Module CustomFields
CustomFields | |
Numero/ID of module | 8500 |
Developer doc. of module | Module_CustomFields_Dev |
This documentation is about the external module CustomFields in branch v3. For previous versions, please read the included README inside the archive, although most of the documentation here is also valid for those older versions (particularly for branch V2 which is the Free edition).
For the native Extrafields module, see the related page.
You can also jump directly to Module_CustomFields_Cases wiki page for a collection of practical examples.
Module name | CustomFields |
Editor / Editeur | Larroque Stephen - www.customfields.org |
Prerequisites / Prérequis | Dolibarr <= 3.6.0-alpha.
Last update date / Date mise à jour fiche / Fecha última actualización | 2014-11-25 |
Note / Nota |
Description
The three main goals of CustomFields are to enable you to:
- Easily create your own custom fields with your data type of choice.
- Automatically manage/create/update/delete custom fields records of datas.
- Easily use the custom fields in your ODT and PDF documents, or any other PHP code.
And the philosophy:
- Standards-compliance.
- Independence with the Dolibarr code.
- Be reusable.
Understanding CustomFields
Technically speaking, this module is a simple wrapper for your sql database. It respects sql standards and manages them in a standard way.
This means that you can modify your sql database with another tool (eg: phpMyAdmin), and the changes will be reflected inside CustomFields as well.
Features overview
- Natively support the modules: Invoices, Propales and Products/Services.
- Full multilanguage support:
- multilanguage in the administration gui (french and english for now, but can be translated by anyone using langs files)
- multilanguage user-defined custom fields labels
- multilanguage custom fields values (eg: yes/no select box can be translated to any language, same for enum user defined values). You can even translate the values of your dropdown boxes or your constrained fields.
- Several natively supported fields types :
- Textbox
- Areabox
- YesNoBox
- TrueFalseBox
- DropdownBox (your own options)
- Date
- DateTime
- Integer
- Float
- Double
- Constrained (link to other tables)
- Other (custom type, defined by your own SQL command)
- Custom sql statements to create complex fields : these custom sql statements will be executed after the creation/edition of the custom field definition.
Requirements
This module requires your database to support Foreign Keys for full functionalities, for example with MySQL you need to enable InnoDB, because MyISAM alone does not support foreign keys and referential integrity checks.
However, in the case you really cannot enable Foreign Keys support in your database, CustomFields can still work in compatibility mode: you will get most of the features, constraints included, but your database will be a bit less clean.
For more informations, please read the developper's documentation about the SQL Compatibility mode.
Enabling the module
Creating a custom field
- Label: this option is disabled, because the label will automatically be the same as the Field Name, but you can translate it (set it) in language files (see the related chapter below).
- Field Name: sql field name. Choose any name you want, it just has to be alphanumeric without any space (you can use underscore '_'). You can also use remote sql columns names if you set a constrained field to enable Smart Value Substitution for this field (see the related chapter).
- Type: the type of the field. This is where you choose what kind of data your field will hold, and more importantly how it will be shown (eg: Textbox, DropdownBox, etc..). You can also choose Other and set your own SQL type (and size) by entering it in the Other box just below (Eg: int(11) will create an int of max size 11 bits).
- Size, or for DropdownBox the Values: if you want to set a specific size, you can set it here. By default, the module will set the right size for most uses, but if you find that it's too limited, you set any value. Also, this is required if you set an DropdownBox type, and instead of setting the size you should here set the values that will be offered in the box (eg: "firstval","secondval","thirdval" WITH the quotes and commas).
- Accept null values: if enabled, the field will accept empty values. Else if disabled, a value will be required, and if an empty value is entered, the last non empty value will be used instead.
- Default value: you can set the default value when a field has not received any value by the user yet.
- Constraint: you can link the field to another table in the database. The field will then offer as choices the records in the remote table.
- Custom SQL Definition: this is used to add more sql commands to the sql definition of the field (such as comments, meta parameters or transformations).
