Module CustomFields Cases
CustomFields
Numero/ID of module 8500
User doc. of module Module_CustomFields
Developer doc. of module Module_CustomFields_Dev
// ... php code ...
  function __constructor($db) {
// ... php code ...
    $this->name = "crabe";
into:
// ... php code ...
// ... php code ...
    $this->name = "customfields";
 *   	\brief      Show the customfields in a new page
 *   	\param      pdf     		PDF factory
 * 		\param		object			Object invoice/propale/order/etc... (CustomFields simpler functions will automatically adapt)
 *      \param      outputlangs		Object lang for output
    global $conf;
    // Init and main vars
    $pdf->SetY($pdf->GetY()+1);
    // Printing the customfields
        // Get translated label
    return 1;
Alternative function (with a bit less functionalities, but more controllable):
 *   	\brief      Show the customfields in a new page (used to debug if CustomFields setup is correct)
 * 		\param		object			Object invoice/propal/product/whatever...
            if (empty($object->table_element) or empty($object->id)) {
                $pdf->MultiCell(0,3, "Current \$object is not compatible with CustomFields, could not find table_element or id.", 0, 'L');
                return 1;
    include_once(DOL_DOCUMENT_ROOT.'/customfields/class/customfields.class.php');
    $customfields = new CustomFields($this->db, $object->table_element);
            // Fetching custom fields records
            $fields = $customfields->fetch($object->id);
            if (!isset($fields)) {
                $pdf->MultiCell(0,3, "No custom field could be found for this object. Please check your configuration (did you create at least one customfield and set a value in the current datasheet?)", 0, 'L');
                return 1;
            } else {
                foreach ($fields as $key=>$field) {
                        $translatedname = $customfields->findLabelPDF($key, $outputlangs); // label of the customfield
                        $value = $customfields->simpleprintFieldPDF($key, $field, $outputlangs); // value (cleaned and properly formatted) of the customfield
                        $pdf->MultiCell(0,3, $translatedname.': '.$value, 0, 'L'); // printing the customfield
    return 1;
// Pied de page
$pdf->AliasNbPages();
// CustomFields
        $pdf->AddPage();
        $pagenb++;
Conditions categories
  • static condition: choices are restrained on a condition that never changes (eg: only show third-parties that are suppliers, or lowercase all data on sql insertion, or check that a field is above a certain number, etc.).
  • semi-dynamic condition: choices that are constrained on a static table but based on the value of another field/customfield. This is also commonly called "Cascaded dropdown lists" or "Dynamically linked dropdown lists".
  • dynamic: everything is dynamic: choices are based on a subfield of a field of the current module, so that there's no material table and it's impossible to create a view (because you would need to create one view per id) (eg: show only the contacts attached to the third-party being accessed)
  • timed condition: a condition that is based on time or recurrence (eg: at 5:00 AM delete old records, etc..)
Conditions solutions
Static condition
  • Constraint WHERE clause (when creating/editing a custom field, you can specify your own WHERE conditions).
  • View: create a view on the table based on the condition, and then create a custom field constrained on this view (which is just like any table), eg: only show third-parties that are suppliers:
SELECT *
FROM llx_societe
WHERE fournisseur=1;
  • Check
  • Trigger
  • SQL Transformations
  • CustomFields's overload functions
Semi-dynamic condition
  • CustomFields's Cascade option is ideal in most cases, and if not enough, you can use the Cascade Custom option and Overloading Functions.
  • View
  • Check
  • Trigger
Dynamic condition
  • CustomFields's Cascade Custom and Overload functions
  • Recursive Remote Fields Access
  • Making your own module, which calls the CustomFields class
Timed condition
  • SQL scheduled events
  • Cron job
Overloading functions
Here are a few concrete use cases of overloading functions to achieve various goals.
Dynamic list selection based on another one
NOTE: this will show how to manually manage this kind of requirements using overloading functions, but in latest CustomFields releases, the same solution can be achieved automatically using the Cascade option.
