Roadmap and Release 2.2.0 ("Purged version")
Version: 2.2.0 (List of other versions on page Category:RoadMap)
Release date: 2007-12-26
  • Called "Purged version" (a lot of old deprecated files were removed)
Detailed ChangeLog:
- Add more statistics on main page.
- Add option to add message on login page.
- Management of categories for third parties.
- Add volume on products properties.
- Support for LDAP authentication.
- Full member synchronisation with LDAP database in
  fundation module.
- More LDAP fields supported for user synchronization.
- Better logger for install.
- First changes to support UTF8.
- Add a "forget password" feature.
- Setup process can run several migrate files if need
  to jump several versions to upgrade.
- Support for webcalendar 1.1 in webcalendar module.
- Support for menu in database.
- Better support for using Dolibarr on more WHP.
- Removed some deprecated files and clean code.
- New theme: Auguria
- Removed PHP warnings.
- Some bugs fixes.
- Traduction more complete.
- Better code comments for Doxygen documentation.
- Better support of vcard export format.
- A lot of security enhancements (no more password in log files,
  crypted password in database, in config file...).
- Themes are full CSS compliant.
- A lot of other minor changes...
- Option to scan uploaded document by an antivirus.
- Transparency for picto files works with IE.
- Can drag and drop boxes on main page.
