Module CustomFields Cases
CustomFields | |
Numero/ID of module | 8500 |
User doc. of module | Module_CustomFields |
Developer doc. of module | Module_CustomFields_Dev |
// ... php code ...
function __constructor($db) {
// ... php code ...
$this->name = "crabe";
into:
// ... php code ...
// ... php code ...
$this->name = "customfields";
* \brief Show the customfields in a new page
* \param pdf PDF factory
* \param object Object invoice/propale/order/etc... (CustomFields simpler functions will automatically adapt)
* \param outputlangs Object lang for output
global $conf;
// Init and main vars
$pdf->SetY($pdf->GetY()+1);
// Printing the customfields
// Get translated label
return 1;
Alternative function (with a bit less functionalities, but more controllable):
* \brief Show the customfields in a new page (used to debug if CustomFields setup is correct)
* \param object Object invoice/propal/product/whatever...
if (empty($object->table_element) or empty($object->id)) {
$pdf->MultiCell(0,3, "Current \$object is not compatible with CustomFields, could not find table_element or id.", 0, 'L');
return 1;
include_once(DOL_DOCUMENT_ROOT.'/customfields/class/customfields.class.php');
$customfields = new CustomFields($this->db, $object->table_element);
// Fetching custom fields records
$fields = $customfields->fetch($object->id);
if (!isset($fields)) {
$pdf->MultiCell(0,3, "No custom field could be found for this object. Please check your configuration (did you create at least one customfield and set a value in the current datasheet?)", 0, 'L');
return 1;
} else {
foreach ($fields as $key=>$field) {
$translatedname = $customfields->findLabelPDF($key, $outputlangs); // label of the customfield
$value = $customfields->simpleprintFieldPDF($key, $field, $outputlangs); // value (cleaned and properly formatted) of the customfield
$pdf->MultiCell(0,3, $translatedname.': '.$value, 0, 'L'); // printing the customfield
return 1;
// Pied de page
$pdf->AliasNbPages();
// CustomFields
$pdf->AddPage();
$pagenb++;
Conditions categories
- static condition: choices are restrained on a condition that never changes (eg: only show third-parties that are suppliers, or lowercase all data on sql insertion, or check that a field is above a certain number, etc.).
- semi-dynamic condition: choices that are constrained on a static table but based on the value of another field/customfield. This is also commonly called "Cascaded dropdown lists" or "Dynamically linked dropdown lists".
- dynamic: everything is dynamic: choices are based on a subfield of a field of the current module, so that there's no material table and it's impossible to create a view (because you would need to create one view per id) (eg: show only the contacts attached to the third-party being accessed)
- timed condition: a condition that is based on time or recurrence (eg: at 5:00 AM delete old records, etc..)
Conditions solutions
Static condition
- View: create a view on the table based on the condition, and then create a custom field constrained on this view (which is just like any table), eg: only show third-parties that are suppliers:
SELECT *
FROM llx_societe
WHERE fournisseur=1;
- Check
- Trigger
- SQL Transformations
- CustomFields's overload functions
Semi-dynamic condition
- CustomFields's Cascade option is ideal in most cases, and if not enough, you can use the Cascade Custom option and Overloading Functions.
- View
- Check
- Trigger
Dynamic condition
- CustomFields's Cascade Custom and Overload functions
- Making your own module, which calls the CustomFields class
Timed condition
- SQL scheduled events
- Cron job
Overloading functions
Here are a few concrete use cases of overloading functions to achieve various goals.
Dynamic list selection based on another one
NOTE: this will show how to manually manage this kind of requirements using overloading functions, but in latest CustomFields releases, the same solution can be achieved automatically using the Cascade option.
1,les 2 alpes,isère 2,chamrousse,isère 3,alpe d'huez,isère 4,vars,alpes du sud 5,risoul,alpes du sud etc...
In CustomFields's admin panel, we create two custom fields:
1- secteur: returns the list of all zones - type DropdownBox: enum('- Aucun','Alpes du Sud','export','Haute-Savoie','Isère', etc...)
