Module 2WebMail EN
Revision as of 14:15, 12 May 2014 by Simnandez (talk | contribs) (Created page with "Category:Complementary modules Category:WebMail {{TemplateDocDev}} {{TemplateDocUtil}} = Information = {{TemplateModuleInfo |modulename=2WebMail |editor=2byte.es |web=htt...")
Information
Module name 2WebMail
Editor / Editeur 2byte.es - http://www.2byte.es
Download or buy page / Page achat ou téléchargement External module - Dolistore
Last update date / Date mise à jour fiche / Fecha última actualización 2014-05-12
Manage with Dolibarr the e-mails from company mail system
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
