Module OVH (SMS, ClickToDial, ...)
Module name | OVH |
Prerequisites / Prérequis | Un compte OVH. Pour l'utilisation de Click2Dial, il faut aussi un abonnement SIP et les identifiants fournis par OVH
Last update date / Date mise à jour fiche / Fecha última actualización | 2014-02-28 |
Note / Nota |
Add features to link Dolibarr between OVH web hosting services. Current version allows to:
- Send SMS to a thirdparty or member
- Import your OVH invoices
- Use the ClickToDial OVH system
Common setup
All services of this module use OVH API. So you must have an OVH (www.ovh.com) account.
Then go on Dolibarr, OVH module setup, tab "Common", and add your OVH account:
* Nic handle * Mot de passe
For field "URL of SOAP OVH service", type the value provided as example.
* https://www.ovh.com/soapi/soapi-re-1.26.wsdl
Once information are input, you can click onto "Test connexion" to check that Dolibarr can communicate with OVH server.
SMS setup
Sending of SMS need to buy SMS packages at OVH, so with your OVH account, select number of SMS to buy at OVH website. OVH commercial page for this is http://www.ovh.co.uk/sms_and_fax/
Once this is done, go into Dolibarr, setup of module OVH, "SMS" tab and add name of SMS group to use (groups created from your online OVH manager).
ClickToDial setup
To use ClickToDial, go on ClickToDial tab, take URL provided on page and paste it into ClickToDial module setup page, once module ClickToDial was activated.
Import OVH invoices setup
Just select the supplier third party to have imported invoices linked to.
SMS
- Go into card of a Thirdparty, Contact or Member. A new tab is visible to send SMS.
ClickToDial
- If the ClickToDial module (it's another module provided by default with all Dolibarr) was also activated, and URL provided by at previous chapter was filled into its setup page, a picto must be visible near to each phone number. Clicking on picto will launch phone numbering and launch your OVH phoning system.
Fetching invoices
Go into menu "Home - Modules tools - OVH invoices import". If this menu does not exists onto your instance, call URL page http://yourdolibarr/ovh/importovhinvoice.php
You can the choose which invoice to import.
