Module 2WebMail EN
Information
| Module name | 2WebMail |
| Editor / Editeur | 2byte.es - http://www.2byte.es |
| Download or buy page / Page achat ou téléchargement | External module - Dolistore |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2014-05-12 |
| Note / Nota |
Manage with Dolibarr the e-mails from company mail system
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
