Table llx commande
Revision as of 10:55, 23 March 2005 by Rodo (talk | contribs)
Presentation
Table principales des commandes clients, les détails de la commande sont dans la Table llx_commandedet
Structure
-- Copyright (C) 2003 Rodolphe Quiedeville <rodolphe@quiedeville.org>
-- the Free Software Foundation; either version 2 of the License, or
-- along with this program; if not, write to the Free Software
-- Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-- $Id: llx_commande.sql,v 1.4 2004/10/09 10:47:16 opensides Exp $
-- $Source: /cvsroot/dolibarr/dolibarr/mysql/tables/llx_commande.sql,v $
create table llx_commande
  rowid            integer AUTO_INCREMENT PRIMARY KEY,
  tms              timestamp,
  fk_soc           integer,
  fk_soc_contact   integer,
  fk_projet        integer DEFAULT 0,     -- projet auquel est rattache la commande
  ref              varchar(30) NOT NULL,  -- propal number
  date_creation    datetime,              -- date de creation
  date_valid       datetime,              -- date de validation
  date_cloture     datetime,              -- date de cloture
  date_commande    date,                  -- date de la commande
  fk_user_author   integer,               -- createur de la commande
  fk_user_valid    integer,               -- valideur de la commande
  fk_user_cloture  integer,               -- cloture de la propale signee ou non signee
  source           smallint NOT NULL,
  fk_statut        smallint  default 0,
  amount_ht        real      default 0,
  remise_percent   real      default 0,
  remise           real      default 0,
  tva              real      default 0,
  total_ht         real      default 0,
  total_ttc        real      default 0,
  note             text,
  model_pdf        varchar(50),
  facture          tinyint default 0,
  UNIQUE INDEX (ref)
)type=innodb;