Any SQL command you write here will be appended at the end of the automatically generated SQL statement to create the custom field.
Eg: you create a custom field named "belowten" and want to make sure that it will never store any value above 10, you can set the following in the Custom SQL Definition (if supported by your DBMS):
CHECK belowten < 10
This will be appended to the automatically generated SQL creation statement, which would be something like this:
ALTER table ADD belowten int(11)
With the appended Custom SQL Definition:
ALTER table ADD belowten int(11) CHECK belowten < 10
You can of course add multiple statements as long as they are doable in the same statement (you are not allowed to use ";" to add another request, you should then use Custom SQL Statement to do that).
- Custom SQL Statement: any sql command can be entered here and will be issued only ONCE after the definition of the field (thus the commands won't be issued every time the field is shown, but only once when you create the field!). This is the same as using a third-party tool such as phpMyAdmin, and is just offered as a quick shortcut.
Note: in Custom SQL Statement, do NOT do
SELECT *
it will be rejected by the injection protection of Dolibarr - and anyway this is totally useless as the module won't show you the result of the request, you should better try sql commands like View, Procedure, Trigger, Check, etc..
any SQL request (not just one or two commands like above) will be issued AFTER the creation statement (not in the same statement, this is the main difference with the Custom SQL Definition field).
Eg: you are creating a custom field named "syncedfield" in "llx_invoices" and you want that everytime data is inserted into that field, the same data is also inserted in another field named "remotefield" but in another table named "llx_propal". You can use a trigger that you will create at the same time as the field, with something like that:
CREATE TRIGGER synctrigger AFTER INSERT ON llx_invoices INSERT INTO llx_propal (remotefield) VALUES (NEW.syncedfield)
In practice, when you create the custom field, it will then issue two different requests:
ALTER llx_invoices ADD syncedfield int(11); CREATE TRIGGER synctrigger AFTER INSERT ON llx_invoices INSERT INTO llx_propal (remotefield) VALUES (NEW.syncedfield)
Notice the semicolon (;) at the end of the first request.
The field Custom SQL Statement is just a shortcut to quickly input a SQL request to be issued just after the creation of the field, but of course you can do the same by using phpmyadmin or any other interface and issuing SQL requests by yourself.
Note2: if what you want to do is to store metadata about your custom fields (extended infos), you do not necessarily have to use SQL, but you may use a relatively recent facility called ExtraOptions, which allow you to basically store any data you want about a custom field (NOT about each record, but about the custom field! Thus there is one ExtraOptions per custom field, not per record!). More info can be found here: CustomFields JSON API
Modifying a custom field
Deleting a custom field
Translation of a custom field's label
Testing your custom fields with the PDFTest module
Implementing in ODT templates
First, you have to know how to create an ODT template. Please refer to the related documentation: Create_an_ODT_document_template
{cf_user_ref}
{cf_user_ref_raw}
{cf_user_ref} = rowid {cf_user_ref_firstname} = firstname {cf_user_ref_user_mobile} = mobile phone etc...