1,les 2 alpes,isère
2,chamrousse,isère
3,alpe d'huez,isère
4,vars,alpes du sud
5,risoul,alpes du sud
etc...
In CustomFields's admin panel, we create two custom fields:
1- secteur: returns the list of all zones - type DropdownBox: enum('- Aucun','Alpes du Sud','export','Haute-Savoie','Isère', etc...)
2- station_a: returns the list of all ski resorts - type constraint on llx_k_station
$result=$db->query($sql);
  if ($result) {
    $i = 0;
    $myarray = array();
    while ($i < $num)
      $i++;
    $value = $myarray;
    $db->free($result);
Dynamic discount computation per products lines on propales
The goal here is to compute the discount for a product line in propales based on a computation on three custom fields.
First, create three custom fields for "Line commercial proposals": vl, cpl and lc.
Then add the following overloading function at the end of your customfields_fields_extend.lib.php file (read the comments for more informations):
function customfields_field_save_propaldet_vl (&$currentmodule, &$object, &$action, &$user, &$customfields, &$field, &$name, &$value) {
    // Fetch the new posted values
    // All $_POST data are generically appended into the $object properties
    $vl = $object->{$customfields->varprefix.'vl'};
    $cpl = $object->{$customfields->varprefix.'cpl'};
    $lc = $object->{$customfields->varprefix.'lc'};
    // Compute the discount
    $remise_calculee = (100 - $vl) * (100 - $cpl) * (100 - $lc);
    // Clean parameters
    include_once DOL_DOCUMENT_ROOT.'/core/lib/price.lib.php';
    $remise_calculee = price2num($remise_calculee);
    // Assign the new discount into the PropalLine object
    $object->remise_percent = $remise_calculee;
    // Update the price (it's not automatic when we edit remise_percent and update, we have to recompute manually the prices before calling $object->update())
    global $mysoc;
    $localtaxes_type=getLocalTaxesFromRate($object->tva_tx,0,$mysoc);
    $tabprice=calcul_price_total($object->qty, $object->subprice, $object->remise_percent, $object->tva_tx, $object->localtax1_tx, $object->localtax2_tx, 0, 'HT', $object->info_bits, $object->type, '', $localtaxes_type);
    $object->total_ht  = $tabprice[0];
    $object->total_tva = $tabprice[1];
    $object->total_ttc = $tabprice[2];
    $object->total_localtax1 = $tabprice[9];
    $object->total_localtax2 = $tabprice[10];
    // Update into database
    $object->update(true); // true to disable the trigger, else it will recall customfields, which will call this overloading function, etc. in an infinite loop.
    $object->update_total();
    //$q = "UPDATE  ".MAIN_DB_PREFIX."propaldet SET remise_percent=".$remise_calculee." WHERE  rowid=".$object->rowid;
    //$db->query($q);
    // Finally, cleanup POST data to avoid conflicts next time, reinserting the same discount. Else the fields will remember these values and it may mistakenly reuse the same values.
    unset($_POST[$customfields->varprefix."vl"]);
    unset($_POST[$customfields->varprefix."cpl"]);
    unset($_POST[$customfields->varprefix."lc"]);
Linking Dolibarr objects from two different modules
The key here is to use the llx_element_element table or the llx_element_* tables (eg: llx_element_contact): this is a standard Dolibarr table that stores all links between objects of two different modules.
Here is the structure:
rowid | fk_source | sourcetype | fk_target | targettype
1 | 2 | fichinter | 5 | facture
// Save the intervention's id
$fromobject = new stdClass(); // Init an empty object
Modify the total global price with a coefficient (without tampering the discount)
This is more troublesome than modifying the total price per product/service line, because the total global price of an object (let's say an invoice, but this also works for any other object) is always recomputed by summing the prices and quantity of each product/service line. This means that although there's an entry "total_ttc" in the database to store the invoice's total price, this price is in fact always recomputed, it's never used as-is. Thus, it's useless to change only the database record: we need to inject some code to change how the total price is computed.
