Table llx extrafields
Revision as of 09:12, 5 September 2015 by Eldy (talk | contribs)
Content/Contenu/Contenido
En verysmall.png Contains the extra fields.
Fr verysmall.png Contient des extra champs.
Es verysmall.png Contiene los campos adicionales.
Structure
Table
rowid int(11) NO PRI auto_increment Technical id
name varchar(64) NO UNI Name of field
entity int(11) NO UNI 1 multi company id
elementtype varchar(64) NO For which element this extra fields is for
tms timestamp NO Current date Date of last modification. See page Field Tms.
label varchar(64) NO Label of field
type varchar(8) NO Type/format of field
size int(11) YES NULL Max size of field
fieldunique int(11) YES NULL 1 if field value must be unique
fieldrequired int(11) YES NULL 1 if field value is mandatory
perms varchar(255) YES NULL 1 if field value is mandatory
pos int(11) YES NULL Position of extra field among other extra field
alwayseditable int(11) YES NULL 1=The field can be edited whatever is status of object
param text YES NULL Parameters to define possible values of field
ishidden int(11) YES 0 The extra field is not visible by user
Keys
Key Type Fields
PRIMARY PRIMARY rowid
idx_extra_fields_name UNIQUE name,entity
