Roadmap and Release 2.8.0
Revision as of 08:50, 27 July 2013 by Eldy (talk | contribs) (moved Roadmap 2.8.0 to Roadmap and Release 2.8.0)
Version: 2.8.0 (List of other versions on page Category:RoadMap)
Release date: 2010-03-16
- Reorganize directories
- Bug war
Detailed Changelog:
***** ChangeLog for 2.8 compared to 2.7 ***** For users: - New: Support note on trips module - New: Can link contacts to projects - New: Can removed attached file on email form if attachment was wrong. - New: Add option to show your logo on top of left menu. - New: task #9935: Can edit accountancy code. - New: Add an option to make users email required. - New: Module notification can send email on order or proposal validation. - New: Can use any command line antivirus on file upload. - New: A customer can also be a prospect. - New: task #9802 : Can link an action to a project and use project to filter agenda. - New: Project can be set on contract creation. - New: Initial sold can be conciliated on bank module. - New: Add a default errors-to email for emailing module. - New: Can filter on user on stock movement list. - New: When creating a third party from a member, it is set as a new customer. - New: Can use {tttt} in numbering mask setup. It will be replaced with third party type. - New: VAT number is stored in one field. This is more "international". - New: task #9782 : Add possibility to delete a warehouse. - New: task #9640 : Add label for stock movements. - New: task #9916 : Add FREE text for interventions card. - New: Can define the new product ref when cloning. - New: Project module support status of project and end date. - New: Provide a debian/ubuntu package. - New: Add link to check a SIREN for french users. - New: Add link "now" to fill date when creating invoices. - Fix: Import module works even if prefix is empty in source file. - Fix: bug #28055 : Unable to modify the date of a cloned command. - Fix: bug #27891. - Fix: Change of numbering module was not effective. - Fix: Change error management when adding already used supplier ref for a product. - Fix: Running sending-email.php - Fix: Warning should not appears for invoice closed - Fix: Import for companies works even with prefix empty. - Fix: bug #28895 : Création d'utilisateur impossible. - Fix: Can change password if has only permission change password. For developers: - Qual: Reorganize /dev directory. - Qual: Change the way items are linked together. - Qual: The login page now use a template in /core/template/login.tpl.php. - New: Modules can add their own tab on projects cards. - New: Add management of triger FICHEINTER_VALIDATE