This could be done using an overloading function or a trigger, but unluckily, Dolibarr doesn't call a trigger nor a hook when recomputing the price. We thus need to edit core files to do what we want.
However, the bright side is that we can cleverly edit just two functions from one core file: update_price() and getMarginInfos() from /htdocs/core/class/commonobject.class.php , and everything should run smoothly. Beware that if you update Dolibarr, you will need to redo these two modifications in the code.
First, you need to create a new custom field called "global_coefficient" in Invoices (not Invoices Lines!). Then you can continue to the subchapters below.
Also note that this global coefficient is also compatible with per line coefficients (as described in the next chapter), thus you can use a global coefficient and per line coefficients at the same time. You can also use multiple global coefficient if you wish.
Another note: if you have a grid of discounts depending on quantity or price or whatever parameter, you can program a precomputation code using a Custom Ajax function (this way, your discounts will be automatically computed, but then you can still manually enter them for particular cases since the custom field is editable).
Implement the change of global price in most of Dolibarr (including remaining debt to pay and PDF and ODT)
The change we will implement here will reflect the new total price with the global coefficient in most of Dolibarr's code, since we will here change the main function that is usually called to update and get the total price.
Open /htdocs/core/class/commonobject.class.php and look for the function update_price().
You should see the following:
function update_price($exclspec=0,$roundingadjust='none',$nodatabaseupdate=0,$seller='')
    global $conf;
Just below the include_once line, add the following:
// Global coefficient (CustomFields)
include_once DOL_DOCUMENT_ROOT.'/customfields/class/customfields.class.php';
include_once DOL_DOCUMENT_ROOT.'/customfields/conf/conf_customfields_func.lib.php';
$customfields = new CustomFields($this->db, $this->table_element);
// Get object's id (either stored in property "id" or "rowid")
$this_id = (!empty($this->id)) ? $this->id : $this->rowid;
// Load custom fields records
$cf_parent_record = $customfields->fetch($this_id);
This will load the global_coefficient custom field (and also any other custom field you have defined for invoices).
Now scroll below, and you should see this:
while ($i < $num)
    $obj = $this->db->fetch_object($resql);
    ... (lots of code)
    i++;
// Add revenue stamp to total
$this->total_ttc       += isset($this->revenuestamp)?$this->revenuestamp:0;
$this->db->free($resql);
This is the end of the loop that is summing each product/service line price to compute the total price. Just after this loop, you should see this:
// Now update global field total_ht, total_ttc and tva
$fieldht='total_ht';
$fieldtva='tva';
$fieldlocaltax1='localtax1';
$fieldlocaltax2='localtax2';
$fieldttc='total_ttc';
// Specific code for backward compatibility with old field names
if ($this->element == 'facture' || $this->element == 'facturerec')             $fieldht='total';
if ($this->element == 'facture_fourn' || $this->element == 'invoice_supplier') $fieldtva='total_tva';
if ($this->element == 'propal')                                                $fieldttc='total';
Between those two blocks of code (so just above // Now update global field total_ht, total_ttc and tva), you can place the following:
if (!empty($cf_parent_record->global_coefficient)) { // avoid applying the coefficient if empty (this will return a 0 price)
    $this->total_ht = $this->total_ht * $cf_parent_record->global_coefficient;
    $this->total_tva = $this->total_tva * $cf_parent_record->global_coefficient;
    $this->total_ttc = $this->total_ttc * $cf_parent_record->global_coefficient;
Done, now try to add/edit a product/service line, and the total price should be affected by the global coefficient.
Note that this modification needs only to be done once for all modules, you then just have to create a custom field named "global_coefficient" in every module you want to apply this coefficient.
Implementing the change of price in margin module
If you enabled the margin module, you should see that the coefficient is not applied there, but it's easy to fix that.
