Roadmap and Release 3.5.0
Revision as of 14:00, 30 January 2014 by Cbattarel (talk | contribs)
Version: 3.5.0 (List of other versions on page Category:RoadMap)
Release date: January 2014
Should contains all tasks with priority 9 logged when previous version were released in task tracker https://github.com/Dolibarr/dolibarr/issues
  • Uniformizing of code and api for developers
  • War against major missing and not stable features
Detailed Changelog:
For users:
- New: Add hidden option BANK_DISABLE_DIRECT_INPUT.
- New: More options to select status of users into select user list.
- New: [ task #862 ] Add ODT on shipments.
- New: [ task #149 ] Add # of notes and attachments in tabs.
- New: Can edit customer ref at any time.
- New: [ task #877 ] Reorganize menus.
- New: [ task #858 ] Holiday module: note on manual holiday assignation.
- New: [ task #892 ] Add hidden option in thirdparty customer/supplier module to hide non active
  companies in select_company method.
- New: [ task #531 ] Add a workload field on tasks.
- New: Add graph of bank account input/output into input-output report page.
- New: Add script export-bank-receipts.php
- New: Add option "filter=bank" onto script rebuild_merge_pdf.php to merge PDF that
  has one payment on a specific bank account.*
- New: [ task #901 ] Add Extrafield on Fiche Inter.
- New: Show process id in all command line scripts.
- New: Module mailman can subscribe/unsubscribe to ML according to categories or type of member.
- New: Add object_hour and object_date_rfc as substitution tag for open document generation.
- New: Add options to send an email when paypal or paybox payment is done.
- New: Clone product/service composition.
- New: [ task #926 ] Add extrafield feature on order lines.
- New: [ task #927 ] Add extrafield feature on Proposal lines.
- New: [ task #928 ] Add extrafield feature on invoice lines.
- New: Add option ADHERENT_LOGIN_NOT_REQUIRED.
- New: Add a cron module to define scheduled jobs.
- New: Add new graphical boxes (customer and supplier invoices and orders per month).
- New: [ task #286 ] Enhance rounding function of prices to allow round of sum instead of sum of rounding.
- New: Can add an event automatically when a project is create.
- New: Add option MAIN_GENERATE_DOCUMENT_WITH_PICTURE.
- New: Add option excludethirdparties and onlythirdparties into merge pdf scripts.
- New: [ task #925 ] Add ODT document generation for Tasks in project module.
- New: [ task #924 ] Add numbering rule on task.
- New: [ task #165 ] Add import/export of multiprices.
- New: Add Maghreb regions and departments.
- New: A more responsive design for statistic box of home page.
- New: [ task #1005 ] Adapting to Spanish legislation bill numbering
- New: [ task #1011 ] Now supplier order and invoice deal with payment terms and mode.
- New: [ task #1014 ] Add option to recursively add parent category.
- New: [ task #1016 ] Can define a specific numbering for deposits.
- New: [ task #918 ] Stock replenishment.
- New : Add pdf link into supplier invoice list and supplier order list.
- New : Genrate auto the PDF for supplier invoice.
- New : Add category into filter webservice thirdparty method getListOfThirdParties.
- New : Allow to define margin or mark rate during quoting, ordering, invoicing.
- New : User permissions on margin module.
- New : Add ref supplier into muscadet model/
- New : Add ability to copy contact address to clipboard.
- New: Can use tag {mm} before {yy} even when there is a reset into numbering masks.
- New: [ task #1060 ] Register fields localtax(1|2)_type into details tables.
- New: [ task #923 ] Localtax support for ODT templates.
- New: [ task #90 ] Barcode search.
- New: Add hidden option MAIN_VAT_DEFAULT_IF_AUTODETECT_FAILS.
- New: Can send an email from thirdparty card.
- New: Can cancel holidays that were previously validated.
- New: Can choose contact on event (action com) creation, and filtered by thirdparty.
- New: Add hidden option MAIN_FORCE_DEFAULT_STATE_ID.
- New: Add page to make mass stock movement.
- New: Add field oustanding limit into thirdparty properties.
- New: Can enter a vat payment of zero.
- New: Add path to installed dir of external modules + Name and web of module provider.
- New: Add option to use a specific mask for uploaded filename.
- New: Can attach external links to objects as we can attach files.
- Qual: Implement same rule for return value of all command line scripts (0 when success, <>0 if error).
- Fix: [ bug #992 ] Proforma invoices don't have a separated numeric count.
- Fix: [ bug #1022 ] correct margin calculation for credit notes.
- Fix: Better management of using ajax for upload form (to solve problem when enabling ajax jquery multifile upload in some cases).
New experimental module:
- New: [ task #157 ] Add a Skype button (adherents / third parties / contacts)
For translators:
- Qual: Normalized sort order of all languages files with English reference files.
- New: Add language code files for South Africa, France new Caledonia, Vietnam.
- New: Translate string for email to change password.
For developers:
- New: DolGraph can build graph with three lines.
- New: DolGraph accept a parameter to cache data of graph getNbByMonthWithPrevYear.
- New: Can enable tuning info with option MAIN_SHOW_TUNING_INFO.
- New: Show version of client lib used by mysql drivers.
- New: Add function to get content of an url (using all dolibarr setup like timeout, proxies...)
- New: Upgrade lib of TCPDF to 6.0
- New: Upgrade jquery flot library to 0.8.1
- New: Add property "hidden" into module descriptors to allow to hide a module according to
  some dynamic conditions.
- New: Add option MAIN_MOTD_SETUPPAGE to add a content onto setup page. Also content for
  MAIN_MOTD_SETUPPAGE, MAIN_MOTD_SETUPPAGE, MAIN_HOME now accept "|langfile" into translation
  key to use a specific language file.
- New: Make some changes to allow usage of several alternative $dolibarr_main_url_root variables.
- Qual: All nowrap properties are now using CSS class nowrap.
- Qual: Move hard coded code of module mailmanspip into trigger.
- New: Into POST forms, if you can add a parameter DOL_AUTOSET_COOKIE with a value that is list name,
  separated by a coma, of other POST parameters, Dolibarr will automatically save this parameters
  into user cookies.
- New: Add hook addHomeSetup.
- New: Add trigger CATEGORY_LINK and CATEGORY_UNLINK.
- New: A trigger can return an array of error strings instead of one error string.
- New: Add method to use a dictionary as a combo box.
- New: Add update method for web service product.
- Fix also several bugs with old code.
WARNING: Following change may create regression for some external modules, but was necessary to make
Dolibarr better:
1) We started to clean hooks code.
If your hook want to modify value of $actions, it's role of your hook to modify it. Dolibarr
hook code will no more decide this for your module. If your action class for hook was returning
a string or an array, instead your module must set $actionclassinstance->results (to return array)
or $actionclassinstance->resprints (to return string) to return same thing. The return value must
be replaced by a "return 0";
Goal is to fix old compatibility code that does not match hook specifications:
 http://wiki.dolibarr.org/index.php/Hooks_system
2) If you implemented hook printTopRightMenu, check that output does not include '<td>' tags any more.
All content added must be tagged by a '<div>' with css class="login_block_elem"
3) Some methods object->addline used a first parameter that was object->id, some not. Of course
this was not a good practice, since object->id is already known, there is no need to provide id as
parameter. All methods addline in this case were modified to remove this parameter.
4) Method ->classer_facturee() is deprecated. It must be replace with ->classifyBilled().
5) Property ->tel on objects is now ->phone
