name FIX: Variable declared boolean FIX: Variable might not be traversable FIX: We did a test on a permission to export contract when permission did not exists. FIX: when mailing is deleted, the targets list was kept in database FIX: when multicompany was enabled, this function didn't check just on the good entity (problem when both company use same mask) FIX: When we automatically creta an order from a proposal with workflow module, if some extrafields of propal don't exist in order object, insertExtraFields() function tries to insert extrafields in unexistant column of commande_extrafields table. FIX: When we clone a propal, if it has a project which is not assigned to a third, it was not on new propal because fk_project was always set to empty string if new propal is for another third. FIX: when we create an agenda event with "Not applicable" status, it is automatically saved with "To do" status FIX: width multiselect FIX: Wrong type hinting FIX: XSS security using the onerror and missing escapement on type of member page. FIX: Missing visibility of static property NEW: Add a button to purge criteria in user list NEW: add all assigned users and all extrafields data in new event when we createFromClone NEW: Add a new component to select categories/tags from the main edit page of product. The dedicated tab is also removed. NEW: Add a search field and report on hrm area NEW: Add a tab document in donation card NEW: Add bank account owner in invoice/proposal/orders footer NEW: Add button to purge search criteria into list NEW: Add close date and user for projects. NEW: Add company information into category contact export NEW: Add current salary on list of payment NEW: add date value filter on account records list NEW: Add exemple of setup for multitail to render dolibarr log files NEW: Add filter on status on invoice list NEW: Add filter on task ref and task label into list of tasks NEW: Add filter on user contact or user task into task list NEW: Add gender property managed on user card FIX: Better error messages when uploading photo of user when permission to write are not granted NEW: Add help tooltips on fields of dictionary edit pages. Fix: visible list of tasks are for opened project only. NEW: Add hidden option MAIN_MAILFORM_DISABLE_ENTERKEY to disable the key enter into the form to send email. NEW: add hook in send mail NEW: Add hooks on list of members to allow an external module to add more fields into list view. NEW: Add hooks to allow an external module to complete list of events into calendar views. NEW: Add opportunity amount on project card. NEW: Add option THEME_ELDY_DISABLE_IMAGE to disable images into menu eldy. NEW: add PDF icon on linked element into project NEW: add "productpricecard" hook and uniformize code NEW: Add ref and label of project into export NEW: Add search box for supplier order search. NEW: Add status into filters of graph NEW: Add tab document on salaries payment NEW: A link to the bugtracker can be enabled in the GUI NEW: A module can add its entries into cron module. NEW: autofocus on product selection dropdown list or search field NEW: Backup and restore tool is easier to use NEW: Can add all user of a project as user of a task, in one step. NEW: Can add project search on left menu search area NEW: Can assign a task to yourself to have it appear on timesheet NEW: Can close a project that has draft status with no need to switch it to validate status before. NEW: Can edit Background color for Top menu and Background color for table title line (works only with theme menu eldy). NEW: Can edit email template using WYSIWYG editor NEW: Can edit internal label of invoice even when closed (this is a private information) NEW: Can edit list of prospect status for customers/prospects. Add a new entry into dictionary table to manage list fo status. Removed deprecated files. NEW: Can filter on contact status in prospect list. Removed deprecated menu entry. NEW: Can filter proposal on a tag of a product Enhance also the prototype test_arrays to include select form before table. NEW: Can filter proposal, orders or invoices with criteria "contain at least one product with following tag" NEW: Can install an external module from admin pages, if web server has permission for and if setup is ok for. NEW: Can search on customer order amount into customer order list. NEW: Can upload files on leave requests. Use more standard permissions. NEW: Can use a "|" to make a OR search on several different criterias into text filters of tables. NEW: Clean code into salary module, debug and add indexes NEW: Can filter on user list and salary payments on user with naural search. NEW: clone action on agenda events NEW: dev feature : replace conf filename with "conf" parameter on url by GET NEW: display linked object in edit mode when we create an event from an order, propal... NEW: Enhancement of module 'Notification by Email'. Show nb of notifications set. Can set several emails. Can set a threshold on amount for notifications. Add notification on supplier order validation. NEW: Enhance prototype, project list and proposal list with new hook to have an external module able to add more fields. NEW: Enhance the natural_search function so we can use it to search numeric fields with criteria with operator <>= inside (< 100, >= 1000) NEW: Enter amount for withdraws requests NEW: Feature request: A page to merge two thirdparties into one #2613 NEW: Feature to build a merged pdf with all unpaid invoice can work for paid invoices. NEW: Filter "active" by default on user list. Fix label of permission of project module NEW: For a contract line, price is no more mandatory. NEW: Forms are using the tab look, even in creation mode. NEW: Hidden option