[!-- IF {cf_enablethis_raw} --] This is enabled and this will show. [!-- ELSE {cf_enablethis_raw} --] Else this will show up when disabled. [!-- ENDIF {cf_enablethis_raw} --]
We need to use the raw value, because we need to have a 0/1 value for the conditional to work. It also works for empty/non-empty, so this can also work with empty Textbox or any other sql datatype: if there's no text, you can avoid to show anything:
[!-- IF {cf_mytextfield_raw} --] My text field is not empty, here is its value: {cf_mytextfield} [!-- ENDIF {cf_mytextfield_raw} --]
Implementing in PDF templates
First, before implementing the custom fields, you have to make your own PDF template. Please refer to the related documentation: Create_a_PDF_document_template
- To load the custom fields:
- To access the field's value:
Beautified formatting:
or for the raw value:
- To access a product's line's value:
- To print it with FPDF (the default PDF generation library):
- And if you want to print the multilanguage label of this field :
$mylabel = $this->customfields->findLabel("cf_myfield", $outputlangs); // where $outputlangs is the language the PDF should be outputted to
- If you want to print an HTML field (Areabox), the FPDF library provides you with a mean to do so:
$pdf->writeHTML('HTML beautified printing for myfield: '.$object->customfields->cf_myfield); // printing areabox with html parsing
$pdf->writeHTMLCell(); // you can also use writeHTMLCell() to get more options with the positionning of your cell
Warning: TCPDF support for HTML is very limited and not guaranteed. If you use the writeHTML() method and it doesn't print you any text of the field in your PDF, then try to strip out the html tags by doing something like this:
$myfield = str_replace(array("\n\n","\r\n\r\n"), "\n",strip_tags($object->customfields->cf_myfield));
$pdf->MultiCell(0,3, $myfield, 0, 'L'); // printing the customfield with line returns but no HTML
Implementing in php code (dolibarr core modules or your own module)
- $object: the object where the custom fields datas will be set
- $fromobject: the object from which the custom fields will be fetched (this can be used to fetch custom fields from multiple modules into one $object)
- $langs: language translation class, to localize your custom fields values
- $prefix: prefix to add to help you organize and avoid overwriting custom fields (eg: you have two modules and want to store into one $object, with $prefix='invoice' the first will store inside $object->customfields->invoice->cf_myfield, and second='propal' will store inside $object->customfields->propal->cf_myfield).
- $pdfformat: beautify the customfields values? (null = no beautify nor translation; false = beautify and translate; true = translation and pdf beautify with html entities encoding)
- First, you necessarily have to instanciate the CustomFields class:
- Secondly, you have the fetch the records (this will fetch ALL custom fields for ALL records):
- Thirdly, you can now print all your records this way:
if (!is_null($records)) { // verify that we have at least one result
foreach ($records as $record) { // in our list of records we walk each record
foreach ($record as $label => $value) { // for each record, we extract the label and the value
print $label.' has value: '.$value; // Simple printing, with no beautify nor multilingual support
print $customfields->findLabel($customfields->varprefix.$label).' has value: '.$customfields->simpleprintField($label, $value); // Full printing method with multilingual and beautified printing of the values. Note: We need to add the varprefix for the label to be found. For printField, we need to provide the meta-informations of the current field to print the value from, depending on these meta-informations the function will choose the right presentation.
- Full final code:
// Fetch all records
// Walk and print the records
- If you want to fetch only one record:
- You can get the errors returned by the CustomFields class (sql errors and others):
print($customfields->error); // This will print all errors concatenated in a single string returned by the CustomFields class
print($customfields->errors[0]); // To print a specific error separately from the rest (can be useful to better understand what happened)
// More complete example:
if (!empty($customfields->error)) {
dol_htmloutput_errors($customfields->error); // Use the old Dolibarr error printing facility
setEventMessage($customfields->error, 'errors'); // Use the new Dolibarr 3.3 error printing facility
Do's and don't to avoid slowdowns when implementing CustomFields
- In PDF templates, use customfields_fill_object_lines() only ONCE before the loop, else it will be very heavy on CPU and memory usage (using it once will already fetch all lines for the current object at once, no need to use it several times).
- Adding a lot of customfields or product lines won't really slow down CustomFields in any way (datasheet printing, editing field, PDF/ODT generation, etc..), thank's to caching.
- Try to avoid the number of constrained customfields: adding a lot of constrained customfields will, because CustomFields automatically lookup the remote tables for every constrained field, so that you can access any remote column in your PDF. There is a cache mechanism that tries to speed up the process, so for example if you have many different constrained customfields on the same remote table (eg: with different Smart Value Substitution prefixes), then the performance won't be tampered, but if every constrained customfields is linked to a different table, there is no way around, it will slow down. If you encounter problems, try to limit the number of constrained fields you create, or try to add SQL indexes on the remote table of the constrained field, or don't use customfields_fill_object*() functions but directly access _only_ the fields you need by using the CustomFields class or your own sql query.
