Module BitTorrent
Revision as of 16:20, 13 January 2014 by Eldy (talk | contribs) (→‎Informations)
Module name
Last update date / Date mise à jour fiche / Fecha última actualización 2014-01-13
Add into Dolibarr, the capability to be a Bit Torrent tracker. This means you are able to serve files to the world on the Bit Torrent network with no need of external web sites or tools.
To complete
