Module Zip AutoFill France - Belgium - Switzerland
Module name Zip Auto Fill (France+Belgium)
Last update date / Date mise à jour fiche / Fecha última actualización 2014-01-14
Load into database all zip codes of France and Belgium. This allow autocompletion for all zip and/or towns input into dolibarr screens.
Just activate the module. If you find a couple zip/town not found, go into menu home - setup - dictionnary. You will find a dictionnary to add missing entry.