- Smart value substitution for constrained fields does not hamper any performance (eg: prefix of the remote column for auto replacement of the raw value by the specified column's value).
- Try to use customfields_fill_object() and customfields_fill_object_lines() only once per script, these functions are really heavy and do all the work for you, they are optimized and cache everything they can, but the drawback is that they're heavy. An easy way is to modify directly the original $object, so that the result will be transmitted to every other parts of Dolibarr (but be careful, do it only if you know that this will not conflict). You can also choose to not use these functions at all, and use directly the CustomFields class, if you have really specific needs, you can have fastest results (eg: if you don't need to fetch all the customfields but only one or a few, or if you only need the raw values).
Constraints
This chapter will present the special functionnalities of constrained fields, which are a powerful functionnality of CustomFields.
Adding a constrained/linked custom field
Smart Value Substitution is a quick and easy option to show another remote field's value of a constrained field in place of the raw value (sql row id).
Eg: let's say you want to show the name of the users in the llx_users table, not the rowid. Just create a custom field with field name = "name" (without quotes) and it will automatically show the name fields instead of the rowid. And don't forget, in the PDF and ODT, you can access all the remote fields, not only name, but firstname, phone number, email, etc..
eg: Create a custom field named "name_firstname_login" constrained on llx_users will show values formatted like 'Admin John admin'. Every value is separated by a space.
country region -------------- France Paris France Seine-Saint-Denis Canada Quebec
Accessing remote fields via a constrained field
With constrained fields, you can not only access the custom field's value, but also any remote field (sql column) of the linked table.
This feature works on any constrained field, just create a custom field with a constraint on a table, and you can use this feature.
To access any remote field, just append "_remotecolumn" to the variable name of the custom field (eg: cf_myfield_remotecolumn).
For example, if you create a custom field "firstname_name" constrained on llx_users, you can access any other field of llx_users.
In ODT:
{cf_firstname_name} will print something like John Doe {cf_firstname_name_login} will print john {cf_firstname_name_email} will print johndoe@somemail.com {cf_firstname_name_user_mobile} will print 0123456789 {cf_firstname_name_firstname} will print John {cf_firstname_name_name} will print Doe
In PDF or PHP code:
// Printing
print($object->customfields->cf_firstname_name); // will John Doe
print($object->customfields->cf_firstname_name_login); // will john
print($object->customfields->cf_firstname_name_email); // will johndoe@somemail.com
print($object->customfields->cf_firstname_name_user_mobile); // will 0123456789
print($object->customfields->cf_firstname_name_firstname); // will John
print($object->customfields->cf_firstname_name_name); // will Doe
// PDF printing
$pdf->MultiCell(0,3, $object->customfields->cf_firstname_name, 0, 'L');
$pdf->MultiCell(0,3, $object->customfields->cf_firstname_name_login, 0, 'L');
$pdf->MultiCell(0,3, $object->customfields->cf_firstname_name_email, 0, 'L');
Extra options
This chapter will present extra options that you can set in the administration panel.
Recopy
Recopy option allows to transfert a custom field's value in module A to another custom field of another module B. This allows to keep custom fields values when converting an object.
For example, let's say that you have a custom field named "piece_reference" in your Commercial proposals. You now would like that when you convert your Commercial proposals into an Invoice, you also transfert this "piece_reference" in the Invoice so that you can easily print it on your generated invoice documents. To do this, you just need to create a custom field named the same, "piece_reference", on Invoices, and then enable the Recopy option on it (not on Commercial proposal's custom field, the recopy option is to be enabled on the child field on which we want to recopy on).
This feature is automatically managed, and it supports chaining (eg: recopy from Intervention to Commercial Proposal, and then recopy from Commercial Proposal to Invoice).
You can also specify the parent field's name if the name is different (eg: "piece_reference" in Commercial proposals but "client_ref" in Invoices).
Cascade
This option allows to create dynamically linked/dependent lists, also called cascaded dropdown lists.
