Module Pibarcode
Revision as of 11:47, 14 January 2014 by Eldy (talk | contribs) (→‎Informations)
Module name PiBarcode
Last update date / Date mise à jour fiche / Fecha última actualización 2014-01-14
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