Open the file /htdocs/core/class/commonobject.class.php and find the function getMarginInfos(), then inside find the following lines:
foreach($this->lines as $line) {
    if (empty($line->pa_ht) && isset($line->fk_fournprice) && !$force_price) {
        $product = new ProductFournisseur($this->db);
        if ($product->fetch_product_fournisseur_price($line->fk_fournprice))
            $line->pa_ht = $product->fourn_unitprice * (1 - $product->fourn_remise_percent / 100);
        if (isset($conf->global->MARGIN_TYPE) && $conf->global->MARGIN_TYPE == "2" && $product->fourn_unitcharges > 0)
            $line->pa_ht += $product->fourn_unitcharges;
    // si prix d'achat non renseigné et devrait l'être, alors prix achat = prix vente
    if ((!isset($line->pa_ht) || $line->pa_ht == 0) && $line->subprice > 0 && (isset($conf->global->ForceBuyingPriceIfNull) && $conf->global->ForceBuyingPriceIfNull == 1)) {
        $line->pa_ht = $line->subprice * (1 - ($line->remise_percent / 100));
This is where the lines are filled with margin infos. The price has just been fetched here, and we will now modify it with the coefficient before the price gets used for margin computation.
To optimize things up, we will load the custom fields before the loop (because they don't change between product/service lines, they are the custom fields of the parent object), and then apply the global_coefficient inside the loop.
Just above the code we found (just before the for loop), paste the following:
$customfields = customfields_fill_object($this);
And now, just below the code we found, inside the loop (and just above the comment: "// calcul des marges"), paste the following:
// Apply the coefficient
if (!empty($this->customfields->cf_global_coefficient)) {
    $line->pa_ht = $line->pa_ht * $this->customfields->cf_global_coefficient;
    $line->subprice = $line->subprice * $this->customfields->cf_global_coefficient;
Note that here we cheated a bit: we do not compute the coefficient on the global total price, but rather per product/service line price. This is done on purpose, because mathematically this should produce no difference, and it also allows Dolibarr to continue peacefully with its margin calculations (else we would have to adapt all those computations, which would imply a lot more of code changes!).
That's all, the price should be reflected in the margin. Just refresh the page to reflect the change.
Refresh the price instantly
Maybe you noticed one glitch: when you modify the global_coefficient, the global total price isn't updated until you add/edit a product/service line. This is because the update_price() function is only called when we add/edit a product/service line.
To fix that, we need now to force the refreshing of price. To do that, we will use an "aftersave" overloading function, which will execute commands after our custom field is saved.
Go to the folder /htdocs/customfields/fields and rename the file customfields_fields_extend.lib.php.example into customfields_fields_extend.lib.php .
Now, open it in your favourite text editor, and add the following function :
function customfields_field_aftersave_facture_global_coefficient (&$currentmodule, &$object, &$action, &$user, &$customfields, &$field, &$name, &$value, $fields) {
    // Force refreshing total price
    $object->update_price(0, 'auto');
That's all. Now, when you edit your global_coefficient, this will force refresh the total price.
However, you will still notice one last glitch: when you edit the global_coefficient, the total price isn't reflected instantly, you must refresh the webpage once to see the new price. This is because of how the datasheet and the CustomFields hook are designed: CustomFields is called only exactly where the custom fields are place, thus it is called after the total price, the margin and the remaining debt are printed. Thus, CustomFields updates the value of your custom field only after all those informations get printed, and thus it cannot modify them at this stage. That's why those information are out-of-date, and you must refresh the webpage once to get to see the latest values.
There is a workaround for this: refresh automatically the webpage (but delete the POST data to avoid an infinite loop). You just need to use this overloading code instead of the one above:
    // Force refresh the page to update prices that were printed before the custom field aftersave was triggered (and only if not creating the object because then there's no need to refresh)
    if ($action !== 'add') print('<script type="text/javascript">window.location.href = window.location.pathname + window.location.search;</script>');
Another way to fix this issue would be to modify how CustomFields save the custom fields, by moving this stage at the very top. However, this would need another hook, which should be called at the very beginning of the page loading, which should be made only for this purpose (PageLoading), and should be available in all modules supported by CustomFields in order to not break anything.