This is a common construct seen on the modern web, for example: you want to be able to specify the location of your client. To do this, instead of using a text field to enter the address, you'd prefer to use Dropdown lists as to avoid entry mistakes. To do that, you can create one field "country_libelle" constrained on llx_c_pays to indicate the client's country, and then another field "region_nom" constrained on llx_c_regions to show the list of regions. However, those two lists are independent, and the selected region can be entirely wrong considered the country. To limit the available regions depending on the selected country, you can use the Cascade option on the "region_nom" (child) field, and set the Parent field to be "country_libelle". Then, you will see that regions will automatically be limited to the relevant ones depending on the selected country. This is called cascading, because the parent field "country_libelle" cascaded its value to the child "region_nom".
By default, the management of the cascade is fully automatic and is managed via AJAX. For compatibility, if the user has no AJAX support, the cascading won't happen so that user's without AJAX support (eg: smartphones, tablets, etc.) will still be able to select a value.
Currently, the automatic management only works on constrained fields (both the child and parent fields must be constrained). If you want to cascade fields of other types than Constrained, you can use the Custom Ajax Functions facility (see below) to manage cascading at object's creation, and Overloading Functions to manage cascading at object's edition.
To setup a cascade in the administration panel, you just need to enable the Cascade option, and select the Parent field that should cascade its value onto the currently edited field. The admin panel will try to fill out the remaining fields automatically. However, if an alert is shown or if the two Join From and Join On fields remain empty, you will need to fill them manually.
These two Join fields specify how the linked tables of the two constrained fields are related (eg: foreign key). CustomFields admin panel will try to detect that automatically, but this may not always be possible (if there's no foreign key).
- Join From is the current field's linked table SQL column that points to the parent field's linked table.
- Join On is the parent field's linked table SQL column that is pointed by the Join From column.
For example: let's say you now want to add a field to specify the department. To do that, you can create a field "dep_nom" constrained on llx_c_departements, and enable Cascade with the Parent field being "region_nom". However, CustomFields will show you an alert telling you that no relationship could be found. This is because the relationship between the two tables isn't encoded in a Foreign Key in your SQL database. To find the relationship, you can take a look at both llx_c_departements and llx_c_regions, and you will see that llx_c_departements has a field named "fk_regions" (so yes they are both linked), and llx_c_regions has a field named "code_region". You now have everything you need: set Join From as "fk_regions", and set Join On as "code_region". Save your new custom field, and you will see that your "dep_nom" field is correctly cascaded when you select a region using "region_nom" field.
Other options
Here are a few other options that you can set:
- Required: make the field required at object's creation. Eg: when creating an Invoice, this field will need to be filled, empty value will not be accepted.
- Not editable: the field cannot be edited by users. Particularly useful for summary fields (eg: an Invoice Lines's custom field that does the final sum after applying custom coefficients on the product's price). These fields are to be implemented by yourself via overloading functions (you will get every infos you need, other fields included, you'll just have to make your computations and then return that).
Advanced configuration
Changing the default variable prefix for fields name
This behaviour can easily be changed by editing the general configuration file for CustomFields located inside /htdocs/customfields/conf/conf_customfields.lib.php.
Then edit the value of the $fieldsprefix variable.
Changing the delimiter for Smart Value Substitution
When using smart value substitution (ie: when you create a constrained field and set remote columns names in the field's name), by default every column name must be separated by an underscore '_'. This is usually good enough for most cases, but in a few occasions you might want to link to a remote column which name already contains an underscore, and in this case you won't be able to access it with SVS (but you can still access it with the remote field access in PDF/ODT templates and PHP codes, eg: myfield_remote_field_name_with_underscore).
If you want to change the default delimiter, you can easily do so by editing the general configuration file for CustomFields located inside /htdocs/customfields/conf/conf_customfields.lib.php
Then edit the value of the $svsdelimiter variable to any value you want.