2- station_a: returns the list of all ski resorts - type constraint on llx_k_station
$result=$db->query($sql);
if ($result) {
$i = 0;
$myarray = array();
while ($i < $num)
$i++;
$value = $myarray;
$db->free($result);
Dynamic discount computation per products lines on propales
The goal here is to compute the discount for a product line in propales based on a computation on three custom fields.
First, create three custom fields for "Line commercial proposals": vl, cpl and lc.
Then add the following overloading function at the end of your customfields_fields_extend.lib.php file (read the comments for more informations):
function customfields_field_save_propaldet_vl (&$currentmodule, &$object, &$action, &$user, &$customfields, &$field, &$name, &$value) {
// Fetch the new posted values
// All $_POST data are generically appended into the $object properties
$vl = $object->{$customfields->varprefix.'vl'};
$cpl = $object->{$customfields->varprefix.'cpl'};
$lc = $object->{$customfields->varprefix.'lc'};
// Compute the discount
$remise_calculee = (100 - $vl) * (100 - $cpl) * (100 - $lc);
// Clean parameters
include_once DOL_DOCUMENT_ROOT.'/core/lib/price.lib.php';
$remise_calculee = price2num($remise_calculee);
// Assign the new discount into the PropalLine object
$object->remise_percent = $remise_calculee;
// Update the price (it's not automatic when we edit remise_percent and update, we have to recompute manually the prices before calling $object->update())
global $mysoc;
$localtaxes_type=getLocalTaxesFromRate($object->tva_tx,0,$mysoc);
$tabprice=calcul_price_total($object->qty, $object->subprice, $object->remise_percent, $object->tva_tx, $object->localtax1_tx, $object->localtax2_tx, 0, 'HT', $object->info_bits, $object->type, '', $localtaxes_type);
$object->total_ht = $tabprice[0];
$object->total_tva = $tabprice[1];
$object->total_ttc = $tabprice[2];
$object->total_localtax1 = $tabprice[9];
$object->total_localtax2 = $tabprice[10];
// Update into database
$object->update(true); // true to disable the trigger, else it will recall customfields, which will call this overloading function, etc. in an infinite loop.
$object->update_total();
//$q = "UPDATE ".MAIN_DB_PREFIX."propaldet SET remise_percent=".$remise_calculee." WHERE rowid=".$object->rowid;
//$db->query($q);
// Finally, cleanup POST data to avoid conflicts next time, reinserting the same discount. Else the fields will remember these values and it may mistakenly reuse the same values.
unset($_POST[$customfields->varprefix."vl"]);
unset($_POST[$customfields->varprefix."cpl"]);
unset($_POST[$customfields->varprefix."lc"]);
Linking Dolibarr objects from two different modules
The key here is to use the llx_element_element table or the llx_element_* tables (eg: llx_element_contact): this is a standard Dolibarr table that stores all links between objects of two different modules.
Here is the structure:
rowid | fk_source | sourcetype | fk_target | targettype ------------------------------------------------------- 1 | 2 | fichinter | 5 | facture
// Save the intervention's id
$fromobject = new stdClass(); // Init an empty object
Modify the total price of every product/service line with a coefficient (without tampering the discount)
Here we will go through the creation and management of a custom field called coefficient that will change the total price of each product by modifying it by the coefficient.
NOTE: this will not create a coefficient per product but rather per product's line. Thus if you want to create a coefficient that never change between invoices but only depending on the product and stays static, please refer to the next chapter below about creating a custom tax per product.
The preliminary and necessary step is to first create a custom field that will be used to modify the total price. We will create one for Client Invoice Lines.
When you go to client invoices in Dolibarr, you should then see something similar to this:
You can see that our coefficient field was successfully created.
Then here are two alternative ways of implementing the change of the total price of each product relativery to this coefficient.
Change total price in database
Here we will use a "save" overloading function to change the total price directly in the database, thus we won't have to modify anything else (eg: nor PDF templating nor ODT) since the total price will be already updated in the database.
Warning: this method will work only with CustomFields => 3.2.23 since the "save" overloading function did not work for products lines before.
