Table llx commande fournisseur
Revision as of 14:33, 7 July 2015 by A.schild (talk | contribs) (Corrected typos)
Content/Contenu/Contenido
En verysmall.png Contains suppliers orders. The order details are in Table llx_commande_fournisseurdet
Fr verysmall.png Table principales des commandes fournisserus, les détails de la commande sont dans la Table llx_commande_fournisseurdet
Es verysmall.png Tabla principal de los pedidos a proveedores, los detalles de pedidos se encuentran en Table llx_commande_fournisseurdet
Structure
Table
rowid int(11) NO PRI auto_increment technical index
ref varchar(30) YES UNI order number
entity int(11) NO 1 See page Field Multi company id. (llx_entity->rowid)
ref_ext varchar(30) NO See page Field ref_ext.
ref_supplier varchar(30) YES NULL supplier order number
fk_soc int(11) NO UNI ID society (llx_societe->rowid)
fk_projet int(11) YES 0 ID of proyect (llx_projet->rowid)
tms timestamp NO Current date Date of last modification. See page Field Tms.
date_creation datetime YES NULL creation date
date_valid datetime YES NULL validation date
date_cloture datetime YES NULL closed date
date_comande date YES NULL order date
fk_user_author int(11) YES NULL ID creator user (llx_user->rowid)
fk_user_valid int(11) YES NULL ID validator user (llx_user->rowid)
fk_user_cloture int(11) YES NULL ID closer user (llx_user->rowid)
source smallint(6) NO order source
fk_statut smallint(6) YES 0 ID of status - See Module Suppliers (developer)
amount_ht real YES 0 amount without tax
remise_percent real YES 0 discount percentage
remise real YES 0 discount amount
tva double(24,8) YES 0.00000000 VAT
total_ht double(24,8) YES 0.00000000 total without tax
total_ttc double(24,8) YES 0.00000000 total
note text YES NULL comentary
note_public text YES NULL public comentary
model_pdf varchar(50) YES NULL Model PDF to print
fk_methode_commande int(11) YES 0 order method
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_commande_fournisseur_ref UNIQUE ref,fk_soc,entity
idx_commande_fournisseur_fk_soc MULTIPLE fk_soc