Note: You can set single characters as well as multiple characters for the svsdelimiter. Eg: $svsdelimiter='__'; will allow you to make a constrained field myfield__firstname__name on llx_users and linked to both the firstname and name columns from the llx_users table.
CAUTION: you can only set as a delimiter a character that is accepted by your DBMS, or else this will produce errors!
Overloading functions: Adding your own management code for custom fields
The module offers an overloading facility where you can overload (read here: replace) functions of CustomFields by your own.
The idea is that for each custom field you create, a few overloading functions are created and associated with it. You can use them or not. If you use them, you can put inside the functions your own SQL queries and other calculations you want to do, and then CustomFields will try to automatically manage this field, using your specifications.
This can be used in various ways: to change how a particular field is printed, how a particular field is saved, to add your own SQL request to manage a custom field, etc.
Within this library, you can define one function per action (view, edit, create, save, etc.), per module and per field (so that you can define different functions for different fields).
To overload CustomFields's functions, first rename the following file: /customfields/fields/customfields_fields_extend.lib.php.example
Into (just remove the .example at the end): /customfields/fields/customfields_fields_extend.lib.php
Then open it with your text/php editor.
You will find inside all the information you need, here is an excerpt:
/* Decription: you can overload a few functions of CustomFields to do your own stuff, mainly the printing and the management of the fields.
* Guidelines:
* global $db;
* $myvar = GETPOST('myvar');
* Usage:
* save: at edition (on datasheet), you can change the values that will be stored in the database, and then CF will commit them (you don't have to, just change the values).
* savefull: at edition (on datasheet), CF stops the processing and you do the rest of the commit to the database (WARNING: CF will not store the data, you have to do it!)
* Format:
global $db;
$myarray = array(
array(0, ''),
array(1, 'test1'),
array(2, 'test2'),
array(3, 'test3'),
array(4, 'test4'),
print $myarray[$value][1];
$myarray = array(
array('id'=>0, 'value'=>''),
Custom AJAX Functions
Adding a new sql data type
This will allow you to properly manage how the sql data type will be printed and managed by CustomFields.
Warning: this will manage all the fields using this sql data type the same way. If you only need one specific field to be handled differently than the others, you should use the overloading functions (jump to Module_CustomFields#Overloading_functions:_Adding_your_own_management_code_for_custom_fields).
Edit the $sql_datatypes to add your own type : the key being the sql data type definition (must be sql valid), the value being the name that will be shown to the user (you can choose whatever you want). Eg:
2/ Manage the new data type (implement the html input/edit field)
Why: CustomFields must know how to manage (save in sql database and show on edit) this particular datatype you've just added.
As a guide, you should probably first take a look below the comment:
// Normal non-constrained fields
Below this comment are the simplest data types (above the comment it concerns only constrained fields which are much more dynamic and complicated).
Here we will implement a printing function that will best represent the data type when not editing, just viewing the data in the datasheet.
Adding the support of a new module
Please read the CustomFields developpers documentation for the instructions on how to implement the support of a new module in CustomFields (beware: it may require some php abilities in the worst case scenario when hooks and triggers are not yet implemented in the module).
Example cases
Exporting and importing your CustomFields
If you want to export your custom fields into another database, or just make a backup, please carefully read this chapter.
Exporting your SQL data
CustomFields stores all its datas and your custom fields configurations directly inside the database.
CustomFields datas and configurations are stored in the same database as Dolibarr, but in totally separate tables.
Thus, you can just make a SQL dump of your database, and your custom fields (configuration and datas) will be exported along the way.
On the other hand, if you just want to export just the custom fields and not the rest of your Dolibarr database (for example because you configured your custom fields on a test server and now want to upload them to the live environment), you can just export all the tables containing 'customfields' in their name, with something like: LIKE %customfields%
This is because everything that is related to CustomFields is labeled with 'customfields' somewhere in the name, so that you can easily single them out of the rest of the Dolibarr standard code and database tables.
Note: please note that you should set FOREIGN_KEY_CHECKS = 0 when exporting any Dolibarr's or CustomFields SQL table (please read the Dolibarr wiki about Database Backups for a more extensive guide).
