Module SEPA
Revision as of 10:48, 27 January 2014 by Eldy (talk | contribs) (→‎Informations)
Module name SEPA
Editor / Editeur 2byte.es - http://www.2byte.es
Dolibarr min version: 3.4.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2014-01-27
Create withdrawals files in the formats established by the european normative SEPA.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
