Versions
- Dolibarr must works on:
- All OS (Windows, Linux, MACOS...)
- PHP 7.1.0+ (Must works with no need of complementary PHP module, except module to PHP module to access database).
- Mysql 5.7.7+
Copyright Norms
- All PHP files must start with a header that looks like
<?php
* Licence information
PHP Norms
PHP
- Dolibarr is written with PHP and supports all PHP version higher than 7.1.0+. All files must end with extension .php
- Usage of superglobals PHP variables must use dedicated operators $_COOKIES, $_SERVER, $_ENV but use Dolibarr function GETPOST() to get content of $_GET or $_POST..
Other operators ($HTTP_SERVER_GET, ...) are now deprecated inside PHP, so they must no more be used. Like that code will works alos if option register_long_arrays is to off. Moreover, the code must works when PHP option register_globals is off (recommended by PHP). It must works the same way that when option register_globals is on (by default on a lot of installations).
- Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"].
- When several variables must be initialized with same value, you must use several lines
$var1=1;$var2=1;$var3=1;
instead of
$var1=$var2=$var3=1;
that is slower.
- String must be rounded by simple quote and variable inside string must be out of the quote.
print 'My text show my '.$variable.' !';
- Comments must use the C syntax, ie a double anti-slash for a comment on one line and a slash-star to open a bloc for several lines
/* Bloc of comment
* End of bloc
for ($i = 1 , $i < 2 ; $i++)
// comment on one line
print $i;
- Functions must return a value strictly higher than 0 if successful and strictly lower than 0 if error.
- No dead code (code never used) into Dolibarr core code (code used by external modules only must be included into external modules).
- Use "include_once" for anything with functions or class definitions in it (so *.class.php and *.lib.php files), use "include" for template-style php with files containing a mix of HTML and PHP (so *.inc.php and *.tpl.php files).
- Coding style to use is the PSR-2 (https://github.com/php-fig/fig-standards/blob/master/accepted/PSR-2-coding-style-guide.md) with 2 exceptions, this means:
- Files must be saved with Unix format (LF) and not Windows (CR/LF). Unif format is compatible on all OS like Unix like, Windows, Mac, but the Windows text file format is no working on some PHP under Unix.
- Smart tags PHP are not used. PHP code section must start with <?php
- But there is an exception of length of line: We accept more than 80 characters per line. 80 is really to low. In most cases, we never go over 80, but sometimes (when declaring a list of reference arrays, like into module descriptor files), it is better to have long lines instead of long page with code content that is just data declaration and does not contains any logic.
- The other exception is that we don't replace the tab with space. This makes lot of editor crazy and breaks some auto-format features.
You can use the file dev/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
Some properties of classes are found into different classes. To avoid having different names, we will use the following names:
- date_creation date creation
- user_creation object User creating object
- fk_user_creation id user creating object
- date_modification date last modification
- user_modification objet User last modification
- fk_user_modification id user last modification
- date_validation date validation
- user_validation objet User
- fk_user_validation id user making validation
SQL rules
Table and fields structures
- Structure of tables.
- rowid integer for id - tms timestamp that will contain date of last modification (the database manages this field automatically, no need to manage it by the code, just create the field) - import_key that will contains the import code YYYYMMDDHHMMSS if you make mass import.
Eventualy
- datec timestamp that is the creation date - fk_user_author integer that is the id of user making creation - fk_user_mod integer that is the id of user making change
Note field:
- note_private text for private comment of the object - note_pubic text for public comment of the object
or
- Type of fields:
Well, to be compatible with any accuracy required by any country on amounts, and with any database syntax, we will use the following type into database:
- integer for an any of foreign key - double(24,8) for any amount - double(6,3) for any vat rate - real for a quantity - varchar for a string (also if length is 1, the type char is more and more deprecated) - timestamp for a field date+time that is automatically updated - datetime for a field date+time - date for a field date
- All tables has a prefix to avoid name conflicts with other projects. In current version this prefix is fixed ans can't be modified. Its value is llx_. In a future version this value should be modified during installation process.
Primary keys
Foreign keys
A foreign key name must start with prefix fk_ followed by the table name linked (this is required to avoid duplicate names in project that are not allowed even if on different tables by some DBMS like Postgresql) then the name of child field (this is to allow to have several foreign keys on same table).
Example: fk_facture_fourn_fk_soc is a foreign key on table llx_facture_fourn for field fk_soc in this table (that link to the rowid field in another table)
Alternative keys
Index performance
DDL file format
Files that contain definition of the database structure (DDL files) must be 2 per tables:
- Each table is defined by its own file whose name is llx_mytable.sql
A comment will be added on each field to explain its usage.
