Versions
  • Dolibarr must work on:
  3. Mysql 5.1+
Copyright Norms
<?php
 * Licence information
PHP Norms
PHP
  • Dolibarr is written with PHP and supports all PHP version higher than 7.1.0+. All files must end with extension .php
  • Usage of PHP superglobals variables must use dedicated operators $_COOKIES, $_SERVER, $_ENV but use Dolibarr function GETPOST() to get content of $_GET or $_POST..
Other operators ($HTTP_SERVER_GET, ...) are now deprecated inside PHP, so they must no more be used. Like that code will work also if option register_long_arrays is set to off. Moreover, the code must work when PHP option register_globals is off (recommended by PHP). It must work the same way when the option register_globals is on (by default on a lot of installations).
  • Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"].
  • When several variables must be initialized with same value, you must use several lines
$var1=1;$var2=1;$var3=1;
instead of
$var1=$var2=$var3=1;
that is slower.
  • String must be rounded by simple quote and variable inside string must be out side of the quote.
print 'My text show my'.$variable.'!';
/* Bloc of comment
 * End of bloc
for ($i = 1 , $i < 2 ; $i++)
  // comment on one line
  print $i;
  • Functions must return a value strictly higher than 0 if successful and strictly lower than 0 if error.
  • Use "include_once" for anything with functions or class definitions in it (like *.class.php and *.lib.php files), use "include" for template-style php with files containing a mix of HTML and PHP (like *.inc.php and *.tpl.php files).
  • Coding style to use is the PSR-2 (https://github.com/php-fig/fig-standards/blob/master/accepted/PSR-2-coding-style-guide.md) with 2 exceptions, this means:
    • But there is an exception of length of line: We accept more than 80 characters per line. 80 is really too low. In most cases, we never go over 80, but sometimes (when declaring a list of reference arrays, like in the module descriptor files), it is better to have long lines instead of long page with code content that is just data declaration and does not contain any logic.
    • The other exception is that we don't replace the tab with space. This makes lot of editor crazy and breaks some auto-format features.
You can use the file dev/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
Some properties of classes are found into different classes. To avoid having different names, we will use the following names:
  • date_creation date creation
  • user_creation object User creating object
  • fk_user_creation id user creating object
  • date_modification date last modification
  • user_modification objet User last modification
  • fk_user_modification id user last modification
  • date_validation date validation
  • user_validation objet User
  • fk_user_validation id user making validation
SQL rules
Table and fields structures
  • Structure of tables.
- rowid integer for id
- tms timestamp that will contain date of last modification (the database manages this field automatically, no need to manage it by the code, just create the field)
- import_key that will contains the import code YYYYMMDDHHMMSS if you make mass import.
Eventualy
- datec timestamp that is the creation date
- fk_user_author integer that is the id of user making creation
- fk_user_mod integer that is the id of user making change
- fk_soc integer that is the ID of the Thirdparty
Note field:
or
  • Type of fields:
Well, to be compatible with any accuracy required by any country on amounts, and with any database syntax, we will use the following type into database:
- integer for an any of foreign key
- double(24,8) for any amount
- real for a quantity
- date for a field date
Primary keys
Foreign keys
A foreign key name must start with prefix fk_ followed by the table name linked (this is required to avoid duplicate names in project that are not allowed even if on different tables by some DBMS like Postgresql) then the name of child field (this is to allow to have several foreign keys on same table).
Example: fk_facture_fourn_fk_soc is a foreign key on table llx_facture_fourn for field fk_soc in this table (that link to the rowid field in another table)
Alternative keys
Index performance
DDL file format
Files that contain definition of the database structure (DDL files) must be 2 per tables:
  • Each table is defined by its own file whose name is llx_mytable.sql
A comment will be added on each field to explain its usage.
  • All foreign keys, performance indexes or other constraints will be defined into another file called llx_mytable.key.sql
Those files must be stored into directory install/mysql/tables for all standard files or mymodule/tables for tables provided by an external module.
Example file of table llx_mytable.sql:
create table llx_mytable
  field_one   integer,
  field_two   integer NOT NULL,
  fk_field    integer,
  field_date  datetime,
)type=innodb;
Example file for keys/indexs on llx_mytable.key.sql:
ALTER TABLE llx_matable ADD UNIQUE uk_matable_field(field_one, field_two);
ALTER TABLE llx_matable ADD CONSTRAINT fk_matable_fk_field FOREIGN KEY (fk_field) REFERENCES llx_matablepere (rowid);
SQL Coding rules
  • Alias usage/Fields naming
  • Using SELECT * is forbidden ! When using SELECT you must define complete list of fields to get. This avoids confusion. Example:
Example:
  • Functions NOW or SYSDATE are forbidden inside SQL requests. If you must use the current date into a field, value must come from the PHP and not from the database engine. This is for better portability of code and correct management of TimeZone.