Note that you will need to create one overloading function for each module you want to support with the global_coefficient custom field. For example, if you want to support both invoices and commercial proposals, you will need two overloading functions:
// Global coefficient for invoices (note the "facture" in the name of the function)
// Global coefficient for commercial proposals (note the "propal" in the name of the function)
function customfields_field_aftersave_propal_global_coefficient (&$currentmodule, &$object, &$action, &$user, &$customfields, &$field, &$name, &$value, $fields) {
Modify the total price PER product/service line with a coefficient (without tampering the discount)
Here we will go through the creation and management of a custom field called coefficient that will change the total price of each product by modifying it by the coefficient.
NOTE: this will not create a coefficient per product but rather per product's line. Thus if you want to create a coefficient that never change between invoices but only depending on the product and stays static, please refer to the next chapter below about creating a custom tax per product.
The preliminary and necessary step is to first create a custom field that will be used to modify the total price. We will create one for Client Invoice Lines.
When you go to client invoices in Dolibarr, you should then see something similar to this: Cfe1.jpg You can see that our coefficient field was successfully created.
Then here are two alternative ways of implementing the change of the total price of each product relativery to this coefficient.
Change total price in database
Here we will use a "save" overloading function to change the total price directly in the database, thus we won't have to modify anything else (eg: nor PDF templating nor ODT) since the total price will be already updated in the database.
Warning: this method will work only with CustomFields => 3.2.23 since the "save" overloading function did not work for products lines before.
Just add the following overloading function in your customfields_fields_extend.lib.php file:
function customfields_field_save_facturedet_coefficient (&$currentmodule, &$object, &$action, &$user, &$customfields, &$field, &$name, &$value) {
    $coefficient = $object->{$customfields->varprefix.'coefficient'}; // you could also use $coefficient = $value;
    // Clean parameters
    $coefficient = price2num($coefficient);
    // Get the original subprices (it's not automatic when we edit remise_percent and update, we have to recompute manually the prices before calling $object->update())
    global $mysoc;
    // Update the subprices with the coefficient
    $object->total_ht = $object->total_ht * $coefficient; // compute no tax price
    $object->total_tva = $object->total_tva * $coefficient; // compute tax amount
    $object->total_ttc = $object->total_ttc * $coefficient; // compute tax included price
    $object->update('',true); // true to disable the trigger, else it will recall customfields, which will call this overloading function, etc. in an infinite loop.
    unset($_POST[$customfields->varprefix."coefficient"]);
This should show the correct total price on the Dolibarr's interface without modifying the unit subprice (P.U. Unit):
You have nothing to edit in your PDF or ODT template, since the new subprice with applied coefficient will be automatically printed instead of the old one without coefficient.
Change printed total price per product without tampering the subprice in the database
Here is a way to change the printed total price (the one shown on screen and in PDF/ODT) but without changing the total price in the database.
The following sub-chapters are all independent, thus you can only follow the ones that you require, eg: if you only need to change the price in your PDF documents, just create a custom field then jump to the sub-chapter to Implement the change of price in PDF.
Implementing the change of price in ODT templates
You can either create your own module, then create your own substitution function, but for the sake of simplicity in this tutorial, we will directly use the CustomFields substitution function. However, please remember that you will have to redo your changes everytime you will update the CustomFields module, so if you don't want to do that it would be better if you create your own module and substitution function.
At the very end of this function, but inside the customfields check:
But just before the ending bracket, you should add the following code:
if ($object->table_element_line === 'facturedet') { // First check that we are in the right module, we don't want to use coefficient for other modules if we didn't define the custom field there
    $substitutionarray['line_price_full'] = $substitutionarray['line_price_ttc'] * $substitutionarray['cf_coefficient']; // multiply the total price with our coefficient
Implementing the change of price in PDF templates
First, we will create our own PDF template by copying an existing template, and then we will edit it to change the price of items.
Creating your own PDF template by copying an existing template
Go into the following folder: htdocs/core/modules/facture/doc/, then copy the file pdf_crabe.modules.php and name the new one pdf_crabecoeff.modules.php.