- All foreign keys, performance indexes or other constraints will be defined into another file called llx_mytable.key.sql
Those files must be stored into directory install/mysql/tables for all standard files or mymodule/tables for tables provided by an external module.
Example file of table llx_mytable.sql:
create table llx_mytable
field_one integer,
field_two integer NOT NULL,
fk_field integer,
field_date datetime,
fk_user_mod integer NOT NULL, -- Last updater, foreign key of llx_user
import_key varchar(14) -- Use by import process
)type=innodb;
Example file for keys/indexs on llx_mytable.key.sql:
ALTER TABLE llx_matable ADD UNIQUE uk_matable_field(field_one, field_two);
ALTER TABLE llx_matable ADD CONSTRAINT fk_matable_fk_field FOREIGN KEY (fk_field) REFERENCES llx_matablepere (rowid);
SQL Coding rules
- Alias usage/Fields naming
- All SELECT * are forbidden ! Any SELECT must define complete list of fields to get. This avoid confusion. Example:
- Into SQL requests, you must quote fields except fields that contains amounts that must be stored as double or real type. Quotes on numbers may results in saving a different value. For example 412.62 in an insert will be saved with value 412.61999512 into database (due to implicit conversion string to numeric) if target field has type double(24,8). Only PHP see value 412.61999512. Other tools will see 412.62 giving sensation that there is no problem. But it's PHP that hase the good vision. There is really a wrong value into database. By removing quotes on numbers, no problem occurs.
Example:
Good: INSERT INTO table_1 (field_txt, field_num) VALUES ('txt', 412.62)
Bad: INSERT INTO table_1 (field_txt, field_num) VALUES ('txt', '412.62')
Note, problem of float numbers is same problem on all langauges and not only when inserting data into database. It occurs also with any language when you work on "real" numbers, so numbers must be, as soon as they are affected, cleaned with function price2num with second parameter defined to : 'MU' (for unit prices), 'MT' (for total prices) or 'MS' (otherwise) depending on usage of number. (see function documentation)
- Functions NOW or SYSDATE are forbidden inside SQL requests. If you must use the current date into a field, value must come from the PHP and not from the database engine. This is to avoid a better portability of code and a correct management of TimeZone.
Mysql specificities
- Tables must be declared with format InnoDB.
This format support foreign keys and their restrictions, and transactions integrity is also supported. This guarantee that Dolibarr events keep all data with correct values between tables even even transaction modify different tables.
- Dolibarr must works even if Mysql option strict is active.
To activate it (recommanded when developping on Dolibarr), add the following line into the config file of your Mysql server (my.cnf or my.ini)
PostgreSQL specificities
There is an exception The SQL "UPDATE FROM" : Syntax MySQL :
Syntax PgSQL:
There is no native SQL request "update from" in dolibarr core. But in your module you should do :
} else {
HTML norms
Syntax rules
- HTML used must be HTML compliant and not XHTML. All attributes of HTML tags must be in lower case and quoted with ".
- Links href must be absolute and use the function dol_buildpath() to get absolute path from a relative path and img tag must be build using function img_picto().
For example:
- HTML tables must have columns with no forced width, except for columns that contains data we know the length. For example, a column with a picto only can be forced to with="20px".
- Javascript/ajax code and call to javascript files into php pages must be avoided. However, if you need to include javascript code, you must add a condition on "$conf->use_javascript_ajax"
... // php code generating javascript here
- Popups windows must not be used, except for tooltips (and must have a condition as explained before).
- External scripts must be written into Perl if they can't be written into PHP. Usage of another language is not forbidden but must be argue before onto development mailing-list.
External templating framework ?
There is ton of frameworks to provide a templating language of an HTML page. The best and faster is just called "PHP", and because Dolibarr already depends on PHP, there is no need for depend on a third languages.
All templating frameworks are just preprocessor, BEFORE PHP. It can't be faster than PHP alone. When we say "speed, when using cache of templating framework, is increase", it is in fact the overtime spent by the framework that is reduced by cache, not the speed of processing PHP file. We should says "any templating framework has an overload over PHP, the cache of framework, just reduce the slowing effect of using it", but not "the speed is increased, it is always increased".
Above all, having a templating system is completely possible by doing a ".tpl.php" file that dos not contains any logic code, but only HTML and echo. We get same result (but faster and easier to develop because it does not need to do all the setXXX) before calling each template. All variables (known by code that include the template) are automaticaly known into a PHP template page. No risk to forget a set, and a lot of line of codes reduced, a lot of time saved.
