Module Massorders
| Module name | |
| Editor / Editeur | 2byte.es - www.2byte.es |
Dolibarr min version: 3.3 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2013-10-15 |
| Note / Nota |
With the module get remarkable efficiency in processing bulk orders. It is mainly suitable for companies that work with a large number of orders, and want to optimize the time spent to become bills.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