Then open it in your favourite editor, and change the following lines:
class pdf_crabe extends ModelePDFFactures // change pdf_crabe into pdf_crabecoeff
    function __construct($db)
	$this->name = "crabe"; // change "crabe" into "crabecoeff"
That's it, now you have your own PDF template!
Now you should enable your PDF template before doing anything else, by going into the Modules Administration panel, and into the Invoice admin page, then click on the ON button at the right of the crabecoeff entry to enable the template.
Now, let's proceed onto modifying the prices.
Changing the prices automatically in your PDF
You can now do pretty much anything you want in your PDF template, but I will give you a mean to automatically change the prices of every products with our coefficient, as well as the total price, without editing too much the template.
First, try to find the following code of line (should be inside the write_file() method):
Now, just copy/paste the following code below pdf_getInstance():
// Resetting every $object price because we will compute them anew
$object->total_ht = 0;
$object->total_tva = 0;
$object->total_ttc = 0;
// For each line of product/service, we will recompute all the prices
foreach($object->lines as $line) {
    // Get the coefficient custom field's value for the current line
    $coeff = $object->customfields->lines->{$line->rowid}->cf_coefficient;
    // Recompute the price of this product/service line
    $line->total_ht = $line->total_ht*$coeff; // compute no tax price
    $line->total_tva = $line->total_tva*$coeff; // compute tax amount
    $line->total_ttc = $line->total_ttc*$coeff; // compute tax included price
    // Do the sum of all new products/services prices and tva (will be incremented with every product/service line)
    $object->total_ht += $line->total_ht; // global no tax price
    $object->total_tva += $line->total_tva; // global vat/tax amount
    $object->total_ttc += $line->total_ttc; // global  tax included price
That's it, now you should try to generate your PDF document, and you should get something like this: Cfe3.jpg
Note: printing the coefficient as a column in your PDF document is also possible but will not be covered here because PDF templates will vary for every persons depending on your needs. For guidelines about how to do this, you can read the documentation on how to create a PDF template and how to use custom fields in PDF templates.
Hint: you should be looking inside the following conditional block, inside the write_file() method:
// Loop on each lines
for ($i = 0 ; $i < $nblignes ; $i++)
Implementing the change of total price in the Dolibarr interface
Unluckily there is not (yet) any hooking context to modify how lines of products/services are printed, thus the only thing you can do is directly edit the template file and manually put inside your code to load your custom field and print it the way you want using HTML formatting, for our example:
  • For Dolibarr 3.3 and above, edit the file htdocs/core/tpl/objectline_view.tpl.php
  • For Dolibarr 3.1 and 3.2, edit the file htdocs/core/tpl/freeproductline_view.tpl.php AND predefinedproductline_view.tpl.php (apply the same changes to both files)
In the template file you opened, find the following code:
And replace it by:
<?php
$linecf = new stdClass();
$linecf->id = (!empty($line->id))?$line->id:$line->rowid;
$linecf->table_element = $object->table_element_line; // you can use $object->table_element_line here instead of 'facturedet' if you want this feature to work for every module supported by CustomFields
// Modifying the HT price and printing it on the Dolibarr's datasheet interface
// Applying a multiplying/dividing coefficient to an HT price will give a mathematically correct TTC price since the taxes are also a multiplier
// However, if you want to apply other mathematical operations (like addition or substaction), you should use the total price with $line->total_ttc
if (!empty($linecf->customfields->cf_coefficient)) {
    echo price($line->total_ht * $linecf->customfields->cf_coefficient);
} else {
This should produce something like this: Cfe2.jpg
Technical note: here we are using customfields_fill_object() instead of customfields_fill_object_lines() (the latter being specifically adapted to lines and thus should theoretically be used here) for performance reasons because the template file we are editing is called in a loop, and customfields_fill_object_lines() should be called outside a loop (because it already does the job that is done by the loop), so here we 'tricks' the customfields_fill_object() function to avoid this loop by submitting 'facturedet' as a module by itself (when in fact it's a product lines table, but it works the same way nevertheless). This is a good demonstration of the flexibility of the CustomFields functions and methods.
