Extrafields
Extrafields
Extrafields allow to add others datas to Dolibarr standard database schema. Introduced in version 3.2, extrafields are now implemented in businesses object :
- Thirdparties & contacts & users
- Events
- Customer Invoices
- Proposal
- Products & services
- Member & member type
- Orders
- Projects & project tasks (since 3.4)
Technical implementation
Each object have his table in database to store values of extrafields.
Datatables extrafield tables models
llx_BaseTableNAme_extrafields rowid integer AUTO_INCREMENT PRIMARY KEY, tms timestamp, fk_object integer NOT NULL, import_key varchar(14)
Load class for extrafields
To use extrafields all pages need include
require_once DOL_DOCUMENT_ROOT.'/core/class/extrafields.class.php';
Load extrafield array in object
$extrafields = new ExtraFields($db);
$extralabels=$extrafields->fetch_name_optionals_label($object->table_element);
$extralabels will be an array with code and label of extrafields.
Load extrafield into object
Extrafields are loaded in $object->array_options array.
$object->fetch($rowid);
$object->fetch_optionals($rowid,$extralabels);
Before call $object->create() or $object->update()
Values of extrafields sent by form need to be retrieve. For do that, use this method :
$ret = $extrafields->setOptionalsFromPost($extralabels,$object);
Inside edit page to display extrafields
$reshook=$hookmanager->executeHooks('formObjectOptions',$parameters,$act,$action); // Note that $action and $object may have been modified by hook
if (empty($reshook) && ! empty($extrafields->attribute_label))
print $object->showOptionals($extrafields,'edit');
Inside view page to display extrafields
print $object->showOptionals($extrafields);
After fetch method of this object class
require_once(DOL_DOCUMENT_ROOT.'/core/class/extrafields.class.php');
$extrafields=new ExtraFields($this->db);
$extralabels=$extrafields->fetch_name_optionals_label($this->table_element,true);
if (count($extralabels)>0) {
$this->fetch_optionals($this->id,$extralabels);
After Update method of this object class :
// Actions on extra fields (by external module or standard code)
// FIXME le hook fait double emploi avec le trigger !!
$hookmanager->initHooks(array('HookModuleNamedao'));
$parameters=array('socid'=>$this->id);
$reshook=$hookmanager->executeHooks('insertExtraFields',$parameters,$this,$action); // Note that $action and $object may have been modified by some hooks
if (empty($reshook))
if (empty($conf->global->MAIN_EXTRAFIELDS_DISABLED)) // For avoid conflicts if trigger used
$result=$this->insertExtraFields();
if ($result < 0)
$error++;
else if ($reshook < 0) $error++;
Admin pages
$elementtype='facture'; //Must be the $table_element of the class that manage extrafield
Repair Database
Search and find definition of $listofmodulesextra add the new extrafield declaration
$listofmodulesextra=array('societe'=>'societe','adherent'=>'adherent','product'=>'product',
'socpeople'=>'socpeople', 'commande'=>'commande', 'facture'=>'facture',
'commande_fournisseur'=>'commande_fournisseur', 'actioncomm'=>'actioncomm',
'adherent_type'=>'adherent_type','user'=>'user','projet'=>'projet', 'projet_task'=>'projet_task');