THEME_ELDY_USE_HOVER is stable enough to become officialy visible into setup. NEW: If module salaries is on, you can set a hourly value for tome consumed by users. Each time a user enter its time consumed on a project, a calculation is done to provide the cost for human services. This value appears into the "Transversal view" of project. NEW: Implement option SUPPLIER_ORDER_USE_DISPATCH_STATUS to add a status into each dispathing line of supplier order to "verify" a reception is ok. Status of order can be set to "total/done" only if line is verified. NEW: Into the overview of projects, the name of thirdparty appears into combo lists of elements to link to project. NEW: Introduce option SUPPLIER_ORDER_DOUBLE_APPROVAL to allow 2 approvals to make a supplier order approved. Activating this option introduce a new permission to the second level approval. NEW: Introduce TCPDI as replacement of FPDI. NEW: List of recent modified supplier product prices in Supplier card NEW: Module notification should details of emails into confirm box, not only number. NEW: On page to see/edit contact of an ojbect, the status of contact is visible (for both external and internal users). NEW: Product stock and subproduct stock are independant NEW: Propal merge product card PDF into azur NEW: Rename install etape to step NEW: Replace category edition page on members with new select2 component. NEW: Show difference between timespent by everybody and time spent by user making timesheet into timesheet pages. NEW: Can enter start hours of task when creating timesheet NEW: Show last official stable version into system - update page. NEW: Show photo of logged user into login top right block. NEW: If no photo is available for user, we show a generic photo depending on gender NEW: [T1758] Merge bank card & account card NEW: [ task 1191 ] AJAX selector for projects NEW: [ task #851 ] Add a new field: Commercial name NEW: [ task #977 ] New option to manage product unit Migrated code from GPCSolutions/dolibarr:3.2-units branch and adapted for 3.8 with some improvements NEW: The line where mouse is over can be highlight with option THEME_ELDY_USE_HOVER (on by default) NEW: The notification module accept keyword __SUPERVISOR__ to send notification to supervisor of user. NEW: Thumbs for statistics on main page are fully clicable (not only link inside the thumb) NEW: Title of page project contains project ref and label NEW: update skeleton and class builder NEW: Use new select2 component for juridical status, country and state selection. NEW: Web service to create or update product can correct stock during creation/update. NEW: When creating order, proposal or invoice from thirdparty card, the project is asked during creation. A link to create project if it does not exists is also available. NEW: Uniformize form creation of proposal to add public and private notes during creation like done for order and invoice. NEW: When using transfer or correct stock from warehouse, after recording we go back to the warehouse page. NEW: Add Option to not change date on cloning project NEW: Add check list from table for extrafield type NEW: Use new combobox. NEW: Add hidden option MAXTABS_IN_CARD. NEW: A default label is suggested for stock correction and transfer instead of empty string. NEW: Add Weighted average price as default price for buying price for margin calculation. Add option MARGIN_PMP_AS_DEFAULT_BUY_PRICE to replace with first supplier price. NEW: Introduce option MAIN_HTML_TITLE to start to control format of html title content. NEW: Add extrafields on bank account cards. NEW: Added delay between mails in Newsletter module. NEW: [ task #1793 ] Create new permission to restrict commercial agent margin to logged user. NEW: Add experimental module ask supplier price to request supplier quotation. NEW: Add module batch management. For translators: NEW: Update language files. NEW: When a translation is not available we always jump to en_US and only en_US. NEW: All language tranlsations (except source en_US) is now managed on https://www.transifex.com/projects/p/dolibarr/. FIX: Typo errors in translation. For developers: NEW: Function yn can show a visual checkbox. NEW: Introduced select2 jquery plugin. NEW: Possibility to add javascript in main login page with "getLoginPageOptions" hook. NEW: possibility to defined a tab for all entities in module descriptor. NEW: add restler framework First step to build REST API into Dolibarr. NEW: add an explorer for REST API consultation & documentation. NEW: script to build API class from existing class. NEW: Add function dolCopyDir to copy directory with recursive content. NEW: Introduce function dolGetFirstLineOfText. WARNING: Following changes may create regression for some external modules, but were necessary to make Dolibarr better: - Removed hook supplierorderdao into supplier order creation. This is a business event, so we must use the trigger ORDER_SUPPLIER_CREATE instead. - Hooks 'printLeftBlock' and 'formConfirm' are now compliant with hook development rules. They are "addreplace" hooks, so you must return content with "->resprints='mycontent'" and not with "return 'mycontent'" - All fields "fk_societe" and "fk_soc" are now named "fk_soc" (same name for all fields). - Method select_PriceBaseType and load_PriceBaseType were merged into selectPriceBaseType. - The triggers USER_LOGIN* are deprecated. They are still working but you should prefer use the hook afterLogin or afterLoginFailed instead. - The trigger USER_CREATE_FROM_CONTACT has been replace with USER_CREATE and property context is now filled to make difference between creation from contact or not. - Function get_exdir require now 6 parameters. This is to prepare a future feature.