Implementing the coefficient column in the Dolibarr interface
It's also possible to show the coefficient in a new column on the Dolibarr interface.
To do that, you need to do two things:
1- Add the column title "Coeff."
2- Add the generator that will input the coefficient value for each line.
Open in your favourite editor the file /htdocs/core/class/commonobject.class.php and inside the function printObjectLines (note the plural s), find the following lines of code:
// Total HT
print '<td align="right" width="50">'.$langs->trans('TotalHTShort').'</td>';
This is what prints the Total HT price column. We will place the Coeff column just before.
So, just above this code, add the following:
// Coefficient (CustomFields)
dol_include_once('/customfields/class/customfields.class.php');
$customfields = new CustomFields($this->db, $object->table_element_line);
$coeff_field = $customfields->fetchFieldStruct('coefficient');
if (!empty($coeff_field)) {
    print '<td align="right" width="50">'.$langs->trans('Coeff.').'</td>';
This will take care of showing the Coeff. column, but only for modules where you created such a custom field (because the file we modified is a common object for all modules in Dolibarr, not just invoices, thus this modification will gracefully skip this custom field if it does not exists for other modules).
Add the generator
Open the file /htdocs/core/tpl/objectline_view.tpl.php and try to find the following block of code:
<?php if ($line->special_code == 3)	{ ?>
<td align="right" class="nowrap"><?php $coldisplay++; ?><?php echo $langs->trans('Option'); ?></td>
<?php } else { ?>
<td align="right" class="nowrap"><?php $coldisplay++; ?><?php echo price($line->total_ht); ?></td>
<?php } ?>
This is what prints the total HT price value for each line.
Just above of this block of code, add the following:
<?php
$linecf->table_element = $object->table_element_line; // you can use $this->table_element_line here instead of 'facturedet' if you want this feature to work for every module supported by CustomFields
if (isset($linecf->customfields->cf_coefficient)) {
    <td align="right" class="nowrap"><?php $coldisplay++; ?><?php echo $linecf->customfields->cf_coefficient; ?></td>
<?php } ?>
Just like for the column title, this code will take care of generating the coefficient value only if the custom field is defined, because this file is also a generic template for all modules of Dolibarr.
At this point, everything is done, you should see the following: Cf wiki coeff column.png
Just below the code we found, paste the following:
$linecf->table_element = $line->table_element;
    $line->pa_ht = $line->pa_ht * $linecf->customfields->cf_coefficient;
    $line->subprice = $line->subprice * $linecf->customfields->cf_coefficient;
That's all, the price should be reflected in the margin. Cf wiki coeff margin.png
Implementing the change of price in remaining debt to pay
    global $conf;
$customfields = new CustomFields($this->db, $this->table_element_line);
// Fetching line ids from parent object id
$line_ids = $customfields->fetchAny('rowid', MAIN_DB_PREFIX.$this->table_element_line, $this->fk_element.' = '.$this->id);
$line_ids = array_values_recursive('rowid', $line_ids);
$cf_records = $customfields->fetch($line_ids);
// Reassociate the records with the line id (instead of the customfields record id)
$cf_line_cfrowid_to_rowid = array_reassociate('rowid', 'fk_'.$this->table_element_line, $cf_records);
$tmp = $cf_records;
$cf_records = array();
foreach ($tmp as $k=>$v) { $cf_records[$cf_line_cfrowid_to_rowid[$k]] = $tmp[$k]; }
This will load the coefficient custom field (and also any other custom field you have defined for lines).
