Versions
  • Dolibarr must work on:
  3. Mysql 5.1+
Copyright Norms
<?php
 * Licence information
PHP Norms
PHP
  • Dolibarr is written with PHP and supports all PHP version higher than 7.1.0+. All files must end with extension .php
  • Usage of PHP superglobals variables must use dedicated operators $_COOKIES, $_SERVER, $_ENV but use Dolibarr function GETPOST() to get content of $_GET or $_POST..
Other operators ($HTTP_SERVER_GET, ...) are now deprecated inside PHP, so they must no more be used. Like that code will work also if option register_long_arrays is set to off. Moreover, the code must work when PHP option register_globals is off (recommended by PHP). It must work the same way when the option register_globals is on (by default on a lot of installations).
  • Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"].
  • When several variables must be initialized with same value, you must use several lines
$var1=1;$var2=1;$var3=1;
instead of
$var1=$var2=$var3=1;
that is slower.
  • String must be rounded by simple or double quote and variable inside string must be out side of the quote.
print 'My text show my'.$variable.'!';
/* Bloc of comment
 * End of bloc
for ($i = 1 , $i < 2 ; $i++)
  // comment on one line
  print $i;
  • Coding style to use is the PSR-2 (https://github.com/php-fig/fig-standards/blob/master/accepted/PSR-2-coding-style-guide.md) with 2 exceptions, this means:
    • But there is an exception of length of line: We accept more than 80 characters per line. 80 is really too low. In most cases, we never go over 80, but sometimes (when declaring a list of reference arrays, like in the module descriptor files), it is better to have long lines instead of long page with code content that is just data declaration and does not contain any logic.
    • The other exception is that we don't replace the tab with space. This makes lot of editor crazy and breaks some auto-format features.
You can use the file dev/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
Some properties of classes are found into different classes. To avoid having different names, we will use the following names:
  • date_creation date creation
  • user_creation object User creating object
  • fk_user_creation id user creating object
  • date_modification date last modification
  • user_modification objet User last modification
  • fk_user_modification id user last modification
  • date_validation date validation
  • user_validation objet User
  • fk_user_validation id user making validation
SQL rules
Table and fields structures
  • Structure of tables.
- rowid integer for id
- tms timestamp that will contain date of last modification (the database manages this field automatically, no need to manage it by the code, just create the field)
- import_key that will contains the import code YYYYMMDDHHMMSS if you make mass import.
Eventualy
- datec timestamp that is the creation date
- fk_user_author integer that is the id of user making creation
- fk_user_mod integer that is the id of user making change
- fk_soc integer that is the ID of the Thirdparty
Note field:
or
  • Type of fields:
Well, to be compatible with any accuracy required by any country on amounts, and with any database syntax, we will use the following type into database:
- integer for an any of foreign key
- double(24,8) for any amount
- real for a quantity
- date for a field date
Primary keys
Foreign keys
Alternative keys
Index performance
DDL file format
create table llx_mytable
  field_one   integer,
  field_two   integer NOT NULL,
  fk_field    integer,
  field_date  datetime,
)type=innodb;
SQL Coding rules
  • Alias usage/Fields naming
  • Using SELECT * is forbidden ! When using SELECT you must define complete list of fields to get. This avoids confusion. Example:
Example:
  • Functions NOW or SYSDATE are forbidden inside SQL requests. If you must use the current date into a field, value must come from the PHP and not from the database engine. This is for better portability of code and correct management of TimeZone.
Mysql specificities
  • Dolibarr must work even if Mysql option strict is active.
To activate it (recommended when developing on Dolibarr), add the following line into the config file of your Mysql server (my.cnf or my.ini)
PostgreSQL specificities
MySQL Syntax:
PgSQL Syntax:
} else {
HTML norms
Syntax rules
For example:
There is ton of frameworks to provide a templating language of an HTML page. The best and faster is just called "PHP", and because Dolibarr already depends on PHP, there is no need for depend on a third languages.
All templating frameworks are just preprocessor, BEFORE PHP. It can't be faster than PHP alone. When we say "speed, when using cache of templating framework, is increase", it is in fact the overtime spent by the framework that is reduced by cache, not the speed of processing PHP file. We should says "any templating framework has an overload over PHP, the cache of framework, just reduce the slowing effect of using it", but not "the speed is increased, it is always increased".
Above all, having a templating system is completely possible by doing a ".tpl.php" file that dos not contains any logic code, but only HTML and echo. We get same result (but faster and easier to develop because it does not need to do all the setXXX) before calling each template. All variables (known by code that include the template) are automaticaly known into a PHP template page. No risk to forget a set, and a lot of line of codes reduced, a lot of time saved.
Also, keeping a 100% isolation between code and HTML output is interesting in only 1 situation: When teams building design is complety different than team building logic code, AND if you build not too sophisticated pages, AND with no need of too many Ajax features (this need to know how code works). And this situation is surely not the Dolibarr future (team will often be same, Ajax will be more and more present, event if I hope not too much, and screens are more and more dependent of dynamic or contextual events, difficult to have with a template without transforming the template into a page with high level of code).
There is a ton of other reasons to not use an external templating system and all arguments to use them are the best argument to use PHP as our templating system.
Skeleton code
Dates and Timezones
For exemple le 1st january 1970, 3 hour at Paris (TZ=+1) = 2 hour at Greenwitch (TZ=0) will be stored into memory with value 7200 and will be submitted into a SQL request to database with the string '19700101030000' (PHP convert into its TZ hour and databse will unconvert it using its timezone too that is same than PHP).
UTF8/ISO encoding
print 239.2 - 229.3 - 9.9;
Creation of tables
Do not create tables, on the fly, during execution by a standard user, we mean, during current usage of software. If you create a module that uses its own table, not available in the default Dolibarr code, then take a look at tutorial Module Development. It explains how to provide new tables with your module, so that, the tables will be created during module activation and not during module usage.
Logs
Working directory
dol_mkdir($mymoduledir);
Patterns of code organization
  • The Domain Model
  • The Table Module
  • The Active Record
  • The Data Mapper