Just add the following overloading function in your customfields_fields_extend.lib.php file:
function customfields_field_save_facturedet_coefficient (&$currentmodule, &$object, &$action, &$user, &$customfields, &$field, &$name, &$value) {
$coefficient = $object->{$customfields->varprefix.'coefficient'}; // you could also use $coefficient = $value;
// Clean parameters
$coefficient = price2num($coefficient);
// Get the original subprices (it's not automatic when we edit remise_percent and update, we have to recompute manually the prices before calling $object->update())
global $mysoc;
// Update the subprices with the coefficient
$object->total_ht = $object->total_ht * $coefficient; // compute no tax price
$object->total_tva = $object->total_tva * $coefficient; // compute tax amount
$object->total_ttc = $object->total_ttc * $coefficient; // compute tax included price
$object->update('',true); // true to disable the trigger, else it will recall customfields, which will call this overloading function, etc. in an infinite loop.
unset($_POST[$customfields->varprefix."coefficient"]);
This should show the correct total price on the Dolibarr's interface without modifying the unit subprice (P.U. Unit):
You have nothing to edit in your PDF or ODT template, since the new subprice with applied coefficient will be automatically printed instead of the old one without coefficient.
Change printed total price per product without tampering the subprice in the database
Here is a way to change the printed total price (the one shown on screen and in PDF/ODT) but without changing the total price in the database.
The following sub-chapters are all independent, thus you can only follow the ones that you require, eg: if you only need to change the price in your PDF documents, just create a custom field then jump to the sub-chapter to Implement the change of price in PDF.
Implementing the change of price in ODT templates
You can either create your own module, then create your own substitution function, but for the sake of simplicity in this tutorial, we will directly use the CustomFields substitution function. However, please remember that you will have to redo your changes everytime you will update the CustomFields module, so if you don't want to do that it would be better if you create your own module and substitution function.
At the very end of this function, but inside the customfields check:
But just before the ending bracket, you should add the following code:
if ($object->table_element_line === 'facturedet') { // First check that we are in the right module, we don't want to use coefficient for other modules if we didn't define the custom field there
$substitutionarray['line_price_full'] = $substitutionarray['line_price_ttc'] * $substitutionarray['cf_coefficient']; // multiply the total price with our coefficient
Implementing the change of price in PDF templates
First, we will create our own PDF template by copying an existing template, and then we will edit it to change the price of items.
Creating your own PDF template by copying an existing template
Go into the following folder: htdocs/core/modules/facture/doc/, then copy the file pdf_crabe.modules.php and name the new one pdf_crabecoeff.modules.php.
Then open it in your favourite editor, and change the following lines:
class pdf_crabe extends ModelePDFFactures // change pdf_crabe into pdf_crabecoeff
function __construct($db)
$this->name = "crabe"; // change "crabe" into "crabecoeff"
That's it, now you have your own PDF template!
Now you should enable your PDF template before doing anything else, by going into the Modules Administration panel, and into the Invoice admin page, then click on the ON button at the right of the crabecoeff entry to enable the template.
Now, let's proceed onto modifying the prices.
Changing the prices automatically in your PDF
You can now do pretty much anything you want in your PDF template, but I will give you a mean to automatically change the prices of every products with our coefficient, as well as the total price, without editing too much the template.
First, try to find the following code of line (should be inside the write_file() method):
Now, just copy/paste the following code below pdf_getInstance():
// Resetting every $object price because we will compute them anew
$object->total_ht = 0;
$object->total_tva = 0;
$object->total_ttc = 0;
// For each line of product/service, we will recompute all the prices
foreach($object->lines as $line) {
// Get the coefficient custom field's value for the current line
$coeff = $object->customfields->lines->{$line->rowid}->cf_coefficient;
// Recompute the price of this product/service line
$line->total_ht = $line->total_ht*$coeff; // compute no tax price
$line->total_tva = $line->total_tva*$coeff; // compute tax amount
$line->total_ttc = $line->total_ttc*$coeff; // compute tax included price
// Do the sum of all new products/services prices and tva (will be incremented with every product/service line)
$object->total_ht += $line->total_ht; // global no tax price
$object->total_tva += $line->total_tva; // global vat/tax amount
$object->total_ttc += $line->total_ttc; // global tax included price
That's it, now you should try to generate your PDF document, and you should get something like this:
Note: printing the coefficient as a column in your PDF document is also possible but will not be covered here because PDF templates will vary for every persons depending on your needs. For guidelines about how to do this, you can read the documentation on how to create a PDF template and how to use custom fields in PDF templates.
