Module Catalog
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Prerequisites / Prérequis Dolibarr min version 3.1
Last update date / Date mise à jour fiche / Fecha última actualización 2014-08-5
Generates a PDF catalog of products and services contained in Dolibarr. Allows management of catalogs by month and year.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
