Module PHPSysinfo
Module name | PHPSysInfo |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2014-01-14 |
Note / Nota |
Include into menu, an entry PHPSysinfo that show all system information of PHPSysinfo tool (See projet http://phpsysinfo.sf.net)
Click on menu entry "PHPSysinfo". System information will be shown on main page.