Hint: you should be looking inside the following conditional block, inside the write_file() method:
// Loop on each lines
for ($i = 0 ; $i < $nblignes ; $i++)
Implementing the change of price in the Dolibarr interface
Unluckily there is not (yet) any hooking context to modify how lines of products/services are printed, thus the only thing you can do is directly edit the template file and manually put inside your code to load your custom field and print it the way you want using HTML formatting, for our example:
- For Dolibarr 3.3 and above, edit the file htdocs/core/tpl/objectline_view.tpl.php
- For Dolibarr 3.1 and 3.2, edit the file htdocs/core/tpl/freeproductline_view.tpl.php AND predefinedproductline_view.tpl.php (apply the same changes to both files)
In the template file you opened, find the following code:
And replace it by:
<?php
$linecf = new stdClass();
$linecf->id = $line->rowid;
$linecf->table_element = 'facturedet'; // you can use $this->table_element_line here instead of 'facturedet' if you want this feature to work for every module supported by CustomFields
// Modifying the HT price and printing it on the Dolibarr's datasheet interface
// Applying a multiplying/dividing coefficient to an HT price will give a mathematically correct TTC price since the taxes are also a multiplier
// However, if you want to apply other mathematical operations (like addition or substaction), you should use the total price with $line->total_ttc
echo price($line->total_ht * $linecf->customfields->cf_coefficient);
This should produce something like this:
Technical note: here we are using customfields_fill_object() instead of customfields_fill_object_lines() (the latter being specifically adapted to lines and thus should theoretically be used here) for performance reasons because the template file we are editing is called in a loop, and customfields_fill_object_lines() should be called outside a loop (because it already does the job that is done by the loop), so here we 'tricks' the customfields_fill_object() function to avoid this loop by submitting 'facturedet' as a module by itself (when in fact it's a product lines table, but it works the same way nevertheless). This is a good demonstration of the flexibility of the CustomFields functions and methods.
Custom tax per product
This part will show you how to create a static custom tax per product. Static means that the tax will be stored per product, and not per product's line, thus you just have to setup the tax once per product and it will always be applied in every invoice you add this product.
To do that, you will need the CustomFields Pro module + ProductsEasyAccess.
1- Create a product's custom fields called "custom_tax". Now, using ProductsEasyAccess, you can access this field wherever you wants, either to show it on the Dolibarr's interface (see previous chapter), or in a PDF template, which we will describe below.
2- Modify your invoice's PDF template. You first need to load all the products' fields before the loop over the products' lines. To do this, search for a line like this:
// This should be placed above the "loop lines" below, add this:
dol_include_once('/productseasyaccess/lib/productseasyaccess.lib.php');
fill_object_with_products_fields($object);
// Loop on each lines, search for this command
// Add this just below the for loop, this will ease your php manipulation after.
// This will allow you to more easily access the products' fields (this will store the id of each product inside $lineproductid).
$line_product_id = $object->lines[$i]->fk_product;
4- You can now use your products' fields in your PDF. To access the custom_tax field, just use:
$object->productslines->$line_product_id->cf_custom_tax
And to print it in your PDF:
$pdf->MultiCell(0,3, $object->productslines->$line_product_id->cf_custom_tax, 0, 'L');
5- Then, if you want to count the custom tax total and add it to your vat total, you can create a counter inside the for loop we cited in the first step:
$object->total_custom_tax = 0; // Initialize the custom tax total counter
$object->total_custom_tax += $object->productslines->$line_product_id->cf_custom_tax;
Then find inside the function **_tableau_tot**, find the following line:
$pdf->MultiCell($largcol2, $tab2_hl, price($sign * $object->total_ttc, 0, $outputlangs), $useborder, 'R', 1);
And prepend the total modification like this:
$object->total_ttc = $object->total_ttc + $object->total_custom_tax; // prepend this to add the custom tax to the total
Done. This should show your custom tax per product and your total including all custom taxes.