Exporting your CustomFields files
Although CustomFields stores as much as possible its configuration in the database, to give you more freedom of extensibility, there are a few configuration files that are stored directly inside the CustomFields directory.
CustomFields separates all its core files from the Dolibarr code, so that they are not mixed up and you can easily make a backup of your CustomFields install by just making a backup of your /htdocs/customfields folder, and that's it!
To be more specific, the main files that you should backup are:
- The overloading functions file if you use overloading functions to manage some of your custom fields, it is located at /htdocs/customfields/fields/customfields_fields_extend.lib.php
- The languages files if you have translated the labels of your custom fields, which are located inside the following folder: /htdocs/customfields/langs/
Updating your Dolibarr/CustomFields
CustomFields was designed to be totally independent from Dolibarr so you don't have to worry when you're updating your Dolibarr install.
Also, you can easily update your CustomFields install by just replacing the old files (just make sure that you've made a backup of your modified files, see the previous chapter). After you updated your CustomFields files, you should disable then re enable CustomFields in the Dolibarr's modules administration page: this is necessary to refresh some of the global parameters.
Troubleshooting
General advices for troubleshooting
If you encounter an error (script not functionning, blank page, etc...), please enable php warnings and error notices and post the errors on the forum if you can't find the solution here or by yourself.
Set this in your php.ini file:
display_errors = On error_reporting = E_ALL | E_STRICT ; E_ALL | E_STRICT (Show all errors, warnings and notices including coding standards.)
Alternatively, in PHP you can use:
error_reporting(E_ALL);
ini_set('display_errors', '1');
// Or if track_errors = On in your php.ini:
print($php_errormsg);
You can also check the Dolibarr log: /documents/dolibarr.log (you must enable Dolibarr logging module before).
And lastly, you can also print the errors returned by the CustomFields class:
Q: I have installed CustomFields but it doesn't show up in the modules administration panel
A: You probably copied the CustomFields files in the wrong place. Please check that the customfields and customfieldspdftest folders are located just under /dolibarr/htdocs/, or if you have specified an alternate folder in your conf.php file ($dolibarr_main_document_root_alt), place the folders inside this path.
Details: For any Dolibarr module to be shown on the Dolibarr's Modules Administration Panel, the only necessary thing is that Dolibarr must find the module descriptor file at the correct place (and with the correct syntax). Since the syntax is taken care of by the developer, if you can't see the module in the admin panel, you should check if you have copied the CustomFields files in the correct location.
Q: I'm trying to edit a constrained customfield parameters in the admin configuration page, but everytime I change the constraint it goes back to None ?
A: This is behaviour is probably due to some of your records containing an illegal value for the new constraint. For example, if you switch your customfield's constraint from your products' table containing 100 products to the llx_users table containing 2 users, the database won't know what to do with the illegal values higher than 2, so it won't accept the new constraint and set to None. In this case, just edit yourself the illegal values, either by fixing them or just deleting all the values for this customfields (but in this case you can just delete the custom field and recreate it, this will indeed delete all values and leave you free to recreate the field with a different constraint).
Q: I'm trying to delete a constrained customfield in the admin configuration page, but it doesn't work!
If you want to forcefully delete the field manually, you can use the following sql commands:
SET FOREIGN_KEY_CHECKS = 0;
ALTER TABLE xxx DROP COLUMN yyy;
SET FOREIGN_KEY_CHECKS = 1;
SET FOREIGN_KEY_CHECKS = 0 will temporarily disable any key check, leaving you free to delete the sql column.
If that doesn't work, you can also totally delete the customfields table by doing:
TRUNCATE TABLE llx_themodule_customfields;
Q: I have a big problem with my fields, and I want to delete all the fields and reinitialize the customfields table
If you have a big problem with a module's custom fields, you may want to start from scratch by deleting the entire custom fields table.
You can do this with the following sql commands:
Q: CustomFields produces a lot of weird errors anywhere I go even when it is disabled, what should I do?
