Table llx extrafields
Revision as of 09:13, 5 September 2015 by Eldy (talk | contribs)
Content/Contenu/Contenido
  Contains the extra fields.
  Contient des extra champs.
  Contiene los campos adicionales.
Structure
Table
rowid int(11) NO PRI auto_increment Technical id
name varchar(64) NO UNI Name of field
entity int(11) NO 1 See page Field Multi company id. (llx_entity->rowid)
elementtype varchar(64) NO For which element this extra fields is for
tms timestamp NO Current date Date of last modification. See page Field Tms.
label varchar(64) NO Label of field
type varchar(8) NO Type/format of field
size int(11) YES NULL Max size of field
fieldunique int(11) YES NULL 1 if field value must be unique
fieldrequired int(11) YES NULL 1 if field value is mandatory
perms varchar(255) YES NULL 1 if field value is mandatory
pos int(11) YES NULL Position of extra field among other extra field
alwayseditable int(11) YES NULL 1=The field can be edited whatever is status of object
param text YES NULL Parameters to define possible values of field
ishidden int(11) YES 0 The extra field is not visible by user
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_extrafields_name UNIQUE name,entity,elementtype