while ($i < $num)
    // Note: There is no check on detail line and no check on total, if $forcedroundingmode = 'none'
    if ($forcedroundingmode == '0')	// Check if data on line are consistent. This may solve lines that were not consistent because set with $forcedroundingmode='auto'
        $localtax_array=array($obj->localtax1_type,$obj->localtax1_tx,$obj->localtax2_type,$obj->localtax2_tx);
        $tmpcal=calcul_price_total($obj->qty, $obj->up, $obj->remise_percent, $obj->vatrate, $obj->localtax1_tx, $obj->localtax2_tx, 0, 'HT', $obj->info_bits, $obj->product_type, $seller, $localtax_array);
        $diff=price2num($tmpcal[1] - $obj->total_tva, 'MT', 1);
        if ($diff)
            $sqlfix="UPDATE ".MAIN_DB_PREFIX.$this->table_element_line." SET ".$fieldtva." = ".$tmpcal[1].", total_ttc = ".$tmpcal[2]." WHERE rowid = ".$obj->rowid;
            dol_syslog('We found unconsistent data into detailed line (difference of '.$diff.') for line rowid = '.$obj->rowid." (total vat of line calculated=".$tmpcal[1].", database=".$obj->total_tva."). We fix the total_vat and total_ttc of line by running sqlfix = ".$sqlfix);
            $resqlfix=$this->db->query($sqlfix);
            if (! $resqlfix) dol_print_error($this->db,'Failed to update line');
            $obj->total_tva = $tmpcal[1];
            $obj->total_ttc = $tmpcal[2];
Just after, add the following:
$cf_coeff = $cf_records[$obj->rowid]->coefficient;
if (empty($cf_coeff) and $cf_coeff !== 0) $cf_coeff = 1; // by default, an empty coefficient = 1
$obj->total_ht = $obj->total_ht * $cf_coeff;
$obj->total_tva = $obj->total_tva * $cf_coeff;
$obj->total_localtax1 = $obj->total_localtax1 * $cf_coeff;
$obj->total_localtax2 = $obj->total_localtax2 * $cf_coeff;
$obj->total_ttc = $obj->total_ttc * $cf_coeff;
This should do the trick. Now go to one of your invoices (or whatever module you are targetting), and try to add/edit a product/service line to force refresh the total price. You should then see this: Cf wiki coeff remaining debt.png
Custom tax per product
This part will show you how to create a static custom tax per product. Static means that the tax will be stored per product, and not per product's line, thus you just have to setup the tax once per product and it will always be applied in every invoice you add this product.
To do that, you will need the CustomFields Pro module + ProductsEasyAccess.
1- Create a product's custom fields called "custom_tax". Now, using ProductsEasyAccess, you can access this field wherever you wants, either to show it on the Dolibarr's interface (see previous chapter), or in a PDF template, which we will describe below.
2- Modify your invoice's PDF template. You first need to load all the products' fields before the loop over the products' lines. To do this, search for a line like this:
// This should be placed above the "loop lines" below, add this:
dol_include_once('/productseasyaccess/lib/productseasyaccess.lib.php');
fill_object_with_products_fields($object);
// Loop on each lines, search for this command
  // Add this just below the for loop, this will ease your php manipulation after.
  // This will allow you to more easily access the products' fields (this will store the id of each product inside $lineproductid).
  $line_product_id = $object->lines[$i]->fk_product;
4- You can now use your products' fields in your PDF. To access the custom_tax field, just use:
$object->productslines->$line_product_id->cf_custom_tax
And to print it in your PDF:
$pdf->MultiCell(0,3, $object->productslines->$line_product_id->cf_custom_tax, 0, 'L');
5- Then, if you want to count the custom tax total and add it to your vat total, you can create a counter inside the for loop we cited in the first step:
$object->total_custom_tax = 0; // Initialize the custom tax total counter
  $object->total_custom_tax += $object->productslines->$line_product_id->cf_custom_tax;
Then find inside the function **_tableau_tot**, find the following line:
$pdf->MultiCell($largcol2, $tab2_hl, price($sign * $object->total_ttc, 0, $outputlangs), $useborder, 'R', 1);
And prepend the total modification like this:
$object->total_ttc = $object->total_ttc + $object->total_custom_tax; // prepend this to add the custom tax to the total
Done. This should show your custom tax per product and your total including all custom taxes.
