Module Massorders
Revision as of 15:42, 10 May 2013 by Fmarcet (talk | contribs) (Created page with "Category:Complementary modules Category:Invoices {{TemplateDocDevEn}} {{TemplateDocUser}} = Informations = {{TemplateModuleInfo |editor=2byte.es ([http://www.2byte.es www...")
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Dolibarr min version: 3.3    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2013-05-10
With the module get remarkable efficiency in processing bulk orders. It is mainly suitable for companies that work with a large number of orders, and want to optimize the time spent to become bills.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
