Module Sales Orders
Orders | |
Numero/ID of module | 25 |
Developer doc. of module | Module Customers Orders (developer) |
With this module, you can manage (create, edit, delete), customers orders. You can also convert an order into an invoice (if Module Customers Invoices is used).
It provides also features to generate documents for each order in a format like PDF.
Suppliers orders are however manager by Module Suppliers Orders.
Note that activating this module will automatically activate the Module Third Parties.
Life cycle / Business rules
A customer order follow the following life cycle:
If module shipment is enabled:
Draft --> Validated --> Shipment in process --> Delivered \ \ \ --> Processed (=Delivered + Billed) \-------------------------> Billed /
If module shipment is not enabled:
Draft --> Validated --> Delivered \ \ --> Processed (=Delivered + Billed) \-> Billed /
- The status "Order to bill" is not a status that is specific. For some users it will be same than status "Validated", for others, it will same than status "Delivered". This depends if you choose to make invoice before or after delivery (both are possible).
- Status "Shipment in process" is only visible if Module Shipment is used.
Once an order is validated, by its creator, if you enabled the shipment module, you can generate one or several shipment receipts to send products. This can be done at anytime before the order is canceled or closed with status processed.
You can also define an order as "Delivered" (change status to "Delivered") when you want.
You can generate one or several invoices from customer order when they are at status "validated" or "delivered". Note that, by default, invoices built from order have same content/amount but you can edit invoice, once generated from order, to change that.
If you click on "Classify billed" and "Classify Delivered", this switch status to "Processed" and order will disappear from menu "Orders delivered". It should be visible into "Orders processed".
Create an order
Creation of an invoice need to go on card of a third party, on tab "Customer" (this require your third party has customer nature).
If Module Workflow and Module Commercial Proposals enabled, you can also have a draft customer orders automatically created once a proposal is closed (You must set this into setup of Module Workflow.
Modify an order
To modify an order, go on its card (you can find order from menu Commercial - Customers order - List or from Thirdparty card - Tab customer.
You can edit it if order has draft status. If not click on action button Modify.
Close/Process an order
To have an order processed, you must both ship it and bill it. So once an order has been completely shipped, you can go onto card to close it.
Delete an order
To delete an order, go on its card (you can find order from menu Commercial - Customers order - List or from Thirdparty card - Tab customer.
Then click on action button Delete order.
Warning, a deleted order is definitively removed with no way to restore it.
Examples of use cases
UCCU01: | |
Situation | |
Actions |