CustomFields, but also Dolibarr, expects the database columns to be all lowercase, but on a few systems the result may be returned in uppercase or mixed-case.
CustomFields now has a mechanism that should prevent this kind of bug to happen, but if that's the case on your system you can expect to get a lot more errors using any Dolibarr's module, or in fact any php script at all.
Please check you SQL DBMS configuration and set it to always return lowercase column names.
Eg: For MySQL, check the lower_case_table_names system variable (check the MySQL manual at identifier-case-sensitivity).
Q: Whenever I try to create a custom field or a record, I get an error "Duplicate entry '1' for key 'PRIMARY'"
Unluckily, this is one of the worst error you can ever encounter :( This error means that the DBMS can't resolve the primary key checks, and it finds a duplicate even if it shouldn't.
This is something that generally happens when either:
- Your SQL queries are malformed, or you are trying to issue a SQL query that the DBMS does not support (DBMS are quite a deal behind the SQL standard in terms of functionnalities).
- Your database is corrupted
Since CustomFields was made and extensively tested to avoid malformed SQL queries, it is probable that your database got corrupted. There are various ways to fix this error, but one of the most working solution is to:
- First try to run mysqlcheck
- If that didn't work out, then first export a backup of your database in a .sql file, then drop your database altogether, and import your backup back into your DBMS. This should fix the problem.
For more informations, here is an interesting thread: softwareprojects dot com/resources/programming/t-how-to-fix-mysql-duplicate-entry-for-key-primary-o-1844.html
Q: CustomFields Pro is VERY slow when it is enabled, even on modules datasheet where no custom field was created! (aka INFORMATION_SCHEMA slowness)
Note the characteristic definition of this problem: CustomFields Pro slows down every datasheet and creation page, even when not any custom field were created for the module!
Also this happens only on MySQL with InnoDB enabled (or partially enabled).
This slowness happens on some databases for any query to INFORMATION_SCHEMA table. If you are affected by this bug, you can try this simple command:
global $db;
$then = microtime(true);
$db->query("SELECT 1 FROM INFORMATION_SCHEMA.TABLES LIMIT 1");
$now = microtime(true);
echo sprintf("Elapsed: %f", $now-$then);
If it takes more than a few milliseconds, then you are affected by the bug.
You can fix this bug by setting the following global variable in your MySQL configuration:
set global innodb_stats_on_metadata=0;
Doing this will change the setting for good and for all applications. You should not have any negative side-effect. A positive side-effect is that other client applications as well as SQL frontends such as phpMyAdmin will be a lot faster.
Alternatively, if you can't modify your global configuration (eg: you are on a limited shared web host), you can modify CustomFields to set this variable at runtime: edit /htdocs/customfields/class/customfields.class.php, and search for "INFORMATION_SCHEMA", and everywhere you find a SQL query containing "INFORMATION_SCHEMA", edit it to add in front of the SQL query:
set innodb_stats_on_metadata=0;
So in the end you should end up with something like this:
$db->query("set innodb_stats_on_metadata=0;SELECT 1 FROM INFORMATION_SCHEMA...");
Another possible alternative would be to use InnoDB plugins to dynamically change the setting. See:
dev.mysql.com/doc/innodb-plugin/1.0/en/innodb-other-changes-innodb_stats_on_metadata.html
The technical reasons behind this slowness:
This is due to a pack of old bugs in MySQL that were never fixed (more specifically connector and I_S queries are suboptimal in MySQL), and which leaks memory and CPU for even small optimized requests. Additionally, InnoDB maintains statistics on metada (which are in most cases useless, except if you do Data Mining on the performance of Relational Models), and these stats incidentally use I_S queries, which hit right into the spot.
If you want more information about this bug, check these posts:
bugs.mysql.com/bug.php?id=19588 bugs.mysql.com/bug.php?id=27940 www.mysqlperformanceblog.com/2011/12/23/solving-information_schema-slowness/
