Module DoliPos
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.1    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2014-08-5
This module is a POS terminal or POS Professional, which provides sales on a counter with the public. With this unique system of point of sale, we can create all terminals (cash) needed, and manage with a single product, with unlimited users, and through the WEB.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