Mysql specificities
This format support foreign keys and their restrictions, and transactions integrity is also supported. This guarantee that Dolibarr events keep all data with correct values between tables even even transaction modify different tables.
  • Dolibarr must works even if Mysql option strict is active.
To activate it (recommanded when developping on Dolibarr), add the following line into the config file of your Mysql server (my.cnf or my.ini)
PostgreSQL specificities
There is an exception The SQL "UPDATE FROM" : Syntax MySQL :
Syntax PgSQL:
} else {
HTML norms
Syntax rules
For example:
  • Popups windows must not be used, except for tooltips (and must have a condition as explained before).
  • External scripts must be written into Perl if they can't be written into PHP. Usage of another language is not forbidden but must be argue before onto development mailing-list.
There is ton of frameworks to provide a templating language of an HTML page. The best and faster is just called "PHP", and because Dolibarr already depends on PHP, there is no need for depend on a third languages.
All templating frameworks are just preprocessor, BEFORE PHP. It can't be faster than PHP alone. When we say "speed, when using cache of templating framework, is increase", it is in fact the overtime spent by the framework that is reduced by cache, not the speed of processing PHP file. We should says "any templating framework has an overload over PHP, the cache of framework, just reduce the slowing effect of using it", but not "the speed is increased, it is always increased".
Above all, having a templating system is completely possible by doing a ".tpl.php" file that dos not contains any logic code, but only HTML and echo. We get same result (but faster and easier to develop because it does not need to do all the setXXX) before calling each template. All variables (known by code that include the template) are automaticaly known into a PHP template page. No risk to forget a set, and a lot of line of codes reduced, a lot of time saved.
Also, keeping a 100% isolation between code and HTML output is interesting in only 1 situation: When teams building design is complety different than team building logic code, AND if you build not too sophisticated pages, AND with no need of too many Ajax features (this need to know how code works). And this situation is surely not the Dolibarr future (team will often be same, Ajax will be more and more present, event if I hope not too much, and screens are more and more dependent of dynamic or contextual events, difficult to have with a template without transforming the template into a page with high level of code).
There is a ton of other reasons to not use an external templating system and all arguments to use them are the best argument to use PHP as our templating system.
Skeleton code
Dates and Timezones
For exemple le 1st january 1970, 3 hour at Paris (TZ=+1) = 2 hour at Greenwitch (TZ=0) will be stored into memory with value 7200 and will be submitted into a SQL request to database with the string '19700101030000' (PHP convert into its TZ hour and databse will unconvert it using its timezone too that is same than PHP).
UTF8/ISO encoding
print 239.2 - 229.3 - 9.9;
If data manipulated is not an amount, so using MU, MT, MS has no sense, so you must use the function round().
Creation of tables
Do not create tables, on the fly, during execution by a standard user, we mean, during current usage of software. If you create a module that uses its own table, not available in the default Dolibarr code, then take a look at tutorial Module Development. It explains how to provide new tables with your module, so that, the tables will be created during module activation and not during module usage.
Logs
Working directory
If you need to create a working directory, into your code, refer to it with DOL_DATA_ROOT.'/monmodule'
The directory can be created into your code by the following fnction:
dol_mkdir($mymoduledir);
If you need a directory to store temporary data, this directory must be DOL_DATA_ROOT.'/monmodule/temp'
Patterns of code organization
  • The Domain Model
  • The Table Module
-> As shown in code skeletons (see previous chapter), Dolibarr use concept of Table Module.
There is 3 way to make links:
This is the most simple. You have one class per table and each class is a link to the table with CRUD methods (Ceate, Read, Update, Delete). A class instance is a record a the table. The class contains only code to reach lines and fields of table.
  • The Active Record
Same than previous, but we are allowed to add some business functions into the class, if such functions are dedicated to the table or recordng into this table.
Example: This mode is used for Dolibarr development and most PHP softwares that includes their own framework and best practices.
  • The Data Mapper
Classes represent entities of the problem and not the data. So you have to double, triple ... theese classes with Mapper classes to access the data. More "purist" on paper (closer of business), this method also has the disadvantage of being more complex in practice.
Example: This is the choice if you use the ORM Framework Propel (http://propel.phpdb.org/trac/). We find this model on heavier applications, based on this ORM among others.
-> For Dolibarr development, it is recommended to use the connection mode Active Record, which offers the advantages of a model close to the business without having the complexity, without obfuscating the technique. It is in this way that the development, understanding of code and technical maintenance and / or business seems the more productive (this is however an ongoing debate between the purists and the pragmatists, debate in which nobody can really be right, because it depends on the objectives).
