Extrafields
Extrafields
Extrafields allow to add others datas to Dolibarr standard database schema. Introduced in version 3.2, extrafields are now implemented in businesses object :
- Thirdparties & contacts & users
- Events
- Customer Invoices
- Proposal
- Products & services
- Member & member type
- Orders
- Projects & project tasks (since 3.4)
Technical implementation
Each object have his table in database to store values of extrafields.
Datatables extrafield tables models is :
llx_BaseTableNAme_extrafields rowid integer AUTO_INCREMENT PRIMARY KEY, tms timestamp, fk_object integer NOT NULL, import_key varchar(14)
Display page have to include :
require_once DOL_DOCUMENT_ROOT.'/core/class/extrafields.class.php';
Load extrafield array in object :
$extrafields = new ExtraFields($db);
$extralabels=$extrafields->fetch_name_optionals_label('''ObjectClassName''');
Load extrafield into object :
''$object''->fetch($rowid);
''$object''->fetch_optionals($rowid,$extralabels);
Before call $object->create or $object->update :
$ret = $extrafields->setOptionalsFromPost($extralabels,''$object'');
Inside edit page to display extrafields :
$reshook=$hookmanager->executeHooks('formObjectOptions',$parameters,$act,$action); // Note that $action and $object may have been modified by hook
if (empty($reshook) && ! empty($extrafields->attribute_label))
print ''$object''->showOptionals($extrafields,'edit');
Inside view page to display extrafields :
print ''$object''->showOptionals($extrafields);
After fetch method of this object class:
require_once(DOL_DOCUMENT_ROOT.'/core/class/extrafields.class.php');
$extrafields=new ExtraFields($this->db);
$extralabels=$extrafields->fetch_name_optionals_label('company',true);
if (count($extralabels)>0) {
$this->array_options = array();
foreach($extrafields->attribute_label as $key=>$label)
$this->array_options['options_'.$key]=$label;
After Update method of this object class :
// Actions on extra fields (by external module or standard code)
// FIXME le hook fait double emploi avec le trigger !!
$hookmanager->initHooks(array('HookModuleNamedao'));
$parameters=array('socid'=>$this->id);
$reshook=$hookmanager->executeHooks('insertExtraFields',$parameters,$this,$action); // Note that $action and $object may have been modified by some hooks
if (empty($reshook))
if (empty($conf->global->MAIN_EXTRAFIELDS_DISABLED)) // For avoid conflicts if trigger used
$result=$this->insertExtraFields();
if ($result < 0)
$error++;
else if ($reshook < 0) $error++;
