Translator documentation
<keywords content="translation, documentation, translator, localize, localization, i18n, internationalization" />
Translate Dolibarr into another language
Dolibarr language files are translated in several languages. French and English are by default always complete. Other languages depend on contributions. This tutorial can help you to complete a translation that does not exists or is not correct for another language.
There are 4 methods for translating Dolibarr (1 automatic: autotranslator, 3 manual: phpLangEditor, iniTranslation and the completely manual method). They are in order of preference:
- Translator OS: All
- Tool: autotranslator.php provided with Dolibarr in directory dev/translation.
This method is recommended when starting translation for a language not already initialized. If there is already a translation available but you need to add missing key or correct errors, try to use next method.
php autotranslator.php lang_code_source lang_code_target GOOGLEAPIKEY
For example :
php autotranslator.php en_US pt_PT GOOGLEAPIKEY
All non existing files will be created, all existing files will be updated. The tool use Google translation service to find the translation value of a string, so a working Internet connection is required from station running the script. Also a GOOGLEAPIKEY is required and Google charges a fee for using this service (20 euros / 1 000 000 of translated chars). Your PHP must also have permissions to write into htdocs/langs directory and must have curl functions available.
Manual Translation with the Firefox plugin phpLangEditor
- Tool: phpLangEditor (plugin for Firefox) File:PhpLangEditor.jpg
Follow these steps to translate using the Firefox plugin:
- Install Firefox and install plugin phpLangEditor (Media:PhpLangEditor254.xpi)
- A further step is required to complete the installation. Type into URL field, the text about:config then in the Filter field, enter phplangeditor. Double click on the line phpLangEditor.file.typeOfLangExt and put ini in field. phpLangEditor is now ready to translate Dolibarr.
- From Firefox, open phpLangEditor by selecting the menu Tools -> PHP lang editor.
- Click on "Open reference file" and choose your file. Lang original (eg in your Dolibarr, htdocs / lang / en_US / bills.lang
- Click 'Open file translation and select the file containing the translation, if a file exists (eg htdocs / lang / es_ES / bills.lang).
- You can choose to display all the words to translate the words or only non-translated. Click on the term in the left column to translate it into the box below. You can also use keyboard shortcuts such as CTRL + N to move to the next
- Save the file once the translation is finished.
- Edit the file with a text editor to remove or correct the first comment line. Indeed, with phpLangEditor, it is not possible to translate the lines Discussed (starting with #), the file contains translated once recorded the comment line of the source file. A small manual editing is needed to correct or delete this line, although this does not adversely affect the proper functioning of the new file. Lang.
Manual Translation with iniTranslator
- Translator OS: Windows
- Tool: iniTranslator (Windows).
Follow these steps to translate using iniTranslator :
- Run your application translation will ask the template file (For example, under iniTranslator, do File - Open Original). Choose the source model in the directory htdocs / lang / en_US or htdocs / lang / en_US, which are up to date.
- Then choose the destination file may, in the directory htdocs / lang / xx_XX or xx is the language code to translate.
- Your tools will display the files 2 face to face with the missing strings to translate.
- Complete files.
- Save the new destination file.
Attention, iniTranslator has a serious defect. It does not retain the original order of the parameters and the generated file sorting alphabetically rather than keys in the order of the source file. In addition, areas comments source files are not reflected in the destination file translated.
Manual translation
To translate Dolibarr into another language, go to the langs directory and create a folder/directory named with the code language to translate (follow the existing format, for example en_US, en_GB, es_ES, de_DE, etc...). Then copy the files from an existing language directory (for example en_US/main.lang, en_GB/bills.lang), into the new language directory that you have just created.
These files have the format of key/value pairs in each line like the followings:
Code1 = translate phrase 1
Code2 = translate phrase 2
Coden = translate phrase n
Translate the phrases (the value portion of the key/value pairs) on right side of the "=" as seen above, the code (the key portion) on left side of "=" should remain unchanged. It is possible to translate the files one by one, without bringing them all at once. If a file has not been translated into the new language, Dolibarr uses English.
To have a localised (translated) string into the PHP code, all you have to do is load the language file and use the method to get the translated value, like this:
print $langs->trans("CodeX")
An entry type;
CodeX = phrase X
must be present or added to the myfile.lang file.
Translate online using Transifex
Transifex is an web application that provides an online platform for translation projects. It includes team and discussion tools, translation memory, glossary, proofreading and a lot of other features. It is quite easy to use and all translations can be uploaded or downloaded through the web interface or using their TX client in a terminal. Transifex is an open source project and the "community edition" can be freely downloaded and installed. There is also an hosted version which can be freely used by free and open source projects.
