Module SEPA
| Module name | |
| Editor / Editeur | 2byte.es (www.2byte.es) |
Dolibarr min version: 3.4.0 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2014-01-23 |
| Note / Nota |
Create withdrawals files in the formats established by the european normative SEPA.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