Also, keeping a 100% isolation between code and HTML output is interesting in only 1 situation: When teams building design is complety different than team building logic code, AND if you build not too sophisticated pages, AND with no need of too many Ajax features (this need to know how code works). And this situation is surely not the Dolibarr future (team will often be same, Ajax will be more and more present, event if I hope not too much, and screens are more and more dependent of dynamic or contextual events, difficult to have with a template without transforming the template into a page with high level of code).
There is a ton of other reasons to not use an external templating system and all arguments to use them are the best argument to use PHP as our templating system.
Skeleton code
- 1 that serves as an example of the module description: myModule.class.php
- 1 that serves as an example of code for creating a new class: skeleton_class.class.php
- 1 that serves as an example of code for creating a new page: skeleton_page.php
- 1 that serves as an example of code for creating a script for executing command lines: skeleton_script.php
Dates and Timezones
- A date into memory must always be stored with Timestamp GMT format.
- A date stored into database, is the GMT Timestamp of date submitted into the request usng the PHP server timezone. This does not apply to date update automatically by database (fields tms into database).
For exemple le 1st january 1970, 3 hour at Paris (TZ=+1) = 2 hour at Greenwitch (TZ=0) will be stored into memory with value 7200 and will be submitted into a SQL request to database with the string '19700101030000' (PHP convert into its TZ hour and databse will unconvert it using its timezone too that is same than PHP).
- Dates that are updated automatically (field tms into database) contains a GMT Timestamp GMT of date when change is done. The select will also use the db->jdate (that use PHP server TZ) to convert read data into a GMT Timestamp into memory. So if timezone of database differs from timezone of PHP server (one of them is not correctly set), you may experience differences between creation date and update date.
- Manipulation date with PHP must be done using the Dolibarr date functions: dol_now(), dol_mktime(), dol_stringtotime(), dol_getdate(), dol_time_plus_duree(). You may also find other functions available into file date.lib.php.
UTF8/ISO encoding
- In database, data is stored in UTF8 or ISO. It depends on the database's pagecode therefore these options are set at creation time. In any case, Dolibarr's database driver (in lib/database) deals with it to convert from/to UTF8 at insertion and readout.
- Memory data is stored in UTF8 (PHP object instances).
- Screen displayed web pages are UTF8 (for versions prior to 2.5.1, the deprecated $character_set parameter from conf.php file defines output format).
print 239.2 - 229.3 - 9.9;
If data manipulated is not an amount, so using MU, MT, MS has no sense, so you must use the function round().
Creation of tables
Do not create tables, on the fly, during execution by a standard user, we mean, during current usage of software. If you create a module that use its own table not available into default Dolibarr code, take a look at tutorial Module Development that will explain you how roviding new tables with your module to have the created during module activation and not during module usage.
Logs
Working directory
If you need to create a working directory, into your code, refer to it with DOL_DATA_ROOT.'/monmodule'
The directory can be created into your code by the following fnction:
dol_mkdir($mymoduledir);
If you need a directory to store temporary data, this directory must be DOL_DATA_ROOT.'/monmodule/temp'
Patterns of code organization
- The Transaction Script (The source code is linear for each user action).
- The Domain Model
- The Table Module
-> As shown in code skeletons (see previous chapter), Dolibarr use concept of Table Module.
There is 3 way to make links:
- The Table And Row Data Gateway
This is the most simple. You have one class per table and each class is a link to the table with CRUD methods (Ceate, Read, Update, Delete). A class instance is a record a the table. The class contains only code to reach lines and fields of table.
- The Active Record
Same than previous, but we are allowed to add some business functions into the class, if such functions are dedicated to the table or recordng into this table.
Example: This mode is used for Dolibarr development and most PHP softwares that includes their own framework and best practices.
- The Data Mapper
Classes represent entities of the problem and not the data. So you have to double, triple ... theese classes with Mapper classes to access the data. More "purist" on paper (closer of business), this method also has the disadvantage of being more complex in practice.
Example: This is the choice if you use the ORM Framework Propel (http://propel.phpdb.org/trac/). We find this model on heavier applications, based on this ORM among others.
-> For Dolibarr development, it is recommended to use the connection mode Active Record, which offers the advantages of a model close to the business without having the complexity, without obfuscating the technique. It is in this way that the development, understanding of code and technical maintenance and / or business seems the more productive (this is however an ongoing debate between the purists and the pragmatists, debate in which nobody can really be right, because it depends on the objectives).