Translation teams
Using the web interface
TX Client configuration
To use the command line utility "tx" you need to download and install it and to create a configuration file. The configuration file have to be named config and saved in a .tx directory in project's root. Your directory's contents will look like that:
|-- build
|-- build.xml
|-- ChangeLog
|-- COPYING
|-- COPYRIGHT
|-- dev
|-- doc
|-- .gitignore
|-- htdocs
|-- INSTALL
|-- pom.xml
|-- quickbuild.xml
|-- README
|-- README-FR
|-- README.md
|-- robots.txt
|-- scripts
|-- test
`-- .tx
The project configuration file is used to store the project’s details and the file-to-resource mappings. As just said, this file is stored in .tx/config in your project’s root directory.
It has the following outline:
[main]
host = https://www.transifex.com
[project_slug.resource_slug]
file_filter = htdocs/langs/<lang>/resource.lang
source_file = htdocs/langs/en/resource.lang
source_lang = en
type = MOZILLAPROPERTIES
Here is an explanation of the sections and options used in the config file: [main] section
In this section we have project-wide options, such as the default transifex host for all projects. These can be overriden by each resource, in case it is needed.
source_lang: this is the source language of the resource.
source_file: this points to the source file directly.
file_filter: here we hold the expression used to identify translation files under the specific project. not mandatory
trans.<lang>: this is used for translation files that don’t follow a common naming schema and the file expression cannot be used to track them. not mandatory
host: in case the project doesn’t use the default Transifex server as specified in the [main] section, it can override it using this option. not mandatory
The current config file can be downloaded from https://github.com/Dolibarr/dolibarr
TX Client use
Some useful information on "tx push" and "tx pull" commands.
====tx push====
Used to push changes from your computer to Transifex server
Additional options for the tx push command are:
-h - Shows the help screen for the command
-l <lang> - Specify which translations you want to push (defaults to all)
-r <resource> - Specify the resource for which you want to push the translations (defaults to all)
-f - Push source files without checking modification times
--skip - Don't stop on errors. Useful when pushing many files concurrently.
-s - Push the source file to the server
-t - Push the translation files to the server
--no-interactive - Don't require user input when forcing a push
====tx pull====
Used to pull changes from Transifex server to your computer
Additional options for the tx pull command are:
-l <lang> - Specify which translations you want to pull (defaults to all)
-r <resource> - Specify the resource for which you want to pull the translations (defaults to all)
-a - Fetch all translation files from server (even new ones)
-s - Force the fetching of the source file (default: False)
-f - Force download of translations files
--disable-overwrite - By default Transifex will fetch new translations files and replace existing ones. Use this flag if you want to disable this feature.
--minimum_perc=VALUE - Specify the minimum acceptable percentage of a translation in order to download it.
Examples:
To pull all translation files for every language you just have to type:
tx pull -a
To pull all files for a specific language only (Italian for example):
tx pull -l it_IT
To push all source files (the language files of the "main" language) just type:
tx push -s
To push only a specific source file (admin.lang for example) type:
tx push -s -r dolibarr.admin
Integrate its translation into Dolibarr
If you have completed existing but incomplete .lang files or if you have created new .lang files for a new language, you can:
- You can upload changes/new files if you know how to use a GIT system. For this create an account on https://github.com/Dolibarr/dolibarr, fork Dolibarr project, make your change then send a Pull Request.
- Or just send your files by mail attachment to the list: dolibarr-dev@nongnu.org (subscription on page https://savannah.nongnu.org/mail/?group=dolibarr). A developer will add it for you into project.
Note: There are two master/reference languages, both of them are always upto date and complete:
- English (Language files are in the directory langs/en_US)
- French (Language files are in the directory langs/fr_FR)
You can use either of the two as reference because both are up to date. All other language files are likely to be incomplete.
Distribute your translation
Into official Dolibarr sources
The best thing after making a translation, is to include it on official version of Dolibarr. For this, just read previous chapter.
As a separate addon file
When you create a new language, if it is not integrated into Dolibarr, it can still be spread to others. You can build a package to distribute using the script build/makepack-dolibarrlang.pl but you can also make a zip by your own to send it on dolistore.com or on developer mailing-list dolibarr-dev (subscription on page https://savannah.nongnu.org/mail/?group=dolibarr).
User just has to unzip package into its dolibarr root directory to have language available.
Translate documentation on wiki
The wiki is written in 3 languages: English, French and Spanish. If you want to enhance documentation on one of this language, all you have to do is to create an account on this wiki. Then, you can edit existing pages to correct a bad translation or translate pages waiting for translation on page Category:Page_waiting_for_translation.
