Table llx facture fourn
Revision as of 14:31, 7 July 2015 by A.schild (talk | contribs) (Corrected typos)
Content/Contenu/Contenido
En verysmall.png Contains invoices sent by suppliers. A supplier invoice can be linked to a supplier order (Table llx_commande_fournisseur) by the Table llx_element_element.
Fr verysmall.png Cette table contient la liste des factures émises par les fournisseurs. Une facture fournisseur peut être liée à une commande fournisseur (Table llx_commande_fournisseur) au travers de la Table llx_element_element
Es verysmall.png Contiene las facturas emitidas por los proveedores. Una factura de proveedor puede estar enlazada con un pedido a proveedor (Table llx_commande_fournisseur) a traves de la Table llx_element_element.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
facnumber varchar(50) NO UNI invoice number
entity int(11) NO 1 See page Field Multi company id. (llx_entity->rowid)
ref_ext varchar(30) NO See page Field ref_ext.
type smallint(6) NO 0 type of invoice (0=Standard invoice, 1=Replacement invoice, 2=Credit note invoice). For the moment only 0 is supported.
fk_soc int(11) NO UNI ID society (llx_societe->rowid)
datec datetime YES NULL creation date
datef date YES NULL date of invoice
tms timestamp NO Current date Date of last modification. See page Field Tms.
libelle varchar(255) YES NULL label
paye smallint(6) NO 0 Is the invoice payed (1=yes, 0=otherwise)?
amount double(16,8) NO 0.00000000 amount
remise double(16,8) YES 0.00000000 discount
tva double(16,8) YES 0.00000000 VAT
localtax1 double(24,8) YES 0.00000000 Special VAT rate 1 (spain)
localtax2 double(24,8) YES 0.00000000 Special VAT rate 2 (spain)
total double(16,8) YES 0.00000000 total amount
total_ht double(16,8) YES 0.00000000 total amount excluding VAT
total_tva double(16,8) YES 0.00000000 total amount of VAT
total_ttc double(16,8) YES 0.00000000 total amount with VAT
fk_statut smallint(6) NO 0 Status of invoice (0=draft, 1=unpayed, 2=payed, 3=abandoned)
fk_user_author int(11) YES MUL NULL ID of user author of invoice (llx_user->rowid)
fk_user_valid int(11) YES MUL NULL ID of user validator of invoice (llx_user->rowid)
fk_projet int(11) YES MUL NULL ID of related proyect (llx_projet->rowid)
fk_cond_reglement int(11) NO 1 Id of payment condition (llx_cond_reglement->rowid)
date_lim_reglement date YES MUL NULL date limit for payment
note text YES NULL commentary
note_public text YES NULL public commentary
import_key varchar(14) YES NULL Code used to save the import id. See page Field Import key.
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_facture_fourn_ref UNIQUE facnumber,fk_soc,entity
idx_facture_fourn_date_lim_reglement MULTIPLE date_lim_reglement
idx_facture_fourn_fk_soc MULTIPLE fk_soc
idx_facture_fourn_fk_user_author MULTIPLE fk_user_author
idx_facture_fourn_fk_user_valid MULTIPLE fk_user_valid
idx_facture_fourn_fk_projet MULTIPLE fk_projet
Notes
En verysmall.png Attention, if the status is 1 (unpayed) but the field "paye" is also 1 (payed), which should never happen under normal use, the invoice is specified payed.
Fr verysmall.png Attention, si le statut est à 1 (impayée) mais le champ "paye" est à 1 également (payée), ce qui ne devrait jamais arriver dans des conditions normales d'utilisation, la facture est indiquée comme payée.
Es verysmall.png Atención, si el statut está a 1 (impagada) pero el campo "paye" está a 1 también (pagada), cosa que nunca pasa en condiciones normales de uso, la factura se indicará como pagada.